So you're planning on going FI - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-26-2008, 08:22 AM   #71
BOOST170
BOOST170's Avatar
Fan#: 57946
What I Drive: 2004 Imperial Blue Focus ST170
FF Reputation: 1 BOOST170 Good Standing Member
^^what he said too^^
2004 Ford Focus ST170 - being boosted real soon!
My daily bunky - 2007 Ford Fiesta ST
BOOST170 is offline
Old 07-26-2008, 10:19 AM   #72
focusedaddiction
2focusedracing
focusedaddiction's Avatar
Fan#: 23787
What I Drive: 2003 sangria red 5spd. ZX3Turbo
Points 2,448, Level 29
Points: 2,448, Level: 29 Points: 2,448, Level: 29 Points: 2,448, Level: 29
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 4 focusedaddiction Good Standing Member
Buy-Sell-Trade Rating: (14)
maybe we should add a plumbing section too...oil lines & sizes , and water lines and locations to tap from if they're water cooled. especiallky for new comers looking at fi.
this is an awsome thread, keep up the great info.
_/\_/\_SCCA_/\_/\_SM #74_/\_/\_BRING ON THE CONES!...zetec crew #74
ZX3..underpressure
tuning by TOM
focusedaddiction is offline
Old 07-26-2008, 11:14 AM   #73
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,172, Level 91
Points: 21,172, Level: 91 Points: 21,172, Level: 91 Points: 21,172, Level: 91
Level Up 65% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
Turbo: forces compressed air into the engine using a fan in a compressor housing that is driven by another fan in the exhuast housing. housing are connected by a chra which cools and lubricates the rotating assembly.
Intercooler: when air is compressed it is heated and that heat can cause detonation. the heated air is cooled either by an air to air, or a air to water intercooler. there are many different sizes for different power and boost levels.
wastegates: the wastegate is one of two kinds, internal or external. both perform the same task, controlling the amount of exhaust that is allowed to travel through the exhaust housing; therefore controling impeller speed and boost. once a set level of boost is reached the wastegate opens and allows exhaust to pass by the turbo and either be directed back into the exhaust after the turbo or vented/dumped in to the atmosphere.
blow off / diverter / recirculation valve: all perform the same task, they vent pressure that is build up under sudden throttle closing, such as durring a shift.
charge piping: used to direct the air from the turbo to the intercooler (hotside), then from the intercooler to the throttle body (cold side). i have seen lots of debates over sizes on here.. but most say 2.25 on hot side and 2.5 on the cold side.
oil feed and return lines: feed and return lines keep the chra lubricated. the feed line can be ran from the plug in the oil gallery on the side of the head behind the coil pack or one of the oil gallery plugs on the back of the engine. the return line should be -10an line or equivalent, no 90* bend right after the turbo. it should be routed back into the engine either through a fitting on the oil pan or the windage tray. do not put it below oil level in the pan, but always lower than the turbo.
exhaust manifold: this is the part that routes the exhaust to the turbo and wastegate. there are a lot of different designs including tubular and log style.
coupler and clamps: on the couplers the more ply's the better. on the clamps you can either use worm gear clamps for lower boost, but i would recommend T style clamps for high.
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 07-26-2008, 12:41 PM   #74
svt_gEEk
oldFart
svt_gEEk's Avatar
Fan#: 18578
What I Drive: nothing
FF Reputation: 3 svt_gEEk Good Standing Member
Buy-Sell-Trade Rating: (4)
Has anyone ever used a water-cooled turbo? That's what I will be using and was wondering where to tap into the coolant system at. I thought maybe figure out a way to run it from that crappy plugged up hole in the t-stat housing that keeps leaking, solve two problems at a time.
svt_gEEk is offline
Old 07-27-2008, 04:58 PM   #75
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
I have always ran water cooler turbos, its a very simple thing to set up.You just simply splice into a pre exsisting hose.
When standing infront of the car, look down at the radiator. You will see the plastic log thats mounted to the radiator support, there are 2 lines coming from the right side of it going towards the engine.
Simply splice into the hose on the LEFT (in other words the fartherst left of the 2 coming off of the right side of the log)
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 08-04-2008, 03:07 PM   #76
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
oh....did anyone do the "heat exchanger" or Water-Water front mount? like the jackson doesnt have one and the PW does? I didnt see that under "intercoolers" even though it's kinda different....lol
if I am wrong just delete this...HAHAHA......
HaveBlue83 is offline
Old 08-26-2008, 04:37 PM   #77
svt_gEEk
oldFart
svt_gEEk's Avatar
Fan#: 18578
What's the deal with blow-through and draw-through set-ups? Could someone explain the difference in them?
svt_gEEk is offline
Old 08-26-2008, 10:04 PM   #78
IslandFocus
Fan#: 22161
What I Drive: 2000 Imperial Blue Focus ZX3
FF Reputation: 3 IslandFocus Good Standing Member
Draw through is when the MAF is before the turbo/supercharger and essentially sucks air through it. In a blow through setup, the MAF is placed after the turbo/supercharger and air is blown through it. Blow through allows you to run a blow off valve, which will be placed after the turbo but before the MAFS. With a draw through setup, a diverter valve is used to divert the boost pressure from your "pressure side" after the turbo to your non-pressure side before the turbo........but after the MAFS.
IslandFocus is offline
Old 08-26-2008, 11:16 PM   #79
svt_gEEk
oldFart
svt_gEEk's Avatar
Fan#: 18578
Ok, that's what I was thinking, but I wasn't sure. I just wanted to make sure I was setting mine up correctly. I was going to put the MAF after the BOV both on the charge side of the piping right before the intake.
svt_gEEk is offline
Old 09-21-2008, 07:33 PM   #80
Nyt_Muves
Nyt_Muves's Avatar
Fan#: 59352
What I Drive: 2006 Sonic Blue ZX3 SE 5 Speed
FF Reputation: 1 Nyt_Muves Good Standing Member
What about the DURATEC guys? do we have any options? And what are the weak points of our drivetrains to consider?
Nyt_Muves is offline
Similar Threads
planning to turbocharge need help though ineedtafocus General Forced Induction 24 02-25-2007 12:41 AM
Planning in gettin new rims FastandFocusZTS Ford Focus & General Car Chat 0 09-29-2006 10:22 AM
Club Focus SoCal G2G - Planning MaximusZTS Fanatics: SoCal 288 06-12-2006 01:56 PM
WHISPERS: Toyota Planning New 250-hp Scion tC Kneel Ford Focus & General Car Chat 22 08-12-2005 10:45 AM
Planning Long Term Mods w/ Forced Induction IHateRice General Forced Induction 20 03-02-2004 12:42 AM
