Trans Flush 2006 Automatic - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-26-2008, 05:47 PM   #1
dezurtrat
Fan#: 53144
What I Drive: 2006 White
FF Reputation: 1 dezurtrat Good Standing Member
Hey all. New here. Have a 2006 Focus 2.0L auto tranny. Was going to do the flush and fill today on the trans. I need to remove the cooler return line but can't figure out how to pop it off. The instructions tell you to push the hose toward the cooler line, then push the release buttons, then pull the hose off. Get those tabs to move or budge at all. Anyone actually ever done this and can explain how to pop that line off. It would be much appreciated. Thanks!
dezurtrat is offline
Old 01-27-2008, 10:27 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
Forum Activity 4%
I know no more than what you wrote. Push forward, then press the clip. If the clip is too hard to push- then you haven't pushed it forward enough.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-27-2008, 10:30 AM   #3
TimHickey
TimHickey's Avatar
Fan#: 38341
What I Drive: 2006 Black zx5 ses
FF Reputation: 16 TimHickey Great Standing Member
thats how it works but be careful not to break it they wont be cheap , you got to push the tabs in on both sides push in while doing so then yank that off you may need to pull a little hard and be prepared to get it in your face I do this atleast every week at work lol
Blue Underglow, Clear Corners,Silverstar Turn signals, Shorty antenna,vogtland springs , Rust Module,Trubendz 2.5 ss magnaflow and Fuzion 205/50/16 HRI's
TEAM DURATEC # 99
TimHickey is offline
Old 01-27-2008, 11:14 AM   #4
dezurtrat
Fan#: 53144
Maybe that's they key but I pushed it forward until it stopped.
Which end of the tabs do you push in? Toward the end of the hose at the cooler line side? I can't even get my fingers in there to press on those. Is there a special tool for this?
I wish I had taken a pic while I was under there to show.
Yea, I figured I might get splashed a little.
Thanks for the replies!
Old 01-27-2008, 11:21 AM   #5
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Press on the back of the collar-- try pressing while pushing forward. When you reach the right spot- it should unclip so that you can pull back. Have your bucket and hose to put over the outlet ready. Also, do the lower hose as that's the return line from the cooler to the trans.
From what I've heard from friends at the Ford dealership- the trans fluid doesn't go bad unless it's dirty or smells burnt. They also say that it's not really necessary to change the filter until the fluid is dirty or burnt. Basically, the maintenance schedule in the owner's manual is general for ALL Ford vehicles, and may or may not apply directly to your vehicle.
Be eclectic.
Old 01-27-2008, 11:55 AM   #6
dezurtrat
Fan#: 53144
Yea, the grips for the clips seem to be toward the rear. The diagram in manual I have show them toward the front. I think You are right and I really need to push it forward more.
Yea, I over maintain my vehicles, too much I think. I actually used to work at the Ford Livonia ETC Transmission Lab in testing in the late 90's. Trans repair at that time was Fords biggest recall. I have been flushing auto trannies too often ever since. The Focus does come with Synthetic in it. The severe service guideline says flush every 30k and replace the filter at 60k. I'll do both now. And actually, I wish I hadn't waited this long as it's not a bad idea to do the first pan drop and cleaning at 5k miles to get all the metal shavings from the new gear break in out.
But as I said I over maintain so all this is probably too much. Bad habits die hard. I'm guessing Ford has come a long way on trans quality since I worked there.
Thanks for the info!
Old 06-02-2008, 07:21 PM   #7
dezurtrat
Fan#: 53144
Alright. Finally got this done. I was able to pop the cooler return hose off. I just needed to push harder in on the tabs and pull. Popped right off.
Flushed it 3 times just like they said. I then dropped the pan, cleaned it, replaced the filter, and filled it back up. Nice and clean again!
Old 08-03-2008, 12:53 PM   #8
dezurtrat
Fan#: 53144
OK, someone PM'd me about this so I'm just posting the procedure here for everybody else. I also included the official version from the manual after the pics.
OK, I modified the official version from the manual a little for my own convenience. There are pics at the end for you from the manual.
I could not get my hand on the cooler return line at the cooler to disconnect it. Instead I followed it back to the trans where I could get at it. Note, I did have the car up on jack stands for this otherwise I didn't fit under there well. Also you can then just swivel the hose around and drain it from here if you disconnect it from the trans side. If you get it off at the cooler you will need a hose to attach to the tube so the fluid won't get all over the front cowling.
So you gotta push the cooler hose on as far as it will go, then pinch those tabs real hard with your fingers and then pull off. This was the hard part.
From here you just start the car and drain out the fluid letting it idle. You'll get just a little over three quarts out. Shut the engine off.
