AWD Zetec/SVT Focus INFO thread - Page 14 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 02-27-2008, 03:18 PM   #131
Bvtt_Whiper
Fan#: 52341
What I Drive: 2005, Blazing copper, focus.
FF Reputation: 1 Bvtt_Whiper Good Standing Member
Originally Posted by hurtinfocus View Post
SUMMARY:
The jaguar transmission cannot be used on a zetec 4cyl, the input shaft is too large in diameter, and cannot be swapped out becuase of the extra parts inside the case to run the transfer case. UNLESS you take it out and have the shaft machined to match the focus transmission's input shaft.
The transfer case seems eaily adaptable to the focus transmission by making a custom "adaptor shaft"....something about the size of a household toilet paper tube which would have the splines/diameter of the stock axle on one end to mount into the transmission output port, and on the other side have the splines/diameter for the input side of the transfer case. Then you shorten the passenger axle.
The front subframe has to be cut in half and the center "boxed out" to fit a driveshaft through.
The rear either has to be a completely custom subframe, an escape modified subframe, or a cobra IRS cutom mounted. All of which require removal of the gas tank and spare tire well in the floor pan. Also all require adapting mounts for the jaguar rear differential because it spins "reverse" to conventional rear diffs.....
The only way to use a jag transmission is to use the 2.5 or 3.0 v6 as well.
Just machine the input shaft
Bvtt_Whiper is offline
Old 03-19-2008, 12:07 PM   #132
dootdodoodledodo
dootdodoodledodo's Avatar
Fan#: 50580
What I Drive: 2000 Dark Blue ZX3
FF Reputation: 1 dootdodoodledodo Good Standing Member
Didn't feel like skimming 11 pages, so I hope thins like isn't a dup and it is of some help. I really want to see this be done so here...
http://www.performancefordmag.com/fo...67&whichpage=2
dootdodoodledodo is offline
Old 03-19-2008, 12:50 PM   #133
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,295, Level 67
Points: 10,295, Level: 67 Points: 10,295, Level: 67 Points: 10,295, Level: 67
Level Up 62% Completed
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
i beleive the MTX75 awd used in the jag are left-over mondeo 4x4 units........so if thats the case all of that info is redundant to this thread.
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is offline
Old 05-29-2008, 03:11 PM   #134
rolla711
rolla711's Avatar
Fan#: 55205
What I Drive: 2003 Yellow ZX3
FF Reputation: 5 rolla711 Good Standing Member
i dont want to see this tread die out......
if you were to machine the input shaft then you would be able to use the jag trans?
also if tha be the case, what would you have to do to mount it all up?
and if you need any info from alldata i can get it for you.....
rolla711 is offline
Old 05-30-2008, 03:52 PM   #135
hurtinfocus
Fan#: 835
theoretically, yes.....you could remove the input shaft from the jag trans and have it machined to fit the zetec motor. the mounting of the trans to the motor should be no different. the only possible problem is clearing the steering rack/exhaust tunnel.
Old 06-02-2008, 03:07 PM   #136
rolla711
rolla711's Avatar
Fan#: 55205
how much clearance would you need for the driveshaft to clear the steering rack
rolla711 is offline
Old 06-02-2008, 06:58 PM   #137
silvermist
silvermist's Avatar
Fan#: 11184
What I Drive: 2001,bright atlantic blue,zx3
FF Reputation: 1 silvermist Good Standing Member
has anyone thought about using the set up out of a awd fusion, will it work for the focus( oviously you'd have to trim the axles to work or find ones that will work) I was thinking about it the other day as I was driving behind a fusion. and I'd like to know if you could use the fusion fuel cell so you don't have to put a fuel cell in your trunk and completely lose the trunk or hatch.
silvermist is offline
Old 06-04-2008, 03:46 PM   #138
rolla711
rolla711's Avatar
Fan#: 55205
but what tranny does it you
rolla711 is offline
Old 06-04-2008, 07:11 PM   #139
coolio
Fan#: 56581
What I Drive: Montero
FF Reputation: 1 coolio Good Standing Member
Hi guys, I don't own a focus or anything, but I'm a major lurker on theses forums.
I really like to read about people's foci and see the progress on builds and such. I almost did get a focus on numerous occasions, but somehow i just ended up with my Monty.
aaaaanyways
I just wanted to join to post that my mom has a courtesy car from jaguar right now, and it's an AWD X-type. If you guys need me to take any measurements or pictures, I'd be glad to help.
(I'm willing to climb under it and everything)
coolio is offline
Old 06-04-2008, 07:25 PM   #140
rolla711
rolla711's Avatar
Fan#: 55205
sweet, i cant remember wat orangesvt wanted but i would say take a pic of the whole underside lol mainly the axle and i guess measure from hub to rub on the rear axle
rolla711 is offline
Similar Threads
Focus Competition Tires: Info, Links, and Reviews Oni Wheels & Tires 16 04-22-2008 10:46 PM
Need info on SVT Focus Cdn Warranty and advice about extended warranty info pls tanya_03svt Focus SVT 0 06-25-2007 06:35 PM
AWD Focus? ZX3 Jon Ford Focus & General Car Chat 12 06-13-2006 01:03 AM
6-SPD AWD in your FOCUS!? SVTF0416 Ford Focus & General Car Chat 14 03-23-2006 03:19 AM
