How to remove 2008 Ford Focus Radio - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-14-2008, 06:47 PM   #11
kenzx3
Say NO to FRPP Drops
Fan#: 42651
What I Drive: '00 ZX3, '03 ZX3, '07 ZX3
FF Reputation: 125 kenzx3 Excellent Standing Member kenzx3 Excellent Standing Member
Buy-Sell-Trade Rating: (49)
Originally Posted by zx505focus View Post
even if you do this, how are you going to put in a aftermarket radio.
I believe Metra makes a kit already for the 08+ Focus, it was at CES this past year so I'm guessing its out on the market already. Only thing is somebody was saying the cost is gonna be around $80, so he should be good if he buys that.
kenzx3 is offline
Old 06-03-2008, 10:32 PM   #12
wolfy659
Fan#: 56553
What I Drive: 2008 Red SES
FF Reputation: 1 wolfy659 Good Standing Member
...but now what?
So I just purchased a 2008 SES today. Love SYNC. Question is, my 00 se had a sony head w/ipod cable to glovebox. Can I do that with the stock unit? Other models seem to have connection thru console. Please advise.
wolfy659 is offline
Old 06-14-2008, 09:49 AM   #13
Archion
Fan#: 53720
What I Drive: 08 VB SES 2d/99 Mustang/86 F150
FF Reputation: 6 Archion Good Standing Member
here is the info on the metra kit...
Metra part # 99-5816
Also, on A/T vehicles you do not need to put your key in the ignition to move the shifter, look to the front right corner of the shifter bezel, you will see a small plastic "block" that pops out, under that is the override button for the shifter interlock, you can stick your key, screwdriver, whatever in there and then move the shifter like normal.
Archion is offline
Old 06-14-2008, 05:15 PM   #14
kenzx3
Fan#: 42651
Gave out a little Rep for that link
kenzx3 is offline
Old 07-09-2008, 09:48 AM   #15
whitefox
whitefox's Avatar
Fan#: 54401
What I Drive: 2008 Ebony CC 2dr coupe SES 5spd
Points 1,961, Level 26
Points: 1,961, Level: 26 Points: 1,961, Level: 26 Points: 1,961, Level: 26
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 35 whitefox Great Standing Member
You should be able to plug your iPod directly into the auxiliary port or the USB port.
Carl - whitefox -
Team Duratec # 164
Mid-Atlantic Team EXTREME
2008 Focus Ebony Clearcoat 2dr SES 5spd
whitefox is offline
Old 07-09-2008, 11:51 AM   #16
02ZX3NJ
02ZX3NJ's Avatar
Fan#: 56346
What I Drive: 2002 Black ZX3
Points 697, Level 13
Points: 697, Level: 13 Points: 697, Level: 13 Points: 697, Level: 13
Level Up 94% Completed
FF Reputation: 5 02ZX3NJ Good Standing Member
I dont know if this works with the sync because the website doesnt give me a option for standard or sync radio but www.axxessinterface.com sells the harness and peice for the Ford radios for ipod intergration.
This is the harness you would need
Axxess - AHDH-FD5
And this is the module
AHDI-D01
Here is a link to the documentation relating to that product.
http://documents.victorytechnologies...oduct/9402.pdf
Enjoy.
~Rich~
02 ZX3 Pitch Black
~Rich~
02ZX3NJ is offline
Old 10-08-2008, 06:43 PM   #17
JCR
Fan#: 59720
What I Drive: 2008, Vista Blue, Focus
FF Reputation: 1 JCR Good Standing Member
Hey guys,
I am new to the site, and let me start by saying that this tread is exactly what i was looking for, thanks. I just have a couple of question. Can i hook up a amp to the factory stereo? Is there a amp turn on lead wire on the back and audio output connection? Thanks to this tread, i now know how to take the stereo out, but i don't want to take everything apart until i know for sure that i can hook up a amp. If someone can post a pic on the back of the stereo, it would be great. Thanks in Advance.
JCR
JCR is offline
Old 10-08-2008, 06:58 PM   #18
focusboy5
focusboy5's Avatar
Fan#: 50002
What I Drive: Four Wheels
Points 8,328, Level 61
Points: 8,328, Level: 61 Points: 8,328, Level: 61 Points: 8,328, Level: 61
Level Up 60% Completed
FF Reputation: 31 focusboy5 Great Standing Member
Buy-Sell-Trade Rating: (13)
First off I would like to say welcome
And yes you can wire up an amp. You need to go buy an LOC(Line output converter). You can buy one of these at your local best but or circuit city. Should cost around $30-$40. You will tap into your rear speaker wires behind the stereo. This will give you your RCA's. As for the Turn on, you can just run a wire to a fuse that is in use when the car is on, such as gauges(may work not sure), but something like that. The rest of the amp wiring is normal.
Hope that helps. Rep is always nice.
focusboy5 is offline
Old 10-12-2008, 09:49 AM   #19
JCR
Fan#: 59720
Thanks for the help. I figured that a LOC would be the best way to go but i wasn't sure what to do with the amp turn on. I guess that i will have to try a few different fuse and see if i can get it to work. Thanks again.
JCR
JCR is offline
Old 10-17-2008, 09:44 AM   #20
rebelboy6121987
Fan#: 58470
What I Drive: 2008, Vista Blue, S coupe
FF Reputation: 5 rebelboy6121987 Good Standing Member
when i was wiring my amp, i used a LOC from the local radio shop. it was an axxis and so far it has not had any problems. it was easy to install. you can reach the wires from your trunk. what i did was i took out the side panels in the trunk, then opened the back seat. i found the wiring harness that had the speakers in it. If you look closely enough you can see the rear speakers, if you have an 08 coupe. and i followed them to a easy to access location. i spliced the wires from the LOC into these and did the basic amp hook up and it sounds great
rebelboy6121987 is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Need Ford Recall, TSB, or your vehicle history? Click Here! DJ Lukdogg General Technical Chat 368 10-13-2008 06:04 PM
2008 Focus TimHickey Ford Focus & General Car Chat 5 01-11-2007 01:51 PM
2008 Ford Focus US-Spec part 1 mitchlguzin Ford Focus & General Car Chat 9 01-08-2007 06:57 PM
European Focus in late 2008!? AndrewST Ford Focus & General Car Chat 36 09-26-2006 02:09 PM
