HOW TO: Intermittent Wiper Problem Fix. AKA TSB Fix. - Page 5 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 07-30-2009, 10:23 PM   #41
osufans
Fan#: 23001
What I Drive: 2003 Pitch Black ZX5 SVT
FF Reputation: 8 osufans Good Standing Member
yeah, just something that was annoying. i finally got tired of it and fixed it.
'03 ZX5 SVT - Pitch Black #268
osufans is offline
Old 08-08-2009, 03:08 PM   #42
arlenn
Fan#: 67609
What I Drive: 2002 Silver ZX5
FF Reputation: 16 arlenn Great Standing Member
I am having a similar problem with the wipers not parking correctly; when the wipers are killed they stop in place and do not return to the correct park position.
I have replaced the relays, but they were already the -AA replacements, the new ones made no change.
I have seen this type of problem with poor electrical grounding, although i don't really feel that this is the problem with this one, everything is a little too clean.
anybody else have any ideas?
Thanks in advance.
edit:
*must replace the correct relay :P, the suspect ones were hiding behind the sheetmetal of the fuse block holder*
arlenn is offline
Old 08-17-2009, 04:46 PM   #43
andyandlexi
Fan#: 34114
FF Reputation: 1 andyandlexi Good Standing Member
I just swapped over the rear and front wiper relays and this cured the wiper parking fault on the front without transferring any fault to the rear. (maybe a loose relay in the first place?) It's worth a try before buying a new one!
On a UK model focus the central junction box can be found by removing the glove box.......should take about 15 minutes for the whole job.
andyandlexi is offline
Old 09-17-2009, 12:21 PM   #44
X6StringerX
X6StringerX's Avatar
Fan#: 64835
What I Drive: FOCUS!!!
FF Reputation: 3 X6StringerX Good Standing Member
I just decided to do this fix and was pleasantly surprised to find that I didn't need to use any tools other than a flashlight. I'm no contortionist, but I found it very easy to access the relay without removing anything. I would advise anyone that is interested in replacing their relay to take a look before they start removing bolts. $11 and 2 minutes later and I had fully functional wipers.
*NOTE* My car is a sedan, so I didn't have a rear wiper relay to get in the way. It might be a little more difficult with the rear wiper relay in place.
FOCUS!!!
X6StringerX is offline
Old 09-17-2009, 01:14 PM   #45
arlenn
Fan#: 67609
from a previous post, these are just a relay and are available from electronic supplier for about 3.75$ ea.
there must have been a change to the fuse block holder, as there was no way to remove relays without the removal of the fuse block, the relays were covered by the holder.
arlenn is offline
Old 09-17-2009, 01:55 PM   #46
X6StringerX
Fan#: 64835
My panel was exactly as the one picture in the first post. It looks tighter than it is. There is plenty of room to remove the relay. Pull straight out and right before the prongs make it all the way out of the socket, you can tilt it ever so slightly to the left or the right and it'll come right out.
FOCUS!!!
Old 09-30-2009, 03:37 PM   #47
kylesvt720
NeedsMoarEverything
kylesvt720's Avatar
Fan#: 51359
What I Drive: 2006 Saabaru "The Unicorn"
Points 10,778, Level 68
Points: 10,778, Level: 68 Points: 10,778, Level: 68 Points: 10,778, Level: 68
Level Up 82% Completed
Forum Activity 2%
FF Reputation: 17 kylesvt720 Great Standing Member
Just had to do this, was extremely helpful! Took me 15 minutes with installing new wipers, thanks!
Jeremy Clarkson on Detroit: “God may have created the world in six days, but while he was resting on the seventh, Beelzebub popped up and did this place.”
ST CREW #107 / TEAM DURATEC #93 / D23 Crew #3
kylesvt720 is offline
Old 11-14-2009, 08:10 AM   #48
jacko83
Fan#: 70489
What I Drive: 1999 Red 1.8 Petrol
FF Reputation: 1 jacko83 Good Standing Member
Hi guys, ive just been reading through this post and it seems like this is the perfect solution for my problem...however as somebody has already stated, i too have a combined R18 and R19 relay in my junction box. Are the relays identical in Spec? Can i Buy two of the relays intended for the R19 socket?
jacko83 is offline
Old 11-14-2009, 04:17 PM   #49
First Focus
Fan#: 70215
What I Drive: 2002, Silver, Comfort SE
FF Reputation: 2 First Focus Good Standing Member
The part number listed in the first post above was superceded by this current relay part number: F5TZ-14N089-B and it costs just $13.36 at any local Ford Dealer. 15 minutes of simple work as stated above and I am good to go! Nice to have the park function back!
First Focus is offline
Old 01-26-2010, 01:48 PM   #50
SeanL
Fan#: 68841
What I Drive: 2012 Boss 302, 2012 Focus SE
FF Reputation: 1 SeanL Good Standing Member
I do have a wiper problem, but it is different. The wipers will work, then get stuck in park position, then not work till I slam my fist down on the wiper or pull it. Then they stop again....I figured it was a hardware issue, but they work fine most of the time. When they do start to have this issue they seem to struggle to move when they do move, except in high speed mode. But when they stop high speed does not work, and the rear does not work either.... Also when I use the rear washer the radio cuts out! Ford gremlins?
SeanL is offline
Similar Threads
New sympton with an old problem that no one can fix.. kndlz28 General Technical Chat 8 05-15-2007 09:11 AM
Windshield Wiper problem KMiller General Technical Chat 10 01-28-2005 12:31 AM
rear window wiper problem Focus2000 Ford Focus & General Car Chat 6 11-27-2004 03:30 AM
Problem: Indiglo gauges not lighting up. Anyone know how to fix this? thrill5one6 MK1 Interior Mods & Upgrades 9 09-17-2004 07:04 AM
Rear Windshield Wiper Problem (HELP!) Seb656 Ford Focus & General Car Chat 15 03-25-2004 12:01 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
