Go Back   Focus Fanatics > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 03-25-2012, 07:10 PM   #101
AllOutZX2
AllOutZX2's Avatar
Fan#: 80930
What I Drive: 1998 Ford Escort ZX2
FF Reputation: 1 AllOutZX2 Good Standing Member
Originally Posted by DoomsdayFAN View Post
Let me ask you this... what is harder on your car overall: Flashing vs Power Breaking?
I seem to get pretty good thrust off the line when launching at 2k RPMs, but I get some tire spin when doing that. I've never tried flashing it, but maybe I'll give it a go. It just seems like it might be more of a shock to the system and that's what worries me. LOL, I know I'm being hard on it to begin with when doing this stuff either way but I'd still like to choose the lesser of two evils whenever possible.
Is it bad for your tires to run less air in them than is recommended? Like, I figure on track day, I let air out right before I go, then when I'm done, I'll stop by the nearest gas station and fill them back up. Hopefully that doesn't kill my tires.
Otherwise, random video.... why are these guys SO slow. The Focus is insanely slow, and for a Turbo, the Honda Element isn't much better. With just my CAI, I bet I could beat both of them and get a better time.
Focus Sedan vs Honda Element (Turbo)
(Skip to 0:30 for the race)
YouTube Video
Flashing shocks the converter and the driveterrain but not nearly as hard as a manual transmission. I recommend upgraded motor mounts.
Power Braking means increasing the transmission fluid temperature while you sit on the gas and brake.
I have over 45 passes on my set-up and I know Flashing the converter equals a faster 60ft time traction permitting.
For those videos, do you know if these are being recorded in a high altitude track? Also the Focus driver misses a shift pretty good.
Shawn
Full Bolt-On's, SCT VCT Tuned ECU, 3500rpm Edge Racing Stall, 205/60R13 M&H D.O.T Street Slicks
AllOutZX2 is offline
Old 03-25-2012, 07:23 PM   #102
blindreap3r
Fan#: 73709
What I Drive: 2008 S Coupe
FF Reputation: 1 blindreap3r Good Standing Member
2008 2dr focus 216whp/226ftlbs
stock motor, stock intake manifold, open diff, cm fx300, 17x7 wheels w/ 215/40 neo gens
fswerks stage 2 @ 11PSI GT28r, fswerks 2.5" exhaust w/ high flow cat
13.84 @ 124MPH
new times coming built motor, top speed turbo kit gtx3071r turbo 500+ whp
2008 Ford Focus S
13.84 @104 MPH
blindreap3r is offline
Old 03-25-2012, 08:20 PM   #103
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
What exactly is there to know about driving an ATX? I thought it was as simple as stomping on the gas and going?
I know what power braking is, but what exactly is "flashing"? Is that where you just stomp on the pedal at green, instead of power breaking and launching?
flashing is for flash the ecu with the xcal
I think I have about 35psi in my tires now. What's wrong with more air in the tires? How does less air help?
with less air is gonna be alittle bit more flat so is gonna have more grip
cossie im, ta technix coilovers, cfm 67mm tb, 3" exhaust and custom turbo kit with holset hx35 turbo comming very soon ;)
team duratec #94
D23 crew #9
koke'sfocus is offline
Old 03-25-2012, 08:34 PM   #104
Bwinkelsas
Bwinkelsas's Avatar
Fan#: 50224
What I Drive: 2007, Screaming Yellow, ZX3 SES
FF Reputation: 2 Bwinkelsas Good Standing Member
13.84 @ 124MPH
im going to guess you meant 104mph?
1.706 / 7.720@91.13 / 12.381@96.84 letting off.
Stock Motor, why hate on the 2.0?
More power and new numbers to come soon...
Bwinkelsas is offline
Old 03-25-2012, 08:43 PM   #105
Bwinkelsas
Bwinkelsas's Avatar
Fan#: 50224
Originally Posted by AllOutZX2 View Post
Oh there is a big difference in street tires when it comes to air pressure. If track prep is not correct you really need to rely on the correct air pressure to get your 60ft down. First time I ran at the track I burnt the entire 1st gear and halfway into 2nd gear in my automatic. 35PSI, the old school guys laughed and told me to drop it by 10 psi then keep going down till it hooked. I usually run 23 psi in my tires seems to work well.
Even with street radials when you drop the pressure you see the sidewall start to bulge and get soft, to me that's an advantage. It may be not the wrinkle sidewall that bias ply slicks give but it's still another advantage.
i suppose with a more consistant auto it is more easy to figure out what works, when i used to use street tires, could never prove anything to change by playing with the psi, went to slicks and gave up on street tires lol what a difference...
