#1 | ||||
Fan blower making noise~~
Ok, Ford had previously replace my fan blower (for the interior) once and now is making noise again during cold weather days.....
Now, being out of warranty, need to replace this myself... Anyone know of a site with instruction in performing this?
Vintage 2000 Focus SE Sport Wagon (Canadian Version) Goodyear Assurance Triple Tred P195/60R15 |
Remove Advertisements |
Fan#: 1
#2 | ||||
are you sure you need to replace it? usually leaves get stuck in blower motors making a noise, and gets worse the faster you put the speed.
I havent done one on a focus but usually their pretty straight forward.
228whp 216wtq 05 Zx3 2.0 Duratec w/CP Pistons, K1 H-Beam Rods,HiBoost Turbo kit w/Focus Sport tuning @7 psi, 3" Magnaflow flex-back exhaust w/Carsound cat,F2 Flywheel,Exedy organic,VF dogbone,Koni dampers |
#3 | ||||
Moderator
Agreed^^^ Make sure the blower didn't just suck something in like a leaf. I have had it happen before.
#4 | ||||
sorry, i mean the fan for our a/c and heater, the one that is use for our interior...
#5 | ||||
Yeah I know. The interior a/c blower motor can get leaves in them.
#6 | ||||
Oh... so how do I access it and clean it?
#7 | ||||
the motor should be under the glove box, remove the glove box and see if you can access the motor there.
Currently cruising with: AEM CAI. Shorty header. FC HF Cat. CatBack 2.25" & Flex. FC UDP's. Euro Upper and Lower grill and clear corners. Halo Headlights. Tune by Turbo Tom. SVT Struts, Eibach Springs. Ported TB. Television. Rules the Nation. |
#8 | ||||
I had the same problem. The fix is relatively easy. Open the glove box and remove the hinge screws, This will give you access to the blower motor. Disconnect the electrical plug to it and then undo the three screws. The bearings are sealed but with care and a little lubrication sprayed sparingly into each end the problem is corrected. I would recommend using G-96 lubricant (available at gunshops) instead of the ubiquitous WD 40 as it does not freeze up at -30c. I would also recommend purchasing a Haynes manual, it shows this and many other procedures listed in these forums. Well worth the money.
#9 | ||||
My blower is also making a very annoying noise. I tried opening the blower motor but I could not find the screws to unscrew Does anyone have a diagram or a picture to help? Thanks!
#10 | ||||
I have tried to live with this noise since I got my car (6 months ago).. but if anyone can help, it will be great! =)
Previous car: 2002 Liquid Grey Focus ZX3 - Falken Torque 5, 18" Gunmetal - Yokohama parada Spec II Performance tires - Roush cat-back Exhaust & Magnaflow Resonator |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| '00 - '03 Ford Focus Fan Wiring | Durango_Boy | General Technical Chat | 6 | 11-03-2007 12:42 PM |
| fan switch or blower relay | needin help | General Technical Chat | 4 | 08-09-2004 12:07 AM |
| A/C & blower motor problem....HELP, I'm burning up! | BlownSkillet | General Technical Chat | 10 | 07-07-2004 06:07 AM |
| 2000 focus blower fan location needed | guest | General Technical Chat | 3 | 07-06-2004 09:56 PM |
| Volant Scoop or boat blower | microtonal | Ford Focus & General Car Chat | 4 | 05-11-2004 04:05 PM |
