DIY: Adjustable wastegate actuator - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-03-2008, 09:04 PM   #1
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,967, Level 74
Points: 12,967, Level: 74 Points: 12,967, Level: 74 Points: 12,967, Level: 74
Level Up 30% Completed
Forum Activity 3%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Talking DIY: Adjustable wastegate actuator
After shortening my wastegate actuator rod too much and ending up overboosting I decided not to take shortcuts this time and make the rod adjustable.
This way I can properly preload the wastegate for the stock psi (9.5), or crank it up later if I wish without much hassle.
I can also lengthen the rod to keep it from boosting if I desire.
Note: this won't work for all applications.
The rod must be straight, and there must be ample space for the turnbuckle.
This is an IHI actuator from a 1987/88 Ford Thunderbird TC 2.3.
Parts:
- wastegate actuator
- 1/4" turnbuckle from Ace Hardware
- 1/4" nut to lock it in position.
Tools:
- Welder or 1/4" die
- Cutting tool
- Vise (to hold parts while welding)
I bought a 1/4" die thinking I would just thread the actuator rod.
Before opening the die (so I could return it) I tested the welder on a part of the turnbuckle eye end.
The weld penetrated beautifully so I went that route.
I used a heat level C (from A-D) on my MIG welder using flux core wire.
After the install I went for a drive and it worked perfectly.
PICS
You can see I ended up cutting more off for a wider range of adjustability:
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Similar Threads
internal wastegate actuator livinlots26 General Forced Induction 5 10-07-2007 03:30 AM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
Is rear toe adjustable with stock suspension? brianwitt Brakes, Suspension & Body Chassis 5 02-13-2006 12:23 PM
How much Horsepower is too much? Carrera26 Ford Focus & General Car Chat 54 01-31-2006 02:31 PM
Comparison: Nonadjusable vs. Adjustable vs. Self Adjusting Shocks/Struts Achilleus Brakes, Suspension & Body Chassis 7 01-26-2006 11:26 AM
