Front axle \ cv joint replacement - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-22-2008, 12:51 PM   #11
cayres
cayres's Avatar
Fan#: 35184
What I Drive: 03 Comp Orange EAP SVT, 06 ZX3 SES
FF Reputation: 8 cayres Good Standing Member
If you look at that site though DomestikZx3 it list about 7 diffrent axels...one is for an auto rhs, auto lhs, mtx rhs, mtx lhs, ib5 (spi), and reman mtx lhs and rhs..none for the svt
cayres is offline
Old 01-22-2008, 12:57 PM   #12
cayres
cayres's Avatar
Fan#: 35184
Rockauto.com does have the motorcraft ones for about 200 a piece so itll be about 400 to replace both sides.
cayres is offline
Old 01-22-2008, 06:55 PM   #13
cafociguy
cafociguy's Avatar
Fan#: 21858
What I Drive: 01 ZX3, 03 ZX3 PWSCed
FF Reputation: 46 cafociguy Great Standing Member
Buy-Sell-Trade Rating: (4)
Check Kragen, they have a lifetime warantee so if they break there free the second time. Not a hard install I have done mine a couple times. You will need a 1 1/16" I think socket to remove the knuckle side huge nut.
Easiest way, if your going to replace both is to remove the passenger side first it just pulls out of the tranny super easy, you will need a press tool like this
http://www.sears.com/shc/s/p_10153_1...pecialty+Tools
First remove your break caliper and rotor
use above mentioned tool to press the shaft out of the knuckle.
You will probably need to remove the knuckle from the A-arm, I just stepped on my a-arm and it pulled right out of the spindle.
Also need to remove the two nuts on the bracket under the car on the passenger side support bearing.
After it's out of the knuckle/spindle you can pull it right out of the tranny
Same thing goes for the passenger side but easiest way to remove it from the tranny is by using a long screw driver on the passenger side and tap it out from the passenger side, I have removed mine by prying it out and that sucked, that little locking clip thing on the end doesn't like to come out of the tranny. But the tapping it out from the passenger side is super easy, just make sure it's a long skinny screwdriver so it can get around the big metal thing in the middle, not sure of the technical name for it you can see it if you can get your head up there behind the tranny. another note it's a bit easier if you remove the bottom engine mount so you can access everything a bit easier.
Hope that helps
cafociguy is offline
Old 01-22-2008, 10:28 PM   #14
DomestikZx3
DomestikZx3's Avatar
Fan#: 20807
What I Drive: 94' Dodge ram 4wd
FF Reputation: 3 DomestikZx3 Good Standing Member
Buy-Sell-Trade Rating: (8)
L4 2.0 Liter FI - 122 CID VIN 5
how is it not showing for the SVT ^^ the part is for the 2002 SVT focus
they also have new Halfshafts for 10.00 more Lifetime warranty
im gonna miss that car....
DomestikZx3 is offline
Old 01-23-2008, 07:24 AM   #15
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
Forum Activity 4%
There's a lengthy description of what you'll basically have to do to replace your axles aside of changing the filter because this is written for an ATX Focus. You will need new transmission fluid regardless- but the draining and replacing process is a bit simpler on a manual trans.
CV axles
Call around, parts places should have a separate part for SVT's, I'd be VERY surprised if they didn't. Shop around for the best price.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-13-2013, 06:24 PM   #16
herenow
Fan#: 105707
What I Drive: 2001 red zx3
Points 315, Level 6
Points: 315, Level: 6 Points: 315, Level: 6 Points: 315, Level: 6
Level Up 30% Completed
FF Reputation: 1 herenow Good Standing Member
Do you have detailed instructions step by step on the replacement process ?
herenow is offline
Old 01-13-2013, 07:05 PM   #17
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
I had to do one awhile ago, a company called EMPI sells new ones for around $100. Got mine from autopartswarehouse.com I think.
6SPD_soul is offline
Similar Threads
Front License Plate Help AprilFool MK1 Focus 20 07-03-2011 11:57 PM
Svt Replacement Axle Or Oem Only? G~Mcfly SVT Performance (2002-2004) 8 10-12-2006 06:27 PM
Getting a replacement right front fender... what's the difference? focusonthefocus MK1 Focus 5 10-12-2006 01:47 PM
Glasspack replacement for front axle muffler chris_watkins87 SVT Performance (2002-2004) 2 05-26-2005 06:50 PM