Old 03-25-2012, 11:37 PM   #106
ThatOneFocusGuy
I <3 Plasti Dip
ThatOneFocusGuy's Avatar
Fan#: 59087
What I Drive: 00 Kona ZX3, 02 ZX3, 13 ST3
FF Reputation: 7 ThatOneFocusGuy Good Standing Member
Buy-Sell-Trade Rating: (27)
2000 ZX3 Kona 14.555 @ 94.65mph, 2.222 60 ft
Automatic with JRSC, 2.4'' S/C pulley, header 2.5'', exhaust 2.25'', short ram intake
172whp 145 wtq
Hopefully run a high 13 after I make a 3'' intake and buy a 3'' exhaust. Also put on my sticky Hankooks.
FocusFactor FocusXtreme
CincySCCA ST '10, SMF '11, EP '12 Champ
CincySCCA #54 EP
ThatOneFocusGuy is offline
Old 03-26-2012, 02:45 AM   #107
DoomsdayFAN
DoomsdayFAN's Avatar
Fan#: 92019
What I Drive: ~2006 ZX4 SE Sedan 2.0L~
FF Reputation: 1 DoomsdayFAN Good Standing Member
I have the CFM Lower Engine Torque Mount (Race Version) with me, I just need to install it. How much will this help?
So then you recommend that instead of power breaking, I just sit with my left foot on the brake, and my right hovering above the gas, and right as the light turns green, I let off the brake and simultaniously STOMP on the gas? I'll certainly try it, but it sound dangerous, as far as hurting the car. I'll take your word, but it still just sounds like it would be putting a massive strain on the car, even more than power braking.
As for the lower tire pressure, I'll certainly drop my two front tires down to 25 PSI and see how that works. I just hope it doesn't hurt my tires, as in, aren't they more protected when at 35 PSI?
Of the Focus vs Element? I have no idea. It was just a random video I found. Of the Ricers, I was there that night (Type R vs Red Ricer & Type R vs Corvette) Those were not at high altitude; only at a 495 foot elevation.
I thought the Focus in that vid was an ATX?
DoomsdayFAN is offline
Old 03-26-2012, 04:46 PM   #108
AllOutZX2
AllOutZX2's Avatar
Fan#: 80930
Stiff engine mounts keep the driveterrain from flopping around, they also keep wheel hop down, they also improve traction.
As with anything if your worried about hurting your car you should leave it in the spectator area. Please don't take it the wrong way just Drag Racing to some degree isn't easy on a car but it's no different then your average street racer pounding the shit out of his car from stop light to stop light and admit it you've done it... everyone has.
Shawn
Old 03-26-2012, 07:19 PM   #109
DoomsdayFAN
Fan#: 92019
Well, I'm keeping my figures crossed that assuming I get a near-perfect launch with these mods:
CAI
67mm TB
4-1 Race header
2.5 Flex
Stealth Exhaust
Tune
Empty Car (take out the spare tire/jack/tools/etc)
25 PSI in the front tires
Flashing (during the launch)
...that I'll be able to run at least somewhere in the mid-15s.
Old 03-27-2012, 01:41 AM   #110
GreenEnvy
Late for Dinner
Fan#: 8529
What I Drive: 13 stang, 02 svtf
FF Reputation: 90 GreenEnvy Excellent Standing Member
power braking... you don't do that at the lights...maybe in the burnout box
YouTube Video
brake-torquing... you do do this at the lights.
You;ll need to practice and find the cars sweetspot.
This is used to load the torque converter, trans, and driveline before launching. Do not load before the lights start dropping, the longer you do, the hotter the tranny gets. light hits let loose and throttle it. you want the torque converter to flash over just after you throttle it. you'll know when your launching at the right rpm as you should get some slight tire squeel with street tires, keep throttling it and let them grab. If you get wheelhop, get out of the throttle immediately and let the race go, its not worth breaking the car to try to win something you've pretty much lost already. If your tires break loose back of and get right back into it. Don't try to push through the burnout, you'll lose more time than backing out and getting back into it.
Also a tip I don't see anyone telling you, don't pull up to the light in the track everyone is using, its plenty wide to launch with your tires slightly out of the tracks where the tac isnt worn off.
YouTube Video
Oh, and please explain how your supposedly flashing a converter with the method you described
If Guns Cause Crime, Mine Must Be Defective
GreenEnvy is offline
Similar Threads
Terrible 1/4 mile times in my SVT Silver Cosworth SVT Performance (2002-2004) 43 01-03-2012 12:54 AM
1/4 times for the jrsc+bbk kharazmatik General Forced Induction 11 05-10-2006 04:57 PM
stock 1/4 mile times, where to shift ZX3Driver ZETEC Performance (2000-2004) 48 06-25-2005 03:26 PM
0-60 - 1/4 mile times for a wide range of cars Goat Roper Autocross Racing 15 05-06-2005 09:42 AM
1/4 Mile Times..... HaveBlue83 ZETEC Performance (2000-2004) 31 01-07-2004 12:04 AM
