Old 08-07-2012, 02:58 PM   #861
NathanielCatch
Fan#: 102296
What I Drive: 2005 Ford Focus ZX4 S
FF Reputation: 1 NathanielCatch Good Standing Member
Originally Posted by afraziaaaa View Post
Massive Speed System makes an aftermarket valve cover.
Do you also have a CEL to go along with the ticking?
Thanks for the info on the valve cover. It isn't very attractive but its good to know there is one out there. I am not sure what you mean by CEL. I googled it and by CEL I think you mean check engine light. If that is what you mean then no. There have been no lights to indicate any kind of problem. I do have a video posted on youtube. Seems more like a cylinder 1 or 2 problem or injectors.
Also I know this isn't the thread so thanks for the help.
YouTube Video
NathanielCatch is offline
Old 08-07-2012, 05:20 PM   #862
DarkSpork
Fan#: 81461
What I Drive: 2006 Silver ZX3 SES
FF Reputation: 1 DarkSpork Good Standing Member
Mine sounds kind of like that, maybe not as loud. From my understanding it's the injectors, and the noise doesn't necessarily mean they are bad, there just isn't a whole lot of sound insulation. At least that's what other people on the forum have told me.
DarkSpork is offline
Old 08-07-2012, 06:59 PM   #863
NathanielCatch
Fan#: 102296
Thanks for the info. I took off the valve cover today and checked everything and re-seated my gaskets on the valve cover. They were leaking a tiny bit in the spark plug chamber. I am going to get the sea foam and injector cleaner this afternoon and see what happens.
I'll make a new video as soon as it's done.
Also, can you link me to a thread that this should go on? I am very new.
Old 08-07-2012, 07:45 PM   #864
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
What I Drive: 2005 ZX4 ST
FF Reputation: 24 afraziaaaa Great Standing Member
Buy-Sell-Trade Rating: (10)
I would say this thread is fine. Do you have a mechanic's stethoscope? If not, you should get one. like $4 at harbor freight.
Sounds normal for the most part. If no check engine light (CEL), then its probably just injectors. One thing to be concerned about if there is a chattering coming from the engine is the tumble flaps in the intake manifold (you will get a CEL with this problem). Myself, along with a couple other 100k foci duratecs are having or have had this problem.
afraziaaaa is offline
Old 08-07-2012, 08:47 PM   #865
NathanielCatch
Fan#: 102296
Just got done doing a sea foam treatment. Already quieter. I'll post the video as soon as it's edited.
Also I live in a town with a general store and a couple gas stations. The likeliness of me finding a mechanics stethoscope is slim to none. Thanks though.
Old 08-07-2012, 10:48 PM   #866
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
Did you take the sea foam directly into the intake or did you put it in the gas tank?
Old 08-07-2012, 10:50 PM   #867
NathanielCatch
Fan#: 102296
Tank. That is what the instructions say. Hope that is okay.
Old 08-08-2012, 08:13 AM   #868
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
Tank. That is what the instructions say. Hope that is okay. Uploading the video now. Should be live in about 3-4 hours. I will post the link here when it's done.
Tank is fine. That will clean your fuel system out. Be sure to change the fuel filter soon after as all the crap gets caught in there. That can cause the fuel pump to gum up like mine did. There is a filter element (basically a mesh housing) that surrounds the fuel pump. Over time, debris will get caught in it and cause your fuel pump to fail. Better later than sooner.
You can also disconnect the vacuum line on the intake manifold and suck it up into the intake and cylinder head that way, although it bypasses the injectors and goes straight to the intake/valves to clean the carbon off. Also, try some in your engine next oil change.
Old 08-08-2012, 12:05 PM   #869
NathanielCatch
Fan#: 102296
Here is the video. I think I may have fixed the tick I heard but I think you are all correct in that the injectors and everything else just make a lot of noise anyway. Thanks for the help and you're welcome to others who may have this problem and this helped you.
YouTube Video
Old 08-12-2012, 06:59 AM   #870
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
FF Reputation: 9 drjkel Good Standing Member
My '01 just turned 100,000 this past week...
2001 Amazon Green ZTS 100,000mis
2012 Sterling Grey SE Sedan M/T!
drjkel is offline
Similar Threads
GTG post cruzstyle Fanatics: SoCal 0 06-07-2006 12:55 PM
Foci BHC KaiRoss Great Lakes Fanatics 1 02-08-2006 07:10 PM
Post your 1/4mile and 0-60mph time version: For the love of (d/dt)² xFOCIx DURATEC Performance (2003-2011) 9 11-26-2005 08:07 PM