Don't bother putting the hose back on yet. Refill the trans with 3 quarts. Start the car and drain out the fluid a second time. Shut the engine off.
OK, fill with three more quarts and then start the car and drain the three quarts one last time. Shut the engine off. Put the cooler return hose back on.
Then refill the trans with 3 quarts. Might wanna go 2.5 here.
Start the car let it come up to temp. Then check the level and SLOWLY add fluid to bring it up to the proper level and DON'T overfill it. Better to get it about half way between the low/high fill marks and drive it around and recheck to make sure it's OK than to overfill it.
Note, they don't recommend changing the the filter until I think 60k but I went ahead and did it anyway. After the third drain, I reattached the cooler hose. I didn't refill it but dropped the pan instead. Cleaned the pan and replaced the filter, added a new pan gasket and put the pan back on. Then I added back in my three quarts and then ran it to temp and brought the fluid up to the proper level. It's a cheapo filter so there was no way I was gunna go to 60k.
NOTE: If your trans fluid spec calls out MERCON V or DEXRON III, you can use a fluid that says it's compatible with MERCON V/DEXRON III. If it calls out only for DEXRON III, DON'T use anything but a DEXRON III fluid. DON'T use one that says good for DEXRON III and MERCON V.
Official Procedure from Service Manual
*NOTE-Severe service interval: 30000 miles
Service Procedure:
Transmission Fluid Drain and Refill
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Maintenance/Service and Repair.
Disconnect the return hose from the transmission fluid cooler.
1 Push the connector fitting into the cooler line.
2 Press the yellow release button.
3 Pull the connector fitting off the cooler line.
Attach a length of suitable drain hose to the transmission fluid cooler return tube.
Lower the vehicle.
Insert the drain hose into a calibrated 10 liter (10.5 quarts) container.
CAUTION: To prevent damage to the transaxle, do not run the engine above idle. NOTE: If the fluid return rate is less than 0.95 liters (1.0 quart) in 30 seconds, or if the return hose pulsates, check for restrictions at the pump, cooler or cooler lines. Run the engine at idle and pump out 3 liters (3.17 quarts) of automatic transmission fluid.
Switch OFF the engine.
Remove the fluid level indicator from the fluid level indicator tube.
Add 3 liters of automatic transmission fluid to the transaxle.
CAUTION: To prevent damage to the transaxle, do not run the engine above idle. NOTE: If the fluid return rate is less than 0.95 liters in 30 seconds, or if the return hose pulsates, check for restrictions at the pump, cooler or cooler lines. Run the engine at idle and pump out 3 liters (3.17 quarts) of automatic transmission fluid.
Add 3 liters (3.17 quarts) of automatic transmission fluid to the transaxle.
CAUTION: To prevent damage to the transaxle, do not run the engine above idle. Run the engine at idle and pump out 3 liters (3.17 quarts) of automatic transmission fluid.
Raise the vehicle.
Remove the length of suitable drain hose from the transmission fluid return hose.
Connect the return hose to the transmission fluid cooler.
Lower the vehicle.
Install the fluid level indicator to the fluid level indicator tube.
CAUTION: To prevent damage to the transaxle, do not run the engine above idle. Run the engine.
Check the automatic transmission fluid level and fill if necessary.
Old 08-03-2008, 01:31 PM   #9
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Thanks! We'll see about adding something like this for when we finally get a How-To on auto transmissions done.
Be eclectic.
Old 08-19-2008, 10:03 PM   #10
nardvark
Fan#: 54394
What I Drive: 06 ZX4, 05 Mazda6 Wagon, 06 Miata
FF Reputation: 1 nardvark Good Standing Member
This is great. I was going to do this in the next week, and it's always nice to see the diagrams straight from the source. Thanks!
I picked up Pennzoil Mercon V, because it was the only specified Mercon V I could find (everything else was a multi-purpose). I'm assuming this should be fine since I'm following a 30k change interval, as opposed to finding a synthetic Mercon V?
nardvark is offline
Similar Threads
Word to the wise www.hypillauto.com is a RIP OFF *LOCKED* y2kc0wb0y Vendors, Dealers & Seller Reviews 173 10-01-2006 10:12 PM
Trans flush vs. Trans Service ddeg10 General Technical Chat 17 09-17-2006 07:13 PM
automatic trans to manual trans DomG General Technical Chat 8 12-06-2005 02:30 AM
Ford Lowers MSRP of Most Ford, Lincoln, Mercury Models for 2006 Kneel Ford Focus & General Car Chat 17 08-02-2005 06:14 PM
automatic transmission flush at 15000 miles avengerc4 Ford Focus & General Car Chat 11 08-27-2004 04:53 PM
