Lets see your 1/4 mile times - Page 14 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 03-29-2012, 09:33 AM   #131
AllOutZX2
AllOutZX2's Avatar
Fan#: 80930
What I Drive: 1998 Ford Escort ZX2
FF Reputation: 1 AllOutZX2 Good Standing Member
Originally Posted by NanoAnimal View Post
While the suspension doesn't preload the same as a rwd, a fwd does preload the a-arm bushings. you can preload them past the point needed which usually ends up causing the tires to spin or bad wheelhop (urethane a-arm and engine mount bushings usually cure it in a modified svt. Did mine anyway). Gotta remember on a fwd the engine, tranny, a-arm bushings are all part of the suspension and they preload. Its a totally different geometry to a rwd. altho both do the same weight transfer to the rear, which in a fwd if its not controlled will cause traction loss.
In a FWD Escort or Focus chassis you would swap in Wagon rear coil springs, and install 90/10 shocks if you can get them to keep the rear end up. If these shocks are not available you can use air bags in the rear springs. You would also swap over to some skinny tall rear runner tires 1-2" taller in diameter then your fronts to get that rack going forward.
As stated above i havn't done the A-arm urathene mod yet, but I have ES Inserts in rear and a Wagon front motor mount.
Shawn
Full Bolt-On's, SCT VCT Tuned ECU, 3500rpm Edge Racing Stall, 205/60R13 M&H D.O.T Street Slicks
AllOutZX2 is offline
Old 03-29-2012, 02:42 PM   #132
SMITHBOY76908
SMITHBOY76908's Avatar
Fan#: 56301
What I Drive: 2007 Turbo ZX3
Points 14,482, Level 78
Points: 14,482, Level: 78 Points: 14,482, Level: 78 Points: 14,482, Level: 78
Level Up 8% Completed
FF Reputation: 18 SMITHBOY76908 Great Standing Member
Buy-Sell-Trade Rating: (4)
Pretty much this!
I'm running 24.5 x 8 slicks on the front with 25.5 x 4 skinnies on the back with Koni adjustable rear shocks set as stiff as they'll go. I'm building ~7psi on a 4000rpm 2-step which is nice with the manual because it doesn't load the suspension. The FSWerks lower stress bar, control arm poly bushings, and LSD did wonders on reducing wheel hop.
I'm pretty much in the same boat as elsolo. Being a fox body / radial tire car guy for so long, learning to launch this car was a whole new experience. Trying to apply some of the same principles from a RWD to a FWD didn't turn out so well. Just learning how to launch FWD took me from a 14.18 on my first pass to a 13.42 on street tires. Slicks got me in the 12s.
Russia... is... awesome!
SMITHBOY76908 is offline
Old 03-29-2012, 08:05 PM   #133
AllOutZX2
AllOutZX2's Avatar
Fan#: 80930
Originally Posted by SMITHBOY76908 View Post
Pretty much this!
You could get extreme and install wheelie bars :) It's more challenging to get a FWD to hook then rwd, the weight transfer isn't going where you need it to. I mean in a RWD first thing I would do is pop that front sway bar off, in a FWD if anything I would add a larger one so it keeps both front tires planted evenly.
Shawn
Old 03-30-2012, 01:18 PM   #134
SMITHBOY76908
Fan#: 56301
I've haven't removed the front swaybar from any of my foxbodies. I just go with adjustable shocks and struts with suspension limiters on the front. I will then adjust the shocks stiffness and front suspension limitation depending on track conditions. I always kept the front swaybar in and added the panhard bar to the back so the car would lift the front wheels evenly and keep straight ahead.
For FWD, just make the rear as stiff as possible. A ghetto trick you can do is take 2 footballs, take the air out, put them inside the springs, and then air them up. This will help stiffen the rear end up a bit. Also, adjustable shocks and just set them as stiff as they'll go. For the front suspension, you want it somewhat moderate stiffness. Too stiff of a front suspension can be just as bad as being too soft. I will be adding suspension limiters on my Focus when I do the tubular control arms to help the front end from leaping up so bad.
