Fan blower making noise~~ - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-04-2013, 01:25 AM   #21
silver9
Fan#: 106650
What I Drive: 04 silver focus zts
FF Reputation: 1 silver9 Good Standing Member
i just wanted to say thanks to gondorian Tri-Flon is awesome. I use this stuff on everything!!!
silver9 is offline
Old 01-27-2013, 05:27 PM   #22
grand106
Fan#: 82925
What I Drive: 2009 focus 1,6 5d
FF Reputation: 1 grand106 Good Standing Member
i just want to ask one thing? How on earth did you all manage to squeeze your hand to remove those 3 screws (torx type they are, at least in my focus ii (late 2008 model)
I try using a flexible extension fitted with a torx end with an electric screwdriver but yet again I can’t even see the 2 out of 3 screws yet alone to even consider removing them . (I feel that if I try that –in blind- by feeling with the edge of my fingers most probably the screws should be lost inside the engine’s abyss). i also have Haynes manual to help me but …
grand106 is offline
Old 01-28-2013, 12:22 AM   #23
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,772, Level 73
Points: 12,772, Level: 73 Points: 12,772, Level: 73 Points: 12,772, Level: 73
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 99%
I reached up from underneath, primarily by "feel" 'cause I didn't feel like diving upside down under the dash if I didn't have to!
Used a torx bit in a 1/4" socket at the end of a 6" extension (1/4" drive). Handle to break loose, fingers on extension to run in & out.....
Worked fairly easily that way. Do the back one first (hardest to get at), since the others will hold the fan in place while you get the hard one out. put it in last on re-assembly....
Luck!
sailor is online now
Old 01-28-2013, 03:09 AM   #24
grand106
Fan#: 82925
Much appreciated, because I thought I might be doing something wrong (it felt too difficult to be the correct way)
p.s If I dive upside down I then have to repair passenger’s seat afterwards . then to another thread and the story goes on
thanks again , i will try it again soon
grand106 is offline
Old 01-31-2013, 03:27 PM   #25
Aaron1331
Fan#: 104593
What I Drive: 2003 Black SVT
Points 261, Level 5
Points: 261, Level: 5 Points: 261, Level: 5 Points: 261, Level: 5
Level Up 22% Completed
FF Reputation: 1 Aaron1331 Good Standing Member
mine does this buy only when braking and on fan speed 2 and 1
Aaron1331 is offline
Old 01-31-2013, 04:31 PM   #26
josephd
josephd's Avatar
Fan#: 84356
What I Drive: 2007 SE Dark Toreador Red Pearl
FF Reputation: 1 josephd Good Standing Member
My fan does the same thing. It does it when in motion, and sitting still. When it gets cold, the low speed(#1)makes noise. If I put it on the second speed it goes away.
josephd is offline
Old 01-31-2013, 05:17 PM   #27
Joelnaf
Joelnaf's Avatar
Fan#: 93167
What I Drive: 2003 Silver ZX5 SVT
FF Reputation: 1 Joelnaf Good Standing Member
Very common for it to do this at low speeds or when breaking turning etc.... just remove the fan like shown above then blow it out with a compressor. Oil up the two copper bearings top and bottom of the fan shaft. Sound will go away.
Joelnaf is offline
Old 04-09-2013, 09:33 PM   #28
Oblivion
Fan#: 92148
What I Drive: 2001 Blue ZX3
FF Reputation: 3 Oblivion Good Standing Member
Originally Posted by iB Chunkyboy View Post
Pics don't work :[ help please
Hello, iB Chunkyboy.
If 'pics don't work': How about a video instead?
Here. I made this just now specifically because I saw your post.
This is for the 2001 Ford Focus ZX3 model though. I'm unsure if the 2000 version is any different.
Video link: http://www.youtube.com/watch?v=0XM7okhkpXg
YouTube Video
Hope that helps you out. Sorry for the poor lightning quality. It went pitch black out here.
Now I have to reinstall it without seeing too much!
Oblivion is offline
Old 11-25-2013, 10:44 AM   #29
Todd GT5
Todd GT5's Avatar
Fan#: 119268
What I Drive: 2002, Black ZX5 and 2000 Subaru OB
Points 11, Level 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
Level Up 21% Completed
FF Reputation: 1 Todd GT5 Good Standing Member
Fixed fan noise!!
Hello all,
Thanks to this thread, I have successfully fixed my fan noise.
Thanks
-Todd
Todd GT5 is offline
Old 11-24-2014, 02:30 PM   #30
pfsantos
Fan#: 125113
What I Drive: 2009 Silver SES
Points 703, Level 14
Points: 703, Level: 14 Points: 703, Level: 14 Points: 703, Level: 14
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
FF Reputation: 1 pfsantos Good Standing Member
On my 2009, the three screws to remove the fan were accessible. Nothing else to remove beforehand.
But to get to the bottom bearing, I had a bit of a hard time removing the bottom cover, which has wires attached to the plug, which is part of the bottom cover. So it's easier to drill a hole in the middle of the round part on the cover, lube the bearing, then cover with black electrical tape.
Paulo - '09 SES Silver
pfsantos is online now
Similar Threads
'00 - '03 Ford Focus Fan Wiring Durango_Boy General Technical Chat 6 11-03-2007 01:42 PM
fan switch or blower relay needin help General Technical Chat 4 08-09-2004 01:07 AM
A/C & blower motor problem....HELP, I'm burning up! BlownSkillet General Technical Chat 10 07-07-2004 07:07 AM
2000 focus blower fan location needed guest General Technical Chat 3 07-06-2004 10:56 PM
Volant Scoop or boat blower microtonal Ford Focus & General Car Chat 4 05-11-2004 05:05 PM
