Attaining maximum camber with factory setup - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 02-04-2008, 04:10 PM   #1
blacksheepZX3
Fan#: 52630
What I Drive: 2007 Silver ZX3
FF Reputation: 1 blacksheepZX3 Good Standing Member
Anyone running in h-stock who has gotten a lot of camber out of their setup with stock bolts - any tips and tricks, please advise....
Also, someone mentioned crash bolts that are smaller than factory and can help increase camber? Any knowledge of this - They would have to be a ford part and have a part no to be legal in h-stock...
Just curious what y'all do!
Thanks!
blacksheepZX3 is offline
Old 02-05-2008, 11:56 AM   #2
blacksheepZX3
Fan#: 52630
WD40 - So, are you saying I cannot get this documentation or its unavailable or are you suggesting not to do it? Please advise...
And for those who don't want to sift thru the whole link, these are the part no's:
Front:
W500550-S309 = BOLT (2 UNITS)
W703217-S309 = NUT (2 UNITS)
Rear:
(2UNITS) YS4Z-5K978-AB BOLT - RR
(2UNITS) XS8Z-5K751-AA CAM - R
(4UNITS) W703217-S309 NUT M12
(4UNITS) W500746-S309 BOLT M1
Old 02-05-2008, 01:07 PM   #3
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
I think what the dear Reverend is trying to explain is that interpretation of the SCCA rules vary by section.
You will have a very difficult time proving to an official, with or without documentation, that the camber bolts are considered by Ford to be an OEM part/correction for an existing performance issue.
The root of it is that the camber bolts improve over stock vs. correct a design flaw.
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 02-05-2008, 03:20 PM   #4
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,532, Level 47
Points: 5,532, Level: 47 Points: 5,532, Level: 47 Points: 5,532, Level: 47
Level Up 91% Completed
Forum Activity 10%
FF Reputation: 35 thenorm Great Standing Member
Originally Posted by blacksheepZX3 View Post
Rear:
so, where do these parts go? do they go into the same location as
http://www.steedafocus.com/store/Sus...201/index.html
basically i've ordered the steeda bolts and i want more camber while remaining within FSP (ie, i cant get the SPC control arms).
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 02-05-2008, 03:26 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Here's what the rule book says:
13. STOCK CATEGORY
Alternate parts listed in a factory parts manual are not authorized
unless their use is specifically referenced in the factory service
manual or in a service bulletin for the specific model.
See Sections 3.8 and 8.3.1 for documentation requirements.
And
13.8 SUSPENSION
E. If authorized by the manufacturer, the use of shims, special bolts,
removal of material to enlarge mounting holes, and similar
methods are allowed and the resulting alignment settings are
permitted even if outside the normal specification or range of
specifications recommended by the manufacturer. If enlarging
mounting holes is specifically authorized but no material removal
limits are specified, material removal is restricted to the
amount necessary to achieve the maximum factory alignment
specification.
As WeeAsp noted, and what I was trying to say, is you will need the documentation to prove
that those bolts are an authorized (by the manufacturer-Ford) repair or service to your particular model car.
I guess the next question, is how strict your Region is as far as following the rule book.
Nationals will definitely require all the proper documentation.
But, local events will more than likely not worry, unless you're exceptionally faster than the rest of your class.
At that point...you'll get bumped.
WD40 is offline
Old 02-05-2008, 11:34 PM   #6
thenorm
thenorm's Avatar
Fan#: 14947
Forum Activity 10%
yes, but im not trying to be Stock legal, im looking for FSP and as such
15.8 SUSPENSION
Vehicles may only exceed the allowances of 13.8 as specified herein.
F. The following allowances apply to strut-type suspensions: Adjustable
camber plates may be installed at the top of the strut,
and the original upper mounting holes may be slotted.
G. Camber bolts may be installed, providing these parts use the
original, unmodified mounting points. Caster changes resulting
from the use of camber bolts are permitted.
so, has anyone used these crash bolts to be able to tell me where on the rear suspension they are used?
May 2014 ROTM
thenorm is offline
Old 02-06-2008, 06:14 PM   #7
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^I was responding to the OP, since he's wanting to stay in HS.
I too am curious about those rear suspension parts.
I always thought they were just another camber bolt like SPC etc,
but that's way too many parts to just be replacing the upper control arm bolt.
WD40 is offline
Old 02-21-2008, 07:23 PM   #8
lauzon
Fan#: 49048
What I Drive: 2003 zx3 pzev
FF Reputation: 1 lauzon Good Standing Member
does anyone know if there is any documentation from ford (service manual or bulletin) available for using these camber bolts---i'd be very interested in finding out!!!!
lauzon is offline
Old 02-27-2008, 07:35 PM   #9
lauzon
Fan#: 49048
anyone???? anyone at all????
lauzon is offline
Old 02-29-2008, 06:27 PM   #10
thenorm
thenorm's Avatar
Fan#: 14947
Forum Activity 10%
Lauzon,
as far as i know, there is no documentation allowing for the use of the crash bolts or camber bolts in a stock classed focus.
This is my opinion after reading hte forums, I have not activly pursued looking for this documentation.
May 2014 ROTM
thenorm is offline
Similar Threads
Installing SVT Subwoofer (w/no factory wiring) shooga Car Audio, SYNC, MyFord Touch & Electronics 8 12-05-2011 07:05 PM
The complete factory sub FAQ spudgunman Car Audio, SYNC, MyFord Touch & Electronics 8 01-10-2011 01:36 AM
For Sale: Digital Air Ride Setup... JayNHL Archive 6 04-18-2007 08:42 AM
SVT Intake Setup for Zetec 02ztsian Archive 15 04-09-2007 01:55 PM
How to: Adding factory Fogs on an '05 Fredness MK1 Focus 4 01-24-2006 10:59 PM
