ProCharger Install + More.....Pics and Video inside!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-14-2008, 11:26 PM   #1
thisdude_05
Thou shall fear me!
thisdude_05's Avatar
Fan#: 50808
What I Drive: 2009 Scion tC
FF Reputation: 27 thisdude_05 Great Standing Member
Buy-Sell-Trade Rating: (17)
Cool ProCharger Install + More.....Pics and Video inside!!!
First and foremost I would like to thank all the guys that helped out this weekend. Tom, Kevin, Travis, Greg, and Dean. You guys are awesome. I learned a lot by doing this install. And thanks Kevin for letting us use your shop. Big thanks to the AZ Crew!
I will talk about the install, issues we ran into, give some pointers to those who plan on doing a similar install in the future. The guys from the AZ Crew will also post up their thoughts and I will update this posting accordingly. You will also see a few pictures as we went along. The plan was initially to do a detailed how-to on all of this but there was just not enough time so we will do our best to help you out.
What we did:
ATI C2 Procharger w/FMIC 10psi (3.2") pulley
DiabloSport MAFia
60lb fuel injectors
SVT Header Kit, SVT power steering line, new EGR
Random Tech Hi-Flow Cat
2.5" Trubendz Flexpipe
2.5" Trubendz Exhaust w/Borla Muffler
FocusSport Front Stress Bar
Roush Performance Rear Sway Bar
Massive MSX 90 Ignition Performance Package
One Step Colder Spark plugs
CFM 65mm TB
Start-up Tune by Tom with the Xcal2
All of this was knocked out this weekend (Saturday and Sunday) and we still had time to BS and BBQ.
Issues and Pointers:
- The exhaust had to be cut in several places to get it off because most of the bolts were rusted as hell and even with some penetrating spray they still wouldn’t budge so we just cut it.
- When you take off the header be sure to label each bolt, unless you have new ones, because we had about 2 bolts that wouldn’t thread all the way once we put the new header on. Label each one to whatever holes they went to.
- The o2 sensors were very hard to get off. Don’t waste your time trying to pry it of with a wrench and risk stripping it. Just go buy an o2 sensor removal tool at Autozone or wherever for about $5.99.
- The fuel injectors were tough to get out by hand so we used a pair of vice grips and grabbed the injector from the bottom and used the valve cover as leverage and they popped right off. Make sure all of the o-rings come off with the injectors. To get them back on we just took a dab of oil and lubed the o-rings and they popped right in. Be careful not to bend the clips the hold the injector to the fuel rail. We ended up bending one too much and had to take the rail and injectors back off to bend it back in place so it would latch on to the rail. We also removed the TB so we could have more room to work with.
- The power steering line was a big issue. It was hard to get out and hard to get back in. The threads are really fine so you have to line it up just right for it to go on. Remember that you are basically refilling the whole p/s system so buy enough fluid to fill the system, about a quart will work.
- We had a hell of a time mounting the FMIC because we had to drill through the metal to make holes. Be sure to buy some really good drill bits. You might want to get a few extra because after the first hole we burned most of it up. Be extremely careful that you don’t slip the bit off the metal and end up drilling a hole through the radiator and hitting an a/c line, spraying freon everywhere (cough cough) Hahaha
- We had to modify the piping from the IC to the TB. We ended up using the whole CAI and cutting one of the supplied pipes to fit it just right.
- The belt……be sure that you pay close attention to the routing of the belt. I believe this was our biggest mistake because we were routing it wrong and it made the belt look too long so we made numerous trips to the parts store, buying belt after belt and it turns out that we had the right belt to begin with but we were just routing it wrong. Here is a reference just in case: Belt Routing
I think that about sums up the issues we ran into. Some of you may not even run into these problems but FYI. The next step is getting this thing tuned. I am working with Tom to get this done.
I still have install the boost gauge and a/f gauge.
Here are some pictures, enjoy!
Here is a link to another post from Tom with more pics. Click here
*EDIT* Here is a video of the start up.
YouTube Video
Thanks to all the members who provided great info and support leading up to this install.
thisdude_05 is offline
Old 01-14-2008, 11:34 PM   #2
jrpasmo
jrpasmo's Avatar
Fan#: 2866
What I Drive: 02Focus ZTW, 02Focus SVT
Points 2,642, Level 31
Points: 2,642, Level: 31 Points: 2,642, Level: 31 Points: 2,642, Level: 31
Level Up 28% Completed
FF Reputation: 5 jrpasmo Good Standing Member
Why did you have to mess with power steering line ?
