AWD Zetec/SVT Focus INFO thread - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 02-24-2008, 03:57 AM   #121
Bvtt_Whiper
Fan#: 52341
What I Drive: 2005, Blazing copper, focus.
FF Reputation: 1 Bvtt_Whiper Good Standing Member
And what gear ratio would that be?
Bvtt_Whiper is offline
Old 02-24-2008, 12:39 PM   #122
sqrly
sqrly's Avatar
Fan#: 22581
What I Drive: 2008 white coupe s
Points 2,757, Level 32
Points: 2,757, Level: 32 Points: 2,757, Level: 32 Points: 2,757, Level: 32
Level Up 5% Completed
FF Reputation: 3 sqrly Good Standing Member
Buy-Sell-Trade Rating: (4)
john try www.car-parts.com it is a compilation of junk yards across the US and you could see if anything is close to you hope this helps.
Zetec Crew #136
Xbox Live: SqrlyZX3
sqrly is offline
Old 02-24-2008, 01:20 PM   #123
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,045, Level 66
Points: 10,045, Level: 66 Points: 10,045, Level: 66 Points: 10,045, Level: 66
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 4%
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
well......for the MTX75..........there is really only two options, and one of them i dont even know if it is possible.
there are no 3.82 gearsets available for a 8.8 rear end. there IS one for the 9" rear end.
http://store.summitracing.com/egnsea...115+4294776274
now the other thing is that the cobra rear IRS has nearly identical moutning points to the 8.8 rear.......so that shouldnt be too bad to mount to the focus, as it was in that picture on page 4 i think
the cobra rear IRS is a 8.8
sucks for me. now the other option i was speaking of is to see if a custom gearset could be made for 3.82 for the 8.8
then i would be all set.
i would use the cobra IRS with a 3.82 and be golden.
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is online now
Old 02-24-2008, 01:35 PM   #124
Bvtt_Whiper
Fan#: 52341
uhhh.. you have to figure out what gear ratio accomplishes a 1:1 ratio. Where a complte axle turn = a complete wheel turn. It has nothing to do with the final drive of the focus transmission.
Old 02-24-2008, 03:10 PM   #125
uk-v8-focus
Fan#: 18104
What I Drive: Various
FF Reputation: 6 uk-v8-focus Good Standing Member
If all the previous information is correct;
Input to Transfer box is the same speed as to the front right wheel.
The Transfer box has no reduction (1:1).
Then you cannot use a conventional reduction diff as used on 8.8.
You can only use the Jag rear end, which will be 1:1, same speed in as speed out.
If you also look at my earlier post, the transfer box output to the rear turns the opposite way to a normal trans output, so the Jag rear IS the only one you can use.
(The system, branded "Traction-4" by Jaguar, utilises a unique Visteon design that drives the rear differential "backwards." )
Stuart
uk-v8-focus is offline
Old 02-25-2008, 04:32 AM   #126
Bvtt_Whiper
Fan#: 52341
So? Cryo treat a jag rear diff and get custom axles.
Old 02-25-2008, 09:23 AM   #127
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
Well, my AWD Focus plans just got put on hold for a couple of months.....
I ran across a GREAT deal on a LOW milage 1996 MYSTIC SVT Cobra that I just couldn't pass up.... and the modding has already began on it.
Once I get the Cobra the way i want it in a month or two I'll actually START the AWD Fofo project... plus it'll be warmer out in the shop by then.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 02-25-2008, 09:50 AM   #128
Bvtt_Whiper
Fan#: 52341
well you dont want to rush it anyway. proper planning time is important
Old 02-27-2008, 07:21 AM   #129
y2kc0wb0y
y2kc0wb0y's Avatar
Fan#: 28314
What I Drive: 2010 Colnago CX-1
FF Reputation: 2 y2kc0wb0y Good Standing Member
Buy-Sell-Trade Rating: (7)
Cool Summary?
Can someone post a summary of what is known? With or without opinion of what the final drive ratio should be is fine. Did we confirm the JaGX transfer case bellhousing etc....
Thanks-
I don't care what you drive as long as you take care of it. As for me, I have no car so I'm only worried about taking care of myself.
y2kc0wb0y is offline
Old 02-27-2008, 09:32 AM   #130
hurtinfocus
Fan#: 835
Forum Activity 4%
SUMMARY:
The jaguar transmission cannot be used on a zetec 4cyl, the input shaft is too large in diameter, and cannot be swapped out becuase of the extra parts inside the case to run the transfer case. UNLESS you take it out and have the shaft machined to match the focus transmission's input shaft.
The transfer case seems eaily adaptable to the focus transmission by making a custom "adaptor shaft"....something about the size of a household toilet paper tube which would have the splines/diameter of the stock axle on one end to mount into the transmission output port, and on the other side have the splines/diameter for the input side of the transfer case. Then you shorten the passenger axle.
The front subframe has to be cut in half and the center "boxed out" to fit a driveshaft through.
The rear either has to be a completely custom subframe, an escape modified subframe, or a cobra IRS cutom mounted. All of which require removal of the gas tank and spare tire well in the floor pan. Also all require adapting mounts for the jaguar rear differential because it spins "reverse" to conventional rear diffs.....
The only way to use a jag transmission is to use the 2.5 or 3.0 v6 as well.
Similar Threads
Focus Competition Tires: Info, Links, and Reviews Oni Wheels & Tires - Sponsored By Tire Rack 16 04-22-2008 10:46 PM
Need info on SVT Focus Cdn Warranty and advice about extended warranty info pls tanya_03svt Focus SVT 0 06-25-2007 06:35 PM
AWD Focus? ZX3 Jon Ford Focus & General Car Chat 12 06-13-2006 01:03 AM
6-SPD AWD in your FOCUS!? SVTF0416 Ford Focus & General Car Chat 14 03-23-2006 03:19 AM
