Lets see your 1/4 mile times - Page 16 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 05-01-2012, 11:07 AM   #151
SMITHBOY76908
Boost Junkie!
SMITHBOY76908's Avatar
Fan#: 56301
What I Drive: 2007 Turbo ZX3
FF Reputation: 18 SMITHBOY76908 Great Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by DoomsdayFAN View Post
So it sounds like all-in-all, I'd only lose a couple of lbs per wheel. Not worth it IMO. I'd rather spend the money on cams & engine mounts.
It's a couple pounds of unsprung-reciprocating weight though. That 10lbs you drop in wheel weight on front would be about equivalent to dropping 50-60lbs of dead weight out of the car. Then think the tire weights also. It can make a big difference.
For the price you could buy bags for the rear, you could just about buy adjustable rear shocks. Battery relocation for a basically stock car that doesn't need it is a waste of time. Especially since most trunk mounted batteries require a rear external shut off switch in order to be in compliance with NHRA/IHRA regulations. Something else I'm also switching to soon is suspension limiters. It's basically just two chains on the front control arms the run up to the strut mount point on the frame and keeps the suspension from lifting. On a RWD car, this is controls the front end lift to get the best center of gravity when lifting the front wheels. On our FWD cars, it's a ghetto drag pack.
Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger! Badger!
MUSHROOM! MUSHROOM!
SMITHBOY76908 is offline
Old 05-01-2012, 12:39 PM   #152
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I want to see that chain setup when you're done with it.
2006 sonic blue zx5 GT2871r turbo.
sporadic is offline
Old 05-01-2012, 10:17 PM   #153
SMITHBOY76908
Boost Junkie!
Fan#: 56301
I'll be sure to do that. The straps are more common but also more permanent since they are usually weld-on and harder to take the strap/cable off. I'll be using the same weld-on mounting brackets but with small chains with release hooks so I can just hook it up at the track and unhook them when it's time to drive home.
MUSHROOM! MUSHROOM!
Old 05-02-2012, 06:03 AM   #154
sporadic
sporadic's Avatar
Fan#: 12724
A turnbuckle for pre-loading would be a thought. That would be a beefy and pricey turnbuckle though. Now you have my wheels turning.
sporadic is offline
Old 05-03-2012, 08:04 AM   #155
Royce01
Royce01's Avatar
Fan#: 93858
What I Drive: 2001 amazon green metallic SE 4dr
FF Reputation: 1 Royce01 Good Standing Member
yeah doomsday i put an air filter on my car and it only gave me 5hp and it drop my power to wieght ratio by .3/1 while i would of had to take out my whole back seat to get that. It's better to upgrade the engine because it doesn't matter what you do to lighten it, you won't make it a lotus elise. no even if it was just frame and motor. just put money in the engine, you'll get better results.
a $15,000 honda and a $500 exhaust doesn't make you a street racer!
Sedan Revolution #223
Rally Revolution #223
132bhp 147ft/lb tq
Royce01 is offline
Old 05-03-2012, 04:55 PM   #156
DoomsdayFAN
DoomsdayFAN's Avatar
Fan#: 92019
What I Drive: ~2006 ZX4 SE Sedan 2.0L~
FF Reputation: 1 DoomsdayFAN Good Standing Member
Is it possible to remove just the upper portion of the backseat? I really don't want to have to unbolt the whole thing from the frame itself. I'd much rather just take off the bits and pieces that can easily be put back on, without much effort.
I'll hopefully be getting my 4-1 header on tomorrow. After that, I'll be getting a tune, and I'll have the car made to where it takes premium grade gas, so hopefully that helps some too.
After that, maybe in a few months, I was thinking about upgrading my camshafts and valve springs/retainers. That'll be around $630 for all that + whatever it costs to have it installed.
After that, maybe late next year sometime, I was thinking about possibly getting a pair of $900 coilovers.
DoomsdayFAN is offline
Old 05-03-2012, 05:33 PM   #157
SMITHBOY76908
Boost Junkie!
Fan#: 56301
While this is true, weight reduction is free. Just takes a little bit of your time. I went from 13.75 @ 103mph to 13.42 @ 105mph with just weight reduction. I later got it to 12.93 @ 105mph with slicks. I shaved off almost a full second without adding any more power to the car, just weight reduction and tires.
MUSHROOM! MUSHROOM!
Old 05-15-2012, 10:04 AM   #158
Paul P
Paul P's Avatar
Fan#: 75111
What I Drive: 2001 ZX3, 71 Chevelle 408
FF Reputation: 2 Paul P Good Standing Member
Buy-Sell-Trade Rating: (6)
My 2001 ZX3
15.6@87mph, 60ft 2.2
Stock cams, injectors, bottom end and clutch with 222000 miles
Tune with bolt ons and mildly ported head.
Crower stage 2s and Quaife diff are next.
Fun street car.
When do I need to up size the injectors?
Paul P is offline
Old 05-16-2012, 01:37 AM   #159
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: 13 stang
FF Reputation: 90 goinloco1 Excellent Standing Member
stock zetec injectors are 19#. with your mods 24# svt injectors or 30# injectors and maf should do as well as a retune for them. the 30# would give you room to grow in the future.
your probably running the stockers pretty close to max at wot top end. a wideband o2 would show it starting to lean out if you were running out of injector or close too it.
goinloco1 is offline
Old 05-16-2012, 08:24 AM   #160
Paul P
Paul P's Avatar
Fan#: 75111
Thanks for the answer.
I think you are right about the injectors being needed for future mods.
It is tuned with an Innovative MTX-L WB O2 it is still ok at WOT the moment.
SVT MAF tube and airbox mod are in it.
I agree there is no other way to tune it safely without it.
Paul P is offline
Similar Threads
Terrible 1/4 mile times in my SVT Silver Cosworth SVT Performance (2002-2004) 43 01-03-2012 12:54 AM
1/4 times for the jrsc+bbk kharazmatik General Forced Induction 11 05-10-2006 04:57 PM
stock 1/4 mile times, where to shift ZX3Driver ZETEC Performance (2000-2004) 48 06-25-2005 03:26 PM
0-60 - 1/4 mile times for a wide range of cars Goat Roper Autocross Racing 15 05-06-2005 09:42 AM
1/4 Mile Times..... HaveBlue83 ZETEC Performance (2000-2004) 31 01-07-2004 12:04 AM
