Read First: Selecting the Best Tires for YOU - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-02-2008, 02:32 PM   #11
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
sweet. a good tire writeup.
now if you can help me with my auto-x wheel tire combo.
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 10-02-2008, 02:41 PM   #12
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Didn't look real hard, did we.
Here you go:
Buying dedicated autocross wheels, what size?
autocross wheel tire combination question
tires for autocross
Is this a good wheel/tire choice for G stock/STN
Tire recommendations for stock 16" wheels for autocross
WD40 is offline
Old 02-08-2009, 07:54 AM   #13
potatoman01
Fan#: 61577
What I Drive: 2003 yellow zx3
FF Reputation: 1 potatoman01 Good Standing Member
good advise,while speed ratings are very misrepresented, one thing the do is improve handling and braking simply with less tire flex! their construction is so good that it takes higher speeds to cause them to become damaged. when downgrading you will most likely see edge wear,do to lower quality shoulder edges. you will have the alignment checked and find out nothings wrong! theirs not ,wrong application. use the min stock rating or improve upper ratings. ford did on zx3 to svt.
potatoman01 is offline
Old 02-27-2011, 03:46 PM   #14
frednumber15
frednumber15's Avatar
Fan#: 83585
What I Drive: 2003 2dr ZX3
Points 1,671, Level 23
Points: 1,671, Level: 23 Points: 1,671, Level: 23 Points: 1,671, Level: 23
Level Up 72% Completed
FF Reputation: 5 frednumber15 Good Standing Member
Here is a method to find the best ALL SEASON tires for the $ you spend.....
I basically go to….
http://www.tirerack.com/
I use tirerack.com because there is an extensive number of reviews and some tests on various tires.
No need to purchase the tires here…but they do have good prices.
I usually have decided what size tire I want to buy…usually maybe 2% to 3% over sized for better mpg. I use this page to calculate what size I want to look for and what the % difference will be from the original tires:
http://www.csgnetwork.com/tireinfo4calc.html
How to SEARCH for a good tire:
* Go to tirerack.com using the link above
* I SEARCH for tires by TIRE SIZE…..and I usually am searching for ALL-SEASON tires….so I CHECK those various boxes that pertain to these type tires.
* After the search…I then rank the tires by PRICE...low to high.
* I then CHECK the first so many tires…maybe 4-5 of the lowest priced….then click COMPARE.
* Then on the left in the Customer Survey area I look at SNOW TRACTION….followed by WET TRACTION…and DRY TRACTION…looking for higher numbers.
Then considering price, traction, and tread wear…I carefully go through the REVIEWS, SURVEYS, and any TESTS for any tire that looks good.
Not everyone is going to like a certain tire….but I can usually tell from the majority of the reviews what the tire is probably going to be like to own.
My “THEORY” as far as Low Rolling Resistance tires is that YES…the OEMs put LRR tires on their new cars…but if you read some of the reviews…a lot of people can’t wait to get them off of their cars…usually due to poor traction. Eventually they might come up with good LRR tires though.
The method I use finds good high traction tires that I can then put enough PSI in to have lower rolling resistance along with good traction year around….and I usually get a good deal at the same time.
The PSI in the glove box (or where-ever) is only a start…after market tires are sometimes made in a much different way…I usually test various pressures…going with as high a PSI that I can and still have good cornering and traction.
I usually end up 4-5 lbs under the sidewall max pressure. If one end of the car is lighter in weight…best to keep that axle a couple of lbs below the heavier end?
Bottom line for me is finding the best tire for the price…and the best traction and handling the tires are capable of…cause you never know when you’re going to need it.
You can spend almost 2Xs as much for the same size tire…and get less tire for your efforts in some cases.
Note: You should use your own judgment if applying any of these ideas or methods...as they are only my opinions....not facts.
2003 2dr ZX3 2.0 L Zetec auto 205/50/16s
...and I am unanimous in that position.
frednumber15 is offline
Old 02-27-2011, 06:32 PM   #15
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
frednumber15, I disagree with one of the sources you rely on...."customer reviews/surveys." While better than nothing I suppose, I rarely rely on these for the following reasons: 1) people are often very (overly) defensive of their purchases, 2) most are comparing the new tire to a worn out old tire so naturally the new one will usually seem head and heals better, and 3) very few people get to do head to head tire comparisons to "fairly" rate a tire. When I look at these surveys I will normally look at the bad reviews rather than the positive ones. Most bad reviews seem to be a little more unbiased.
I do agree that there is a lot of very good info on the Tirerack site and I do rely heavily on "their" testing results when shopping for a tire.
Geezer is offline
Old 02-28-2011, 10:52 AM   #16
frednumber15
Fan#: 83585
Some of the bad reviews are by people who just go by the PSI sticker and don't realize that some non-OEM tires require more air. I generally pay most attention to the people who have run the tires a good many miles.
The tirerack tests don't usually cover all the tires they sell.
I'm mostly interested in all season tires...the same method with modifications could be used for summer performance tires.
But every body does it differently......
Old 02-28-2011, 03:42 PM   #17
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,940, Level 74
Points: 12,940, Level: 74 Points: 12,940, Level: 74 Points: 12,940, Level: 74
Level Up 23% Completed
Forum Activity 99%
Just remember your tire patches are the size of a softball. So I say step up!!!!!! Please don't cheap out there!!!!!
felixthecat is offline
Old 11-04-2013, 09:54 AM   #18
Kavika
Fan#: 63848
What I Drive: 2001 ZX3
Points 166, Level 3
Points: 166, Level: 3 Points: 166, Level: 3 Points: 166, Level: 3
Level Up 32% Completed
FF Reputation: 1 Kavika Good Standing Member
I just want to buy tires for my 2001 ZX3 to help me get another 100K miles out of it. I drive aggressively sometimes, but rarely over 75mph.
What tires last the longest and have the best reputation?
Thanks!
Kavika is offline
Old 07-15-2014, 09:19 PM   #19
JLokiG
Fan#: 172937
What I Drive: 2009 Silver Focus SE
Points 583, Level 11
Points: 583, Level: 11 Points: 583, Level: 11 Points: 583, Level: 11
Level Up 66% Completed
FF Reputation: 1 JLokiG Good Standing Member
You saved me a BUTTLOAD of headache lol
JLokiG is offline
Old 09-02-2014, 04:30 AM   #20
cruiz2001
Fan#: 187241
What I Drive: 2001 Silver ZX3 with 201,000+ miles
Points 25, Level 1
Points: 25, Level: 1 Points: 25, Level: 1 Points: 25, Level: 1
Level Up 49% Completed
FF Reputation: 1 cruiz2001 Good Standing Member
Hello. I have read your post but have a question. Turns out my 2001 focus with 200500+ miles, which I have had 3 weeks now, has a rear driver side tire with the steel belting shifted. I need tires in an emergency but am on a very tight budget. Should I get 2 expensive tires or should I just buy all 4 cheaper ones? I am seriously considering the set of 4 PRIMEWELL Valera Sport AS tires with 40,000 mileage warranty.
cruiz2001 is offline
Similar Threads
Is it safe to have two old, partially worn tires on left side and two new tires on dfv Wheels & Tires 8 05-09-2007 09:46 PM
17" rims and tires in San Diego SD_Focus Archive 8 05-08-2007 01:01 PM
Were My Tires Correctly Mounted to the Factory Rims? abq focus Wheels & Tires 10 06-30-2005 04:44 PM
goodyear integrity tires SD_Focus Wheels & Tires 1 11-10-2004 12:01 AM
Wrong Tires - Dealer Responsibility ? Kalos Wheels & Tires 9 11-02-2004 12:28 PM