Here's a video from a couple years ago. The track prep that night sucked (It's crapitol dragway, shouldn't expect more) and as the night went on, the track got colder and colder and I was spinning worse and worse no matter how much heat I put in the tires. I had gotten in the 12.9s earlier in the evening but on these last two runs of the night, I was spinning the slicks pretty bad.
YouTube Video
Old 03-30-2012, 03:16 PM   #135
AllOutZX2
AllOutZX2's Avatar
Fan#: 80930
I've actually seen that football trick in a Cobalt SS/TC. A guy I run with was having some traction issues and did what you described, helped him out. but that was a low 12 high 11 second car.
Shawn
Old 04-01-2012, 02:19 AM   #136
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
Two footballs isn't that much cheaper than the purpose built airbags.
elsolo is offline
Old 04-11-2012, 04:49 AM   #137
DoomsdayFAN
DoomsdayFAN's Avatar
Fan#: 92019
What I Drive: ~2006 ZX4 SE Sedan 2.0L~
FF Reputation: 1 DoomsdayFAN Good Standing Member
When you do the football thing, is there a specific spot in the springs you should fit them into? Do you do this just to the rear end on a FWD car, or on both front and rear?
DoomsdayFAN is offline
Old 04-11-2012, 09:38 PM   #138
bespurcell
bespurcell's Avatar
Fan#: 60917
What I Drive: 2003 black svt
FF Reputation: 2 bespurcell Good Standing Member
Just the rear.
Dominant Eng. orp, ITG Maxogen panel filter, Focus-Power tune, Team Dynamic Pro Race 2 16x7 wheels in black(36 lb weight reduction from stock tire/wheel combo)
bespurcell is offline
Old 04-24-2012, 11:13 AM   #139
Royce01
Royce01's Avatar
Fan#: 93858
What I Drive: 2002 focus se toredor red
Points 960, Level 16
Points: 960, Level: 16 Points: 960, Level: 16 Points: 960, Level: 16
Level Up 60% Completed
FF Reputation: 1 Royce01 Good Standing Member
I ran my time on this side road by my apt. I estamated a 1/4 mile as accurated as i could with my odometer. I did like 16.6 @ 84mph with overdrive on. when i turned it off I took almost a whole second off my time.
15.84 @ 93mph. but remember I'm not sure how accurate it was so there may be a significant difference if I had a chance to take it on a real dragstrip.
these are the parts i had when i did it.
1) magnaflow exhaust and high flow cat.
2) spectre high flow cone filter
3) sport aluminum radiator
4) lightweight battery (not the optima)
5) just had the transmission rebuilt a week before I tested my 1/4 mile time.(may have made a difference)
a $15,000 honda and a $500 exhaust doesn't make you a street racer!
Sedan Revolution #223
Rally Revolution #223
132bhp 147ft/lb tq
Royce01 is online now
Old 04-24-2012, 06:26 PM   #140
LD5050
LD5050's Avatar
Fan#: 94329
What I Drive: 04 SVTF
FF Reputation: 1 LD5050 Good Standing Member
can't wait to see what my car will do.
Still need 67mm TB, quaiffe diff, and stiff rear suspension.
2004 SVT ZX3 Black
LD5050 is offline
Similar Threads
Terrible 1/4 mile times in my SVT Silver Cosworth SVT Performance (2002-2004) 43 01-03-2012 01:54 AM
1/4 times for the jrsc+bbk kharazmatik General Forced Induction 11 05-10-2006 05:57 PM
stock 1/4 mile times, where to shift ZX3Driver ZETEC Performance (2000-2004) 48 06-25-2005 04:26 PM
0-60 - 1/4 mile times for a wide range of cars Goat Roper Autocross Racing 15 05-06-2005 10:42 AM
1/4 Mile Times..... HaveBlue83 ZETEC Performance (2000-2004) 31 01-07-2004 01:04 AM
