100,000+ Mileage Foci, Post here.. - Page 96 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Discussions > Ford Focus & General Car Chat
Old 12-13-2013, 07:40 AM   #951
02Wagon5spd
Fan#: 128458
What I Drive: '02 Silver Focus Wagon SE 5-spd
FF Reputation: 1 02Wagon5spd Good Standing Member
2002 Ford Focus Wagon SE 5-speed
113,436 miles
I've owned it seven months and have replaced a leaky master cylinder, cracked ignition coil, and installed a new set of 195/60/15 B.F. Goodrich Advantage T/A tires.
02Wagon5spd is offline
Old 12-13-2013, 11:39 AM   #952
Highball116
Fan#: 112564
What I Drive: 2005 Red ZX4
FF Reputation: 1 Highball116 Good Standing Member
176,400 on our 2005 ZX4. Replaced a lot of stuff, including the front crash sensor and all four steel rims, which were so bent up they couldn't be balanced anymore. Front right wheel bearing and control arm had to go. Will soon replace the power steering pump, which is very corroded. Will probably hit 200,000 in the next year.
Toby
Highball116 is offline
Old 12-13-2013, 04:18 PM   #953
hoosiersam
Fan#: 100849
What I Drive: 2002 Red zx3
FF Reputation: 1 hoosiersam Good Standing Member
I have a red 2002 zx-3 with a 5 speed. I have 256,250 miles on it. Bought it in 2006 with 52,000. I have changed the master cylinder 3 times, the clutch at 200,000, the left and right motor mounts, the valve cover gasket twice, ac compressor. I made it to 250,000 before changing the timing belt,water pump and power steering pump. This week a rear wheel drum started grinding so plan on changing that over the weekend.
hoosiersam is offline
Old 12-15-2013, 01:08 AM   #954
Kodyston
Kodyston's Avatar
Fan#: 112498
What I Drive: 2003 Sangria Red ZX3; Zetec; MTX-75
FF Reputation: 3 Kodyston Good Standing Member
Wow! Sounds like you really got your moneys worth out of your Focus. lol Gives me high expectations for mine... but I know it probably wont last that long... :-(
Steeda Louvered hood, carbon fiber dash trim, shift knob & door sill plates. American Racing chrome plated 16" wheels. SVT suspension & K&N lifetime drop in air filter.
Kodyston is offline
Old 12-18-2013, 12:59 AM   #955
sfolse
Fan#: 14005
What I Drive: 2004 Focus ZTS
FF Reputation: 1 sfolse Good Standing Member
Smile ZTS High Mileage
I have a 2004 ZTS 2.3L with 270K plus miles daily commuter. Lots of fun!
My son just bought a 2013 ST, even more fun!
sfolse is offline
Old 12-18-2013, 10:54 AM   #956
mikewilt
Fan#: 129322
What I Drive: 2001 Ford Focus ZX3
FF Reputation: 1 mikewilt Good Standing Member
My 2001 ZX3 has 190K mi and I plan to keep going once I replace the clutch.
mikewilt is offline
Old 12-22-2013, 08:29 PM   #957
QCGoose
Fan#: 122217
What I Drive: '05 White ZX3 S, '03 Blue S10 ZR2
FF Reputation: 1 QCGoose Good Standing Member
'05 ZX3 S 5-speed with a little over 108k right now.
QCGoose is offline
Old 12-23-2013, 08:42 AM   #958
enjoisk8r2211
Fan#: 129226
What I Drive: 2002 Green (Pearl Metallic) Focus S
FF Reputation: 1 enjoisk8r2211 Good Standing Member
02 green focus SE 2.0 zetec
115,906 miles
Daily driver/fun car. Just picked it up a week ago from used car dealer.
enjoisk8r2211 is offline
Old 12-23-2013, 09:13 AM   #959
Paul P
Paul P's Avatar
Fan#: 75111
What I Drive: 2001 ZX3, 71 Chevelle 408
FF Reputation: 2 Paul P Good Standing Member
Buy-Sell-Trade Rating: (6)
Just broke the 250,000 mile barrier. Still running perfect with the stock clutch in place!
Paul P is offline
Old 12-24-2013, 10:43 AM   #960
2003 Ford Focus
2003 Ford Focus's Avatar
Fan#: 91951
What I Drive: My daughter drives 03 Focus SE
FF Reputation: 4 2003 Ford Focus Good Standing Member
Smile
My daughter's 2003 Focus SE - SPI 2.0 turned the magic 100,000 miles or 160,000 Kms in August 2012, but I forgot to post it. Has about 187,000 Kms on it now.
Update: Running 5W30 year round now. No indication that it is hurting. With 100,000 plus there is enough clearance between journals and bearings to warrant it. Eliminated some of the piston slap and valve train noises too. Plugged in below -5 degrees C 24 hours a day.
New snow tires on the standard 14" rims this year too. Made a big difference for navigation and braking. Will look round for some more 14" rims in the spring to mount her summer tires.
Aside from routine maintenance, trans oil drop and fill, plugs, wires, belts, idler pulley, tensioner and water pump at 155,000 Kms it has not demanded much in the way of fixes. I've attempted polishing the headlight lenses twice, but will have to become more serious about it in the spring. New ones are not an option; - expensive even for aftermarket.
Oh, we replaced the rear brake hardware after a grinding noise developed in October 2012; - return spring snapped off. I can see the stabilizer links needing replacement in 2014; although they have zerk fittings, no one ever greased them.
Even put a cabin filter under the cowl (retro'ed real nice in the top of the heater intake)
The AC has developed a small leak around the high side hose attached to the compressor; could be an O ring, but not too concerned.
My wife and I love driving it when my daughter comes home to visit. Solid ride, steering is tight and easy to park.
Happy Holidays Everyone!
First Ford: '62 Falcon Futura 2-door / Modified Production 302 / 270 HP / Close Ratio 4-speed / 3.50 ratio 8" Fairlane Differential (289-271 HP cam / heads / exhaust / medium high rise / 600 CFM Holley / dual-point) Low 15's at 90+ MPH
2003 Ford Focus is offline
Similar Threads
GTG post cruzstyle Fanatics: SoCal 0 06-07-2006 12:55 PM
Foci BHC KaiRoss Great Lakes Fanatics 1 02-08-2006 07:10 PM
Post your 1/4mile and 0-60mph time version: For the love of (d/dt)≤ xFOCIx DURATEC Performance (2003-2011) 9 11-26-2005 08:07 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
