Old 12-16-2009, 07:45 PM   #311
myfafp3
zetec 2 duratec swap
myfafp3's Avatar
Fan#: 59725
What I Drive: 2000 Cloud9 Sport Saloon
FF Reputation: 4 myfafp3 Good Standing Member
The bearing is what allows the wheels on your car to spin freely. the fronts are located where the axle slide thru to attach to the hub. The rear are integrated into the drums (mine are idk about other fofos). The wheel bearings on my focus are sealed so there is no repacking them. Just press them out and reinstall new ones.
As for the person wondering about the rear wheel bearings and replacing them...if you are lowered at anything other than what an svt sits at, I'd recommend doing them. Idk where u guys are from but in socal, our roads are not silky smooth specially with the recent rain. All it takes is the right sized bump, pothole, or improper alignment angle to start the wear then one day ul hear a metal to metal scraping sound accompanied with a strange wiggle in the rear end followed by a tow home cuz the wheel is about to fall off. I replaced my rears 4 times now and the fronts once. It doesn't really matter how much weight the rear wheels carry its how the alignment is. Too much toe or camber accelerates the wear of the bearing. Not to mention plain old mileage. If ur over 130k miles in a focus u should replace the bearings anyway. It makes a difference.
Posted via FF Mobile
myfafp3 is offline
Old 12-16-2009, 07:46 PM   #312
myfafp3
myfafp3's Avatar
Fan#: 59725
Oh my 2000 zetec sedan is at 190k miles.
myfafp3 is offline
Old 12-16-2009, 08:15 PM   #313
j-zetec_pr
MACHINERY TECHNIAN
j-zetec_pr's Avatar
Fan#: 47101
What I Drive: 2000 Silver ZX3 Kona, MTX-75, Zetec
FF Reputation: 27 j-zetec_pr Great Standing Member
Buy-Sell-Trade Rating: (9)
if you have a lowered car, the right thing to do is to correct the camber using any of the different parts that come for that (camber bolts, plates, etc). that way you are not putting any more stress on the bearings than stock and you won't be wearing tires wrong.
wheel bearings don' really go out all of a sudden like that. the start making a quiet rubbing/grinding sounds that worsens and gets louder over time. when you start hearing them, it's time to replace them. if they aren't making any noise, they are good. you can check them by jacking up the car and see if they have any play (movement) up and down or left to right. if it's working perfectly, why replace it?
Carpe diem quam minimum credula postero
ODOMETER: 162,000 miles
j-zetec_pr is offline
Old 12-17-2009, 01:49 AM   #314
Kayak_man
iCTHEWORLDINMYKAYAK!
Kayak_man's Avatar
Fan#: 30025
What I Drive: 2001, twilight blue ZX3
FF Reputation: 13 Kayak_man Great Standing Member
I'm at 123K and I'm replacing the front wheel bearings tomorrow (the back ones are still in good shape) and something else..I can't think of what it is right now. LOL.. I'll update my post when i remember. I've been having lots of issues with this car..It seems like every couple of month something goes wrong with it. :(
Sold the focus
Kayak_man is offline
Old 12-17-2009, 01:51 AM   #315
j-zetec_pr
MACHINERY TECHNIAN
j-zetec_pr's Avatar
Fan#: 47101
aside from wheel bearings, what else is going wrong?
Old 12-17-2009, 01:56 AM   #316
Kayak_man
Kayak_man's Avatar
Fan#: 30025
What hasn't yet? lol.. Like i said every couple of months somthing seems to be wrong with it.. Here's a list (below)
Originally Posted by Kayak_man View Post
01 focus zx3
I made it to 120k miles!
things i did so far:
replaced timing belt
pcv
oil change
cooling system flush
thermostat housing
coolant leak leaking
oil filter
gasket
replace upper and lower radiator hoses
valve cover gasket
replace front engine mount
I've been having trouble with the breaks too!
I've been having lots of problems with my focus... sorry to say this but i WILL not being getting another focus in the future..Still seems to be running good. I will be keeping it another year or so and then its outta here!!
Sold the focus
Old 12-17-2009, 01:57 AM   #317
j-zetec_pr
MACHINERY TECHNIAN
j-zetec_pr's Avatar
Fan#: 47101
^^ i felt the same way around 120,000 or so.
all at the same time, i had to swap suspension, battery, rebuild starter, wheel bearings, endlinks, axles, had the radiator plastic tube break, and the only key i had stopped working with the PATS system. all this sucked, because even though it's mostly maintenance stuff which the focus was behind on, it all happened at the same time- within maybe a 10,000 mile window. i almost lost hope on the focus, but at this point it's as reliable as any other car.
Old 12-17-2009, 02:00 AM   #318
Kayak_man
Kayak_man's Avatar
Fan#: 30025
^I feel your pain! lol.. I had maybe 2 big issue happen at once and it was a pretty expensive fix let me tell you. Oh well i guess that's life.
Oh the other issue is the exhaust..it think it's making the back end of my car rattle like crazy..It's bugging the heck out of me.
Sold the focus
Old 12-17-2009, 02:01 AM   #319
j-zetec_pr
MACHINERY TECHNIAN
j-zetec_pr's Avatar
Fan#: 47101
oh yeah, i also did pcv, oil pan rtv, thermostat housing and valve cover gasket.
thing is though, most of that stuff is inevitable maintenance at our mileage and not any real serious problems.
Old 12-17-2009, 11:51 AM   #320
SVTOtter
SVTOtter's Avatar
Fan#: 46753
What I Drive: 2003 Black SVT EAP
FF Reputation: 1 SVTOtter Good Standing Member
125,500 miles.
Clutch is starting to slip.
It's original.
Tray sliding is hilarious.
2003 SVT #2453
SVTOtter is offline
Similar Threads
GTG post cruzstyle Fanatics: SoCal 0 06-07-2006 12:55 PM
Foci BHC KaiRoss Great Lakes Fanatics 1 02-08-2006 07:10 PM
Post your 1/4mile and 0-60mph time version: For the love of (d/dt)² xFOCIx DURATEC Performance (2003-2011) 9 11-26-2005 08:07 PM
