Balance shaft delete questions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2008, 06:48 PM   #1
Blackcatn2o
soon to be turbo!
Blackcatn2o's Avatar
Fan#: 48278
What I Drive: 06 silver ZX4 ST
Points 8,020, Level 60
Points: 8,020, Level: 60 Points: 8,020, Level: 60 Points: 8,020, Level: 60
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 48 Blackcatn2o Great Standing Member
Buy-Sell-Trade Rating: (13)
I bought a BS delete kit from focus sport yesterday an I've read threads about the BS delete an try an figure out of some of the things people have told to other members. like one of the questions i saw was that you need to add a extra quart of oil after you install the BS delete kit?, I was told if you over TQ the bolts to the oil pan that it will strip the threads on the block (you think i should use thread lock?) theres other questions i will ask later. if there's something i left out please tell me. thaxs in advance
Blackcatn2o is offline
Old 01-24-2008, 07:27 PM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
You will need more oil. The BS assembly sits in the oil pan, and displaces oil. Without it, the oil level will be lower. It usually is between 0.5 - 1.0 quarts.
Like anything aluminum, if you over torque bolts, they will strip. Thread lock isn't needed. Just install the oil pan carefully, and you will be fine.
http://duratec.wikispaces.com/modification-BSD
Egz is offline
Old 01-24-2008, 07:41 PM   #3
Blackcatn2o
soon to be turbo!
Fan#: 48278
on Focussport it says that you need the oil baffle kit when you remove the balance shaft is that true?
Old 01-24-2008, 07:48 PM   #4
Blackcatn2o
soon to be turbo!
Fan#: 48278
that link helps alot thanks did you put that up
Old 01-24-2008, 08:18 PM   #5
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Need? Depends on what you plan to do. Daily driving, no. But if you are going to be on the race track, its recommended.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 01-24-2008, 08:36 PM   #6
Blackcatn2o
soon to be turbo!
Fan#: 48278
Ok thank you again
Old 01-25-2008, 05:25 PM   #7
Blackcatn2o
soon to be turbo!
Fan#: 48278
the Baffle kit is for like autoX not drag racing right? b/c i kinda do alittle of both
Old 01-25-2008, 09:37 PM   #8
Rabitstyle
Rabitstyle's Avatar
Fan#: 38137
What I Drive: 2006 ST
FF Reputation: 1 Rabitstyle Good Standing Member
okay based on this
13. Place a drain pan under the oil filter. Remove the old filter and install the new one.
14. Pour 3 quarts of oil into the engine. Check for leaks. Add 2 additional quarts if there are no leaks.
15. Cleanup the area under the car. Remove the jack stands and lower the car to its tires.
16. Reconnect the battery cable.
17. Start the engine and run for 20-30 seconds. Pay attention to the sound of the engine, it should sound exactly as it did before the procedure. Stop the engine. Verify the oil level adding from the sixth quart until the dipstick reads full. Once again, check for leaks.
18. Test drive the vehicle. Congratulations! You have completed the installation of the Balance Shaft Removal Kit.
does it take 6 Q of oil ????
14. Pour 3 quarts of oil into the engine. Check for leaks. Add 2 additional quarts if there are no leaks. = 5 Q
is this a typo or does it take 6 Q of oil because I am looking to do this to my 2.3 here very soon. ?????
Thanks
D23 Magnaflowed out 06 ST Baby
Team DURATEC # 128
TexasFoci
Rabitstyle is offline
Old 01-25-2008, 10:47 PM   #9
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
I think its a typo. Mine usually takes 5.
Egz is offline
Old 01-25-2008, 11:02 PM   #10
Blackcatn2o
soon to be turbo!
Fan#: 48278
Im kinda glad that i started this thread
Similar Threads
Balance Shaft Delete: long term thoughts and opinions blueoval23 DURATEC Performance (2003-2007) 11 08-09-2007 09:58 PM
For Sale: Cosworth Balance Shaft Delete Kit el diablo Archive 12 03-24-2006 08:45 PM
For Sale: New Cosworth Balance Shaft Delete Kit *SOLD* Massive Archive 20 03-24-2006 09:19 AM
