How to remove 2008 Ford Focus Radio - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-27-2008, 04:03 PM   #1
Twinkeethekid
Fan#: 52926
What I Drive: 2008 Black SES
FF Reputation: 1 Twinkeethekid Good Standing Member
I made a post in an earlier thread that I successfully was able to remove the radio unit in my 2008 Ford Focus and some people wanted to see pictures on how I did this. If you've seen the 2008 Focus's dash unit you know it looks pretty intimidating to remove. After playing around a bit I was able to remove it with no special "DIN tools." The only thing you'll need is a flathead screwdriver, a 7mm ratchet wrench, and a little bit of carefulness and patience.
1) You want to start off by pulling the e-brake all the way up as far as you can. I also found it helps to put the key in the ignition (you don't need to start it) and put your automatic transmission into D or L. This will just make it easier when you pull off the plastic that surround it.
2). Open the middle storage compartment and pry the plastic up with a flathead screwdriver (see picture below).
3) Once you remove the center plastic that surrounds the e-brake and shift stick you need to remove the 2 screws that secure the bottom of the radio unit into place (please see the below picture).
4) Using a flathead screwdriver pry the plastic plate on the passenger side (where the airbag is located). This won't come all the way off, as there's a screw keeping it from doing so. You should be able to to get it off enough to be able to remove the radio.
5) Remove the two screws holding the plastic that surrounds the steering wheel.
6) Lower the steering wheel all the way and remove this plastic.
7) Remove the vents above the top of the radio dash unit.
8) Remove the two screws holding the radio in place.
9) Starting from the bottom begin to pull the dash unit out.
I hope this helps for anyone who wants to try this. I apologize for not knowing technical words for things or for my lack of explanations. I hope the pictures speak pretty much for themselves. Good luck!
Twinkeethekid is offline
Old 01-28-2008, 09:25 AM   #2
Thorin_II
Fan#: 52396
What I Drive: 2008, blue, ZXC
FF Reputation: 1 Thorin_II Good Standing Member
blech. excuse me while i throw up. ok now that you have the pictures up and you know how to do it... mind coming over and doing it for me?
nah all kidding aside, thanks for the FAQ.. now all i have to do is figure out the color coding on the speaker wires...
Thorin_II is offline
Old 01-28-2008, 10:39 AM   #3
shepski
Fan#: 45523
What I Drive: '04 CD Silver SVT ZX5, #328 of 1079
FF Reputation: 53 shepski Excellent Standing Member
Buy-Sell-Trade Rating: (10)
Whoa - nice write-up and gutsy move: improvisationally tearin' up the console and dash of your brand-new car! I'd be far too squeamish for that. (That stereo must not sound all that good, huh? EDIT - oh, I just found your other thread re: Sirius. Got it.)
shepski is offline
Old 01-28-2008, 09:53 PM   #4
mrfatride
mrfatride's Avatar
Fan#: 21759
What I Drive: 2009 Vista Blue SES Coupe
FF Reputation: 42 mrfatride Great Standing Member
ouch....i would have at least used a panel puller...hope that screw driver didnt mess up your plastic too much
2009 SES Coupe #036
MECP Certified Installer
mrfatride is offline
Old 01-29-2008, 01:15 AM   #5
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
sweet job man now i can convince my mom to paint her interior panels red like the outside
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 02-07-2008, 05:50 PM   #6
290
290's Avatar
Fan#: 52633
FF Reputation: 1 290 Good Standing Member
Now the question is...can i go to a junkyard and find an 08 with with the same color interior and swap out my steering wheel with one that has the control buttons and a radio that has Sync and a 6-disc?????!
Oh and the mirror since thats where the mic is for the phone. Im also guessing that all the wiring is pre ran as part of the harness for the whole 08 foci series and i can just "Plug & Play".
2008 Focus SE Deluxe MTX - The Mine
2008 Focus SES ATX - The Wifes
1995 Taurus SHO MTX - The For Sale
290 is offline
Old 05-14-2008, 03:44 PM   #7
Casper666
Casper666's Avatar
Fan#: 53077
What I Drive: 2008, Black, SES
FF Reputation: 1 Casper666 Good Standing Member
yo thanks alot man this really helped me and my boy, we coyldnt figure it out
Casper666 is offline
Old 05-14-2008, 03:49 PM   #8
zx505focus
AKA KILLA XB
zx505focus's Avatar
Fan#: 44497
What I Drive: 2010 Scion XB RS7
Points 10,155, Level 67
Points: 10,155, Level: 67 Points: 10,155, Level: 67 Points: 10,155, Level: 67
Level Up 27% Completed
FF Reputation: 44 zx505focus Great Standing Member
Buy-Sell-Trade Rating: (19)
even if you do this, how are you going to put in a aftermarket radio.
Murasaki Warrior
zx505focus is offline
Old 05-14-2008, 03:53 PM   #9
Casper666
Casper666's Avatar
Fan#: 53077
hey im putting in a amp but when i removed the radio there was no left and right input...what am i supposed to do
Old 05-14-2008, 06:18 PM   #10
08sesfocus
08sesfocus's Avatar
Fan#: 53462
What I Drive: 2008 white SES
FF Reputation: 17 08sesfocus Great Standing Member
run a line output converter off the rear speakers
2008 Focus SES / 5 speed / Team Duratec #177
STEEDA SRI
custom 2.5 exhaust in the near future
REP points are always appreciated if i mange to help anyone
08sesfocus is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Need Ford Recall, TSB, or your vehicle history? Click Here! DJ Lukdogg General Technical Chat 368 10-13-2008 06:04 PM
2008 Focus TimHickey Ford Focus & General Car Chat 5 01-11-2007 01:51 PM
2008 Ford Focus US-Spec part 1 mitchlguzin Ford Focus & General Car Chat 9 01-08-2007 06:57 PM
European Focus in late 2008!? AndrewST Ford Focus & General Car Chat 36 09-26-2006 02:09 PM
