AWD Zetec/SVT Focus INFO thread - Page 11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 02-21-2008, 03:53 PM   #101
uk-v8-focus
Fan#: 18104
What I Drive: Various
FF Reputation: 6 uk-v8-focus Good Standing Member
Jag Drivetrain
X Tpe rear
Stuart
uk-v8-focus is offline
Old 02-21-2008, 04:45 PM   #102
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
Originally Posted by hurtinfocus View Post
^ because the front and rear have to have the correct ratios with the transfer case or it will not work properly
I was refering to changing out the ring and pinion in the rear axle to match the front.... becuase it would be easier and cheaper than to do the gearing in the transaxle.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 02-21-2008, 10:50 PM   #103
Bvtt_Whiper
Fan#: 52341
What I Drive: 2005, Blazing copper, focus.
FF Reputation: 1 Bvtt_Whiper Good Standing Member
Just copy the Jaguar ratios. Problem solved.
Bvtt_Whiper is offline
Old 02-22-2008, 12:50 AM   #104
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Wouldn't having twin layshafts with two final-drive ratios in the transmission cause problems with this?
SkaAddict is offline
Old 02-22-2008, 09:02 AM   #105
Bvtt_Whiper
Fan#: 52341
Jag board responce..
"transfer case has no ratio...
like I said the tranfer case output is the same rpm as the transmision output... what you need to do is make sure the front and rear diff have the EXACT same ratio as each other.
now what are you doing with this car? If you want acceleration, pick a big ratio, if you want highway peace and quiet.. a smaller one"
Old 02-22-2008, 01:11 PM   #106
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,295, Level 67
Points: 10,295, Level: 67 Points: 10,295, Level: 67 Points: 10,295, Level: 67
Level Up 62% Completed
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
ok, so what we would have to do is make the existing final drive ratio of the focus set equal to the 40%, and figure out what the 60% in relation to that WOULD be for the proper rear split?
If this is the case, then the rear would need a 5.73 gear ratio.....which doesnt seem right
or is the guy saying that the two ratios must be equal and the transfer case is what sets them to the 40/60?
im thinking the latter is the case, meaning a 3.82 is needed in the rear for an MTX-75
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is online now
Old 02-22-2008, 01:22 PM   #107
hurtinfocus
Fan#: 835
for *&giggles......do they list the ratios of the jag trans final drive and of the jag rear diff?
Old 02-22-2008, 01:28 PM   #108
hurtinfocus
Fan#: 835
http://forums.roadfly.com/forums/jag...type/forum.php
Old 02-22-2008, 01:44 PM   #109
hurtinfocus
Fan#: 835
this is all i have been able to find so far......but it seems wrong for some reason:
"Yes, the final drive ratio can be determined from the posted information. Both the 2.5 and the 3.0 auto and manual have a drivetrain ratio (normally called rear end ratio on RWD's) of 2.53 to 1. The actual final drive ratio which takes into the overdrive ratio of the transmission and tire radius for the auto is 2.66 to 1 and the manual is 2.92 to 1.
As long as there is no slip in the transmissions or clutches (yes the auto has a clutch also) you can use the same ratio of speed to rpm and get to the rpm in high gear for any speed.
Does this mean that the auto has a higher top speed than a manual? Yes and no. If they both had unlimited HP the auto could go faster. With the same HP the manual will be faster due to the lower gearing allowing the motor to rev higher producing more HP. Also the auto will have greater friction losses in the transmission reducing available HP."
Old 02-22-2008, 03:02 PM   #110
Bvtt_Whiper
Fan#: 52341
If you had a 4.06 final drive you use the same exact ratio in the rear diff
If you wanted more rear bias I would assume a taller setting in the rear diff so it spins faster.
Similar Threads
Focus Competition Tires: Info, Links, and Reviews Oni Wheels & Tires 16 04-22-2008 10:46 PM
Need info on SVT Focus Cdn Warranty and advice about extended warranty info pls tanya_03svt Focus SVT 0 06-25-2007 06:35 PM
AWD Focus? ZX3 Jon Ford Focus & General Car Chat 12 06-13-2006 01:03 AM
6-SPD AWD in your FOCUS!? SVTF0416 Ford Focus & General Car Chat 14 03-23-2006 03:19 AM
