Codes PO401 & PO402 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-02-2008, 02:29 PM   #1
FiaCobra
Fan#: 53289
What I Drive: Ford
FF Reputation: 1 FiaCobra Good Standing Member
Codes PO401 & PO402
2002 Focus SE 2.0L ZeTec
Pulled codes:
PO401: EGR insufficient flow detected
PO402: EGR excessive flow detected.
Problem is i need a vacuum schematic for this car since the engine emissions decal is missing (car was involved in 2 frontal accidents by the previous owner) I want to check the vacuum system 1st to make sure everything is routed properly but i would need someone to scan the engine emissions decal. I want to start with the basics before "replacing parts" even though it may just be the EGR valve itself. Can anyone supply a schematic and post here?
TIA
FiaCobra is offline
Old 02-02-2008, 03:34 PM   #2
tczx3
tczx3's Avatar
Fan#: 48551
What I Drive: 2002 ZX3 (SVT Eng/Tran), 2002 SVTF
FF Reputation: 32 tczx3 Great Standing Member
Buy-Sell-Trade Rating: (8)
A code P0402 most likely means one or more of the following has happened:
The DPFE (differential pressure) sensor is faulty and needs to be replaced
There is a blockage in the EGR (most likely carbon buildup)
The EGR valve is faulty
The EGR valve may not be opening due to a lack of vaccuum
Sorry don't have a vacuum line routing handy! Testing the egr valve itself is easy if you have a vacuum pump. Disconnect the line from the egr, plug the line, connect pump to egr valve, start engine and allow to warm up, apply vacuum to egr valve, you should notice a dicernable difference in the idle speed. If not, then possible bad valve or blockage.
2002 ZX3SVT SVT engine/trans conversion w/ SVT guages, headlamps, front grille, bumpers, 17" Euro, Hankook Ventus V12, AEM CAI, Borla
2002 SVTF Infra Red! Stock w/ Dual oulet exhaust and rolling on Proxes 4
2002 SVTF Pitch Black-Dad's new ride!
tczx3 is offline
Old 02-02-2008, 10:34 PM   #3
FiaCobra
Fan#: 53289
What I Drive: Ford
Thanks for the tip. I'll post back my findings.
FiaCobra is offline
Similar Threads
Rough Idle and SES Codes chkpnt General Technical Chat 3 08-25-2007 01:14 AM
Codes and Codes and Codes...oh my MIKESSVT General Technical Chat 6 08-24-2007 08:26 AM
Please Help Me, throwing codes!! MattZX3 General Technical Chat 8 08-07-2007 10:40 PM
got a couple of codes in my focus tatao General Technical Chat 1 04-09-2006 08:02 PM
