100,000+ Mileage Foci, Post here.. - Page 36 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 01-25-2010, 08:54 PM   #351
trailbikerider
trailbikerider's Avatar
Fan#: 50501
What I Drive: 2002 Granny Gold ZTS, 94 2.3 Ranger
Points 10,328, Level 67
Points: 10,328, Level: 67 Points: 10,328, Level: 67 Points: 10,328, Level: 67
Level Up 70% Completed
FF Reputation: 14 trailbikerider Great Standing Member
Buy-Sell-Trade Rating: (15)
172,xxx and counting!
Originally Posted by SVT3658
I am enjoying this ice cream like Evan enjoys drinking a beer from a koozi in a beach chair across the street from a middle school
trailbikerider is offline
Old 01-26-2010, 05:46 PM   #352
xxacefirexx
Fan#: 48311
What I Drive: 2002 Blue ZX3
FF Reputation: 1 xxacefirexx Good Standing Member
120k, but it died :(
xxacefirexx is offline
Old 01-29-2010, 03:04 PM   #353
FociBoi121
FociBoi121's Avatar
Fan#: 53573
What I Drive: 2003 InfraRed ZX3 ATX
FF Reputation: 4 FociBoi121 Good Standing Member
Update
2003 Zx3 ATX 2.0 dohc
119,690 miles
i replaced alternator and battery at 117,xxx miles
im due for new springs and struts in the front its creaking bad
now my cooling fans are dead at 118,xxx miles finding melted relays burnt out and corroded fan shroud resistor in process of replacing all next to that regular oil changes as well as seafoam and fuel filter every 3 oil changes its still running like a champ
Current Mods: about me profile
ZETEC Crew #237
HATCHBACK LOVER #121
PS3 ID: LarkBoi189
Slow bolt ons added or bolt ons slowly added?
FociBoi121 is offline
Old 01-30-2010, 02:30 PM   #354
volcom8716
volcom8716's Avatar
Fan#: 51408
What I Drive: 01 twilightblue wedge
FF Reputation: 2 volcom8716 Good Standing Member
2001 zx3 5 spd 105k had her since she was born
volcom8716 is offline
Old 02-02-2010, 11:51 AM   #355
focus_man
focus_man's Avatar
Fan#: 57686
What I Drive: 03 Liquid grey ZX3 Ford Focus
FF Reputation: 1 focus_man Good Standing Member
03 zx3, had em since 35k now he has 107k and still runnin good. Had to replace the battery, fuel pump, clutch, master cylinder, front right spindel, all stocks, and have a lot of after market parts.
focus_man is offline
Old 02-02-2010, 04:31 PM   #356
FociBoi121
FociBoi121's Avatar
Fan#: 53573
Update 120,015 its gonna be ok lol tax return feb 12th im replacing passenger/driver motor mounts with OEM and dogbone with polyurethane, timing belt and theres not much else i can think of engine wise wise of so the rest of the money will go to window tint, replacing driver side manual window regulator, and RIMS!, adn ill shop around for a red svt rear bumper and a front lip if i find a good deal for my zx3 thats served me so well thus far
ZETEC Crew #237
PS3 ID: LarkBoi189
Old 02-03-2010, 03:20 PM   #357
larrywhite90045
Fan#: 57652
What I Drive: 2000 Focus SE Wagon
FF Reputation: 1 larrywhite90045 Good Standing Member
111,000 miles on 2000 wagon, First wagons came off the line around Jan. 2000 mine was one of first to be produced at Ford Wayne, Mi. Leaking oil out od oil cap , O-Ring was broken, fixed yesterday. . Wagon would stall & ford engineers didn't find the trouble until 2003. they found when the gas tank was 1/4 full & you made a right turn it would shut down. Runs better than my 2008 Escape.
New front struts @ about 65,000. Loose steering gear & 85k I didn't want to drive it to Las Vegas @ 111,000 until the reading all the threads. Thanks Focus Fanatics you helped me out. I will never sell it!!
larrywhite90045 is offline
Old 02-03-2010, 03:30 PM   #358
larrywhite90045
Fan#: 57652
Auto Recall Date: NOV 19, 2003
Vehicle Component: FUEL SYSTEM, GASOLINE
Estimated Vehicles Affected: 671000
Model Affected
2000 FORD FOCUS
2000 Ford Focus Defect Summary:
ON CERTAIN PASSENGER VEHICLES, CONTAMINATION OF THE FILTER IN THE FUEL DELIVERY MODULE (FDM) CAN REDUCE, AND EVENTUALLY BLOCK, THE FLOW OF FUEL TO THE ENGINE.
Defect Consequence:
THIS MAY CAUSE ENGINE HESITATION, LOSS OF POWER, SURGING, AND OTHER SIMILAR SYMPTOMS. OVER TIME, THE FILTER MAY BECOME SUFFICIENTLY BLOCKED TO CAUSE THE ENGINE TO STALL, WHICH COULD RESULT IN A CRASH.
Remedy:
THIS ACTION IS DEEMED A SAFETY IMPROVEMENT CAMPAIGN AND IS NOT BEING CONDUCTED UNDER THE SAFETY ACT. ALL OWNERS WILL BE NOTIFIED OF THE PROBLEM, AND DEALERS WILL REPLACE THE FDM WITH A NEW DESIGN AT NO CHARGE IF THE OWNER REPORTS THAT THE VEHICLE EXHIBITS ANY OF THE IDENTIFIED SYMPTOMS. THE FREE REPLACEMENT WILL BE AVAILABLE FOR A PERIOD OF 10 YEARS FOLLOWING THE ORIGINAL PURCHASE OF THE VEHICLE, WITH NO MILEAGE LIMIT. OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING NOVEMBER 2003. OWNERS SHOULD CONTACT FORD AT 1-800-392-3673.
671000
Notes: FORD MOTOR COMPANY 03N01
Old 02-04-2010, 10:04 PM   #359
nekoashide
Fan#: 50156
What I Drive: 2010 Ford Focus S
FF Reputation: 1 nekoashide Good Standing Member
2003 Ford Focus ZX3 Totalled at 167,244
Burned no oil with 5k Oil changes and consistant 32 MPG
Replaced.
Radiator Fan
Radiator Fan Shroud Thermresistor
Starter
Battery
EGR Vaccume Solenoid
DPFE Sensor
PCV Hose on back of engine
3x Brake pads and 1 set of Rotars
Serpentine Belt Tentioner
Spark Plugs
Passanger side Motor Mount
T-Stat Housing
And at 120k Water pump, Timing belt and Tensioners.
Things needing to be done when it was totalled.
Strut's and Strut Tower.
T-Stat Housing again
Valve Cover Gasket
nekoashide is offline
Old 02-05-2010, 01:04 AM   #360
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
I'm at 102k and going strong!
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Similar Threads
GTG post cruzstyle Fanatics: SoCal 0 06-07-2006 01:55 PM
Foci BHC KaiRoss Great Lakes Fanatics 1 02-08-2006 08:10 PM
Post your 1/4mile and 0-60mph time version: For the love of (d/dt)≤ xFOCIx DURATEC Performance (2003-2007) 9 11-26-2005 09:07 PM
