Jacking points diagram - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-12-2008, 10:20 AM   #1
nacnudv8
nacnudv8's Avatar
Fan#: 52725
What I Drive: former owner:Pitch Black '03 SVT 3D
FF Reputation: 7 nacnudv8 Good Standing Member
Some of you may have noticed that the links in the HOW TO on this subject a broken (it links to an external site I think) as you can see here:
http://www.teamfocus.us/jacking.htm
http://www.teamfocus.us/lifting.htm
So that we still have that information in the interim (as the MODS see fit) - here is the Jacking Point the diagram and text from the Ford Manual:
Jacking Points:
WARNING: Always position the vehicle on a hard level surface. If the vehicle must be jacked up on a soft surface use load spreading blocks under the jack. Always use a chock at the wheel diagonally opposite the jack. Failure to follow these instructions may result in personal injury.
CAUTION: It is not recommended that the vehicle is jacked or lifted on the rear suspension crossmember. If the vehicle must be lifted on the crossmember, make sure that the jack or lift is positioned centrally. Failure to follow these instructions will result in deformation of the closing plate which will weaken the crossmember.
Before commencing any repairs that involve jacking the vehicle, it is essential that the following instructions are fully understood.
It is important that only the correct jacking and support locations are used at all times.
The vehicle may be lifted by positioning a floor jack under the outer rocker panel and supported by vehicle axle stands. The location is identified behind a removable cover (if equipped), a notch in the outer rocker panel indicates where the jack should be positioned. Use a cushioned pad, if possible, to avoid damaging body paint.
nacnudv8 is offline
Similar Threads
Focus Fanatics Extreme Autocross Challenge - FAQ Tom Autocross Racing 64 05-16-2008 05:04 PM
proper jacking points for doing suspension??? socrates General Technical Chat 3 06-09-2007 01:41 PM
Accessing jacking points FocusOhFive Wheels & Tires 9 10-14-2006 10:50 PM
Jacking points Rudejake SVT Performance (2002-2004) 2 06-24-2004 09:31 PM
