NO 5th and 6th gear - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > SVT Performance (2002-2004)
Old 01-07-2008, 08:02 PM   #1
FordManSVT
FordManSVT's Avatar
Fan#: 44253
What I Drive: 2003 ZX3 SVT Euro in Comp Orange
FF Reputation: 1 FordManSVT Good Standing Member
NO 5th and 6th gear
So last night i was gettin off the highway, downshifter into 5th and then 4th. Then i went to shift back into 5th and the shifter didnt feel right and the rpms went up. Turns out i was in 3 gear int he 5th gear position and 4th in the 6th gear position. I have 1st through 4 and reverse. The part i dont get is that i can move the shifter from 1st or 2nd all the way to the 5th and 6th position respectivly, while still in gear. i took the shifter apart tonight and nothing really looked out or place. has anyone ever seen this before. Im hoping its a cable problem and not the levers on the trans. i dont think it is an internal tran issue because it has never ground into gear or acted up before. Thanks
FordManSVT is offline
Old 01-07-2008, 08:47 PM   #2
WitchCitySVT
Turbo!!!!
WitchCitySVT's Avatar
Fan#: 33699
What I Drive: 2012 Chevy Sonic 1.4 Turbo LTZ
FF Reputation: 30 WitchCitySVT Great Standing Member
I'm going to guess it's the cables. Thats a common issue.
BUILD# 840 out of 3985 BUILD DATE 4/1/2003 *RIP*
2003 Competition Orange SVT *Revived*
2012 Black Sonic 1.4 Turbo LTZ
WitchCitySVT is offline
Old 01-07-2008, 08:53 PM   #3
zzr4u2nv
zzr4u2nv's Avatar
Fan#: 52385
What I Drive: 2008 Silver Frost Metallic SES..ATX
FF Reputation: 2 zzr4u2nv Good Standing Member
had the same issue way back in the day with my old 88 and 1/2 Escort..........except mine was no 5th gear or reverse.
The linkage needed to be adjusted and then everything lined back up and shifted fine. Not sure if yours is the same problem but it sounds like it.
zzr4u2nv is offline
Old 01-08-2008, 01:27 AM   #4
Shizznid
Fan#: 49618
What I Drive: 2003 Silver SVT
FF Reputation: 1 Shizznid Good Standing Member
I agree. Sounds like cables. For your sake, I hope it is - that's a quick and easy adjustment and/or fix.
Shizznid is offline
Old 01-08-2008, 08:33 PM   #5
FordManSVT
FordManSVT's Avatar
Fan#: 44253
So i looked at the cables today. It turns out the selector cable came apart where it attaches to the bracket on the trans. So hope i can get that stupid little spring back in so i dont have to replace the cable. Thanks guys
Old 01-08-2008, 08:50 PM   #6
WitchCitySVT
Turbo!!!!
Fan#: 33699
The cables aren't that expensive, but they're kind of a PITA to replace.
Old 01-09-2008, 01:03 PM   #7
WD40
The Librarian
WD40's Avatar
Fan#: 5157
FF Reputation: 138 WD40 Excellent Standing MemberWD40 Excellent Standing Member
Seriously...someone PM me, and tell me to add the following to the sticky thread ""How To" and "Infomation" Links":
From FF member COSDEVSVT:
Originally Posted by COSDEVSVT View Post
Adjusting the linkage is easy:
1. Put the shifter in neutral
2. Carefully pop/pry up the orange lock on the back of the cable end
3. Wiggle the shifter around trying to find the best center position - don't shift into a gear
4. Push in the orange lock on the back of the cable end
Take it out for a test drive and see how all the gear gates feel.
Adjust if necessary again (likely won't need to).
Sometimes the cable housings come out of the body attachment clips (under the heat shielding in the 'tunnel') and can flop around a bit ... requiring a cable adjustment.
Some early-build SVTs had the MTX-style cable ends (as shown in the Focushacks article).
Newer builds have a cable end where the lock pops out instead of in (as shown in my earlier posted pic).
And, here's his other post with a pic:
http://www.focusfanatics.com/forum/s...9&#post1101019
FordManSVT; short of buying a new (updated) cable,
you'll most likely need to zippie tie your cable end back together to get 5th and 6th back.
(See the link above "....other post with a pic")
Seems to be a lasting fix that has worked for several members.
WD40 is offline
Old 01-09-2008, 02:12 PM   #8
FordManSVT
FordManSVT's Avatar
Fan#: 44253
I got the little spring to go back into place today. Hopefully it will hold together. I have a feeling that i popped the spring out back in november when i had the trans out to put a clutch in. Thanks for the help guys.
Old 05-14-2008, 09:35 AM   #9
SVTDavan
SVTDavan's Avatar
Fan#: 2767
What I Drive: 03 SVT Focus
FF Reputation: 1 SVTDavan Good Standing Member
Spring?
Can anyone give me some more information on how to reattach this cable? This happened to me on the way into work this morning...
framedfiction.com - My photography Portfolio
svt.framedfiction.com - #22 of 3985
calgaryfocus.com - Calgary Focus Owners Club
SVTDavan is offline
Old 05-14-2008, 02:22 PM   #10
SVTDavan
SVTDavan's Avatar
Fan#: 2767
Well, I took both linkages out at the transmission, and re-installed and adjusted them.
But this didn't change that I don't have 5th and 6th gear. With no gate between 1-3-5 and 2-4-6.
There are only two linkages, right? Or am I missing something else?
SVTDavan is offline
Similar Threads
Counterweight removal-no 5th or 6th gear colinsdad SVT Performance (2002-2004) 11 05-14-2007 11:23 PM
Stuck in 5th!!! Shifter in 6th... HalfTime SVT Performance (2002-2004) 7 12-11-2006 12:09 PM
35mph to 40mph cruising.. 5th or 6th gear??? itbparada SVT Performance (2002-2004) 54 11-12-2006 01:56 PM
5th and 6th are gone SVTbedson SVT Performance (2002-2004) 17 08-15-2006 10:17 PM
Clutch TSB Took 5th and 6th Gear... JohnMichael SVT Performance (2002-2004) 23 04-30-2005 08:02 PM
