Leaking Power Steering Fluid - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-18-2004, 12:11 AM   #1
spikNspan DAN
spikNspan DAN's Avatar
Fan#: 5226
What I Drive: 02' Liquid Grey ZX3
FF Reputation: 1 spikNspan DAN Good Standing Member
I had a problem a weak ago with low fluid, I filled it and though it was fine. Now it's low again which means it's leaking somewhere, but I don't know where it's leaking from. There is a build up of fluid all over my front axle and that's where it's dripping from. I don't know which tube it's leaking from, anyone have any tips for finding the source of the leak? All help is appreciated, thank you!
...2002 Ford Focus Zx3 Turbo...
spikNspan DAN is offline
Old 05-18-2004, 12:47 AM   #2
Shady R
Fan#: 3138
What I Drive: Euro 2003 PitchBlack SVT Focus
FF Reputation: 8 Shady R Good Standing Member
use a black light and black light reflective ink. put ink in power steering bottle,only a small amount is needed, drive for a week and check with the black light next time under the car, and follow it back. I did this for an oil leak wich I thought was the rear main seal but found it was actaully the valve cover. It worked well for my Couger may be it will help in this case to.
Bwaha ha ha ha ha ha, Bleach Fan from day 1. 07-2005:: Spoiler:: Aizen is a good guy. Every one dies. Orihime Saves every one. All there memories are erased as if NONE of it happend.
Shady R is offline
Old 05-18-2004, 01:39 AM   #3
spikNspan DAN
Fan#: 5226
Thanks, maybe I'll try that when I have the time this summer. Till then I'll just fill it back up every week so that it stays at the normal level.
Old 05-18-2004, 07:23 PM   #4
WRCZX3
Fan#: 3395
What I Drive: 2003 ZX3 PZEV
FF Reputation: 1 WRCZX3 Good Standing Member
You might want to check the fittings where the power steering lines go into the top of the steering rack. On the first oil change that I did on my 2001 focus, I noticed some fluid leaking from the fittings on the top of the rack. They were very loose and obviously had come that way from the factory since my car only had 1000 miles at that time. I tightened them up and topped of the fluid and that was all it took.
2003 Liquid grey PZEV. H&R cup kit,205/45/17's on Team Dynamics Pro Race 1's,Focus Central cat back,Marcy Intake,debadged.
WRCZX3 is offline
Old 05-18-2004, 10:30 PM   #5
spikNspan DAN
Fan#: 5226
Alright, I'll try that tomorrow when I have time. Thanks!
Old 11-02-2011, 09:39 AM   #6
joedenny
Fan#: 90327
What I Drive: silver
FF Reputation: 1 joedenny Good Standing Member
it would be the union pipe going into the pump there has been a well known problem with that fitting ford have updated the fitting but still wont give a call back on them .to get it fixed you have to buy both pipes and a union fitting plus the belts i bought them from ford 140 got them fitted for 60 sorted i thought a week later the accuall pipe came back out of the union brought this up with ford who then sold me a different union it is a moderfide union so ask for that one ford dont reconise there is a fault but new cars are the problem mine has only 40000 on it if you are going to fix it your self here is a tip there is a bracket that comes with the pipe it can be cut off and fixed through the head light it snaps into the union hope this helps
joedenny is offline
Similar Threads
Power Steering Fluid Flush 2005 ZX5 ctscas General Technical Chat 2 03-06-2010 03:21 PM
Wet weather braking and wacky power steering fluid. Charged SVTF General Technical Chat 17 03-30-2009 07:37 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
Quick: Power steering fluid ? LastRites SVT Performance (2002-2004) 1 04-17-2006 03:24 PM
Power Steering Fluid jamfrank ZETEC Performance (2000-2004) 2 04-06-2006 08:47 PM
