100,000+ Mileage Foci, Post here.. - Page 47 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Discussions > Ford Focus & General Car Chat
Old 10-23-2010, 09:18 AM   #461
RallieConGoggle
RallieConGoggle's Avatar
Fan#: 50774
What I Drive: 2007 CD Silver ZX4
FF Reputation: 9 RallieConGoggle Good Standing Member
2000 Pitch Black ZTS
188,000 miles
Problems:
Ignition Key Module
Ignition Coilpack
Fuel Pump
Crankcase Ventilation hose (rear) busted a hole right at the INT MAN connection
All of the above problems happenned right around 150,000 and I haven't had any trouble since.
The other big issue I've had is with the rear wheel bearings. There are two main root causes for this.
1) No cotter pin on the spindle nut.
These nuts are good for about 3 or 4 removals before they start backing out and causing bearing failures. When idiots work on your car and do a "free brake inspection" they will take off your spindle nut and not tell you about it. Be wary of this when you need a wheel alignment or new tires. Recently, I've been putting lock-tite on my spindle when I remove the nut, and that seems to help.
2) I used to use Auto-Zone wheel bearings. NEVER buy anything safety related from Auto Zone!
Good luck, my fellow high-milers!
Rally with your goggles on!
2000 Pitch Black ZTS Auto (230,000+ miles)
2007 CD Silver ZX4 SES 5spd
Zetec Crew #190
RallieConGoggle is offline
Old 10-23-2010, 12:19 PM   #462
sputnikrlife
Fan#: 79761
What I Drive: 2000 Silver Ford Focus SE
FF Reputation: 1 sputnikrlife Good Standing Member
Got a 2000 SE with a replaced engine SO to DO
body 146k Engine 115k Give or take a few
new pads, front struts, timing and serpentine belts at 135k
Engine still runs like a dream
one problem though.
about once or twice a week, could be a cold start in the morning or a start after a few hours of sitting, turn the key, crank, no start. second turn of the key, crank, starts right up. Not that much of a problem.
sputnikrlife is offline
Old 10-24-2010, 08:29 AM   #463
focus racing group
Fan#: 36810
What I Drive: 2000 rain forest zts
FF Reputation: 3 focus racing group Good Standing Member
to rallieConGoogle...i used to have alot of problems with wheel bearings until i got a 4 whl alignment...have a 2000 zts wth 236,000, use only synthetic oil (amsoil) and reg gas..have replaced alot of parts, but still have original engine, clutch and tranny
sedan revolution #82 zetec crew #243
focus racing group is offline
Old 10-24-2010, 11:25 PM   #464
jesusamares
jesusamares's Avatar
Fan#: 64713
What I Drive: 2000 Rainforest SE SOHC SPI
FF Reputation: 1 jesusamares Good Standing Member
I have a 2000 ford focus spi sohc
I bought it for $300 and well it would turn off whenever i was on a stop light,
To fix the problem of it from turning off i made it idle high,
Then one day I looked for leaks and found that the EGR Valve gasket was broken and it wad missing a screw, so basically it wasnt on there tight enough. In the process of trying to find the problem I had changed the fuel injectors, fuel pump, fuel filter, valve cover gasket, ignition coil, spark plugs abd wires, motor mounts and tranny mounts, tranny oil, engine oil. And i believe thats all. Now i have the shocks syuts tie rods inner and outer and sway bar end links all moog and kyb. Also imma change out the rear bushings and the bearings. I have 147700 miles and i believr i bought it at 125000. I hope I can make it run better and smoother than stock.
!Stock_2000_Focus!---[S.E.-S.O.H.C.-S.P.I.]
jesusamares is offline
Old 10-29-2010, 07:57 AM   #465
Huntr
Fan#: 32661
What I Drive: 2012 Aluminum SE Hatchback
FF Reputation: 1 Huntr Good Standing Member
2005 ZX5 145,000 bought new.
So far I have:
new alternator
new clutch (LOTS of stop and go traffic)
What it needs:
air box for the A/C system replaced because the door is stuck and it broke the switch cable AGAIN. Probably not going to do it because I've been quoted $900 to do it and the car's a beater at this point and not putting that kind of money in when a $20.00 fan/heater from the parts store will work just fine.
Wipers don't "park" correctly and in the "mist" function I have to hold the arm down or the wipers don't work.
Huntr is offline
Old 10-30-2010, 10:34 PM   #466
dtriplette
Fan#: 80014
What I Drive: 2007 blue ford focus se
FF Reputation: 1 dtriplette Good Standing Member
Power steering problems
I had my steering pump and rack replaced and i still have loud squeeling and power steering fluid pushing out of resevoir, what can i do? please help
dtriplette is offline
Old 10-31-2010, 10:20 AM   #467
63redsled
Fan#: 23219
What I Drive: 2000 red zx3 1966 for tbird 1963 galaixe 500 ragtop 1972 f-100
FF Reputation: 1 63redsled Good Standing Member
2000 zx3 193k still has the factory clutch
2000 zx3 193k still has origanal Clutch !!
good car it will be 10 years old on dec 18 of this year!!!
the worst thing to happen to it was when we hit a deer with it.
only towed home one time!
thinking to buy one more for my wife
i fixed every thing my slef
only went to the shop for the timing belt
thanks for all the help fixing this car over the years
marc
63redsled is offline
Old 10-31-2010, 12:25 PM   #468
DAAR84
DAAR84's Avatar
Fan#: 80017
What I Drive: 2006 "Sonic Blue" Ford Focus SE
FF Reputation: 1 DAAR84 Good Standing Member
06 se 125+
DAAR84 is offline
Old 11-02-2010, 11:24 PM   #469
charlie.cross2
charlie.cross2's Avatar
Fan#: 51550
What I Drive: 2012 Tuxedo Black Metallic SE HTCBK
FF Reputation: 1 charlie.cross2 Good Standing Member
LX SPI With 127k. Replaced the alternator a month ago, along with the clutch switch, and had a plug foul at 30k. Other than that, normal maintenance does wonders
charlie.cross2 is offline
Old 11-11-2010, 02:18 PM   #470
Binzer
Binzer's Avatar
Fan#: 73070
What I Drive: 2013 Ruby Red SE Hatch, 94 FLSTC
FF Reputation: 1 Binzer Good Standing Member
Brake Drum Question
I have a high mile ZX4-SES and want to change the rear drum brakes before snow, any of the info I have found shows what looks like pulling the spindle off with the drum on it, does the drum come off by itself like the older cars.
I have not had to do much on the car since day one, serp belt, gas filter, front brakes, 114k miles and passed emissions.
Tnx.
Binzer is offline
Similar Threads
GTG post cruzstyle Fanatics: SoCal 0 06-07-2006 12:55 PM
Foci BHC KaiRoss Great Lakes Fanatics 1 02-08-2006 07:10 PM
Post your 1/4mile and 0-60mph time version: For the love of (d/dt)≤ xFOCIx DURATEC Performance (2003-2007) 9 11-26-2005 08:07 PM