#4208/4788 Procharged SVT 10PSI : +-270/204 by Focus-Power,
N/A ZTW, 2.2 CRDI AWD Santa Fe MMRacing tuned
jrpasmo is offline
Old 01-14-2008, 11:34 PM   #3
egman2005
Slow n lifted
egman2005's Avatar
Fan#: 44983
What I Drive: 2003 SVT Focus
Points 9,623, Level 65
Points: 9,623, Level: 65 Points: 9,623, Level: 65 Points: 9,623, Level: 65
Level Up 91% Completed
Forum Activity 2%
FF Reputation: 21 egman2005 Great Standing Member
Buy-Sell-Trade Rating: (7)
nice looks good!
egman2005 is online now
Old 01-14-2008, 11:36 PM   #4
thisdude_05
Thou shall fear me!
Fan#: 50808
I bought the SVT header kit and along with that I bought the SVT p/s line because the stock one sat too close to the header, too much heat would cause it to blow, as was the case with some members on here. But looking back at it now I would have rather bent the stock one out of the way and wrapped it because it was such a pain to get on.
Old 01-14-2008, 11:36 PM   #5
loudfocus01
loudfocus01's Avatar
Fan#: 26006
What I Drive: 2001 White LX 2002 Infra-Red Svt
FF Reputation: 107 loudfocus01 Excellent Standing Member loudfocus01 Excellent Standing Member
Looks great. Finally able to turn those big chrome wheels now eh?
O'Reilly Auto Parts
Store Manager
Oak Grove, MO
loudfocus01 is offline
Old 01-14-2008, 11:41 PM   #6
Xetchx
Xetchx's Avatar
Fan#: 49113
What I Drive: 03 Silver SVT
FF Reputation: 23 Xetchx Great Standing Member
because he switched to the SVT header instead of the old stock exhaust manifold. the SVT style 4-2-1 header puts out more heat, wraped or coated it gets hot, and it will boil the PS fluid or burn the line hence the need for the SVT PS line
dang he beat me to it. lol
"If you’re going to lead, then lead. If you’re going to follow, get the hell out of my way"
Originally Posted by Trav-E2.0 View Post
I'm not hard, I'm fluffy...lol
#2846
Xetchx is offline
Old 01-14-2008, 11:57 PM   #7
jrpasmo
jrpasmo's Avatar
Fan#: 2866
^^ Is that SVT header so much different from Focus Central 4-2-1 ? I have one on my ZTW for over 2 years and no problem, but it's ceramics coated
jrpasmo is offline
Old 01-15-2008, 12:11 AM   #8
Trav-E2.0
Thread Killer
Trav-E2.0's Avatar
Fan#: 8331
What I Drive: 2014 Fiesta ST
Points 14,853, Level 79
Points: 14,853, Level: 79 Points: 14,853, Level: 79 Points: 14,853, Level: 79
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
FF Reputation: 6 Trav-E2.0 Good Standing Member
Buy-Sell-Trade Rating: (13)
Damn! Looks good Adrian!!! Glad I could be there to help for at least one day .
LMK when you have everything tuned and ready, cause my fat ass wants a ride! LOL
I has FiST
Trav-E2.0 is offline
Old 01-15-2008, 12:58 AM   #9
FocusStrider
Deaf Focus Fanatic
FocusStrider's Avatar
Fan#: 36447
What I Drive: 2014 Tuxedo Black Ford Focus SE
Points 6,893, Level 54
Points: 6,893, Level: 54 Points: 6,893, Level: 54 Points: 6,893, Level: 54
Level Up 72% Completed
FF Reputation: 3 FocusStrider Good Standing Member
wow... its nice.. I didnt know the ProCharger can be installed in ATX Focuses...
Mr. Strider
Former FOCAL-POINT member
Former SEDAN REVOLUTION #11 member
Now a Freelance Street Tuner!
I'm Deaf and Proud to be!
FocusStrider is online now
Old 01-15-2008, 05:28 PM   #10
WUGcatsvt
Obama Can't Gymkhana
WUGcatsvt's Avatar
Fan#: 36697
What I Drive: 02 SVT, 86 BMW E30, 10 VW GTI
FF Reputation: 62 WUGcatsvt Excellent Standing Member
Buy-Sell-Trade Rating: (18)
YOu have my exhaust.. LOL.... No Resinator... RT CAT and of course SVT header.. Sounds Reall good..
Thats alot of money to spend.. lol...
"No, the Focus is SLOW and just kinda stays that way."-Joe GCR SCCA VP
gumpcrew#10
Gulf Coast Region #12 - Me-45 DSP
My Girl-451 DSPL
WUGcatsvt is offline
Similar Threads
Finished... Finally! LOTS of pics, 1 Video. number1187svt Ford Focus Builds & General Showroom 40 08-25-2007 01:58 AM
Pics and video... focuzed1 General Forced Induction 34 07-17-2007 10:22 AM
SVTF Video n Pics. "That's HOT" (56K Warning) topherdopher SVT Performance (2002-2004) 34 03-06-2007 01:48 AM
video install pics ren Car Audio, SYNC, MyFord Touch & Electronics 8 07-05-2004 01:46 AM
