Steeda SRI install - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-23-2008, 06:31 AM   #21
Netmon
Netmon's Avatar
Fan#: 46321
What I Drive: 2007 ToriD Red ZX5 SES
FF Reputation: 45 Netmon Great Standing Member
More which-way the MAF ?!?
Originally Posted by Timmah! View Post
I did something similiar. I ran outta the rubber grommet/wire that they give you, so I ran down to Checker and got another foot of the stuff. It was just normal rubber piping so I cut a slit in one side and put it between that corner and the battery cable. Was starting to cut the outer plastic.
If MINE'S IN RIGHT then the one pictured HERE(in the quoted thread) is in backwards. (And I've heard.....)
The printed instructions from STEEDA say "with the more tapered end", "facing the AIR FILTER"....
Steeda SRI, Eibach Pro, Ford Racing Dampers, Gorilla Lugs
Netmon is offline
Old 03-23-2008, 06:39 AM   #22
Netmon
Netmon's Avatar
Fan#: 46321
Tapered end? what? !
Check it out. as this pic seems to indicate, there IS NO "more tapered end" they appear equally tapered. so what now? "green-wire to the back"?
"red clip in the front"?
OK the red on the clip is on both sides so that's out.
If all of the pics on this thread are correct it's "Green wire IN, White wire OUT (facing the filter).
and MINE needs to be reversed.....
Thanks ! you all have been a great help!
Netmon is offline
Old 03-23-2008, 01:38 PM   #23
Netmon
Netmon's Avatar
Fan#: 46321
As I did of course EVENTUALLY figure OUT... The "tapered end" they were referring to was ON THE FRACKIN' TUBE! NOT the MAF sensor. (My full install-ordeal can be followed in detail on my thread "STEEDA's IN ! Car's Running WORSE??")
Netmon is offline
Old 03-28-2008, 06:06 PM   #24
Flinkly
Fan#: 29577
What I Drive: 2004 2.3L Liquid Grey ZX5
FF Reputation: 1 Flinkly Good Standing Member
i put a steeda in a 2004 and left off the heat shield and still get about 2 mpg better than before, if i leave my foot off of it. I can also go at least 20 miles farther on a tank. so from 32-34 mpg and from 360 miles to 380 miles. i would be interested to know which way the maf sensor goes, although my car seems to work fine.
Flinkly is offline
Old 03-28-2008, 09:29 PM   #25
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
About the bottom heatshield fitting correctly, the front corner must slip underneath the wiring below the headlight. If not then it will cause it to rock back and forth and not seat in the hole its supposed to.
Here is a pic of my install of the top heatshield. Connected it with a bracket and it fits much better.
jetrinka is offline
Old 05-25-2008, 10:15 PM   #26
nsticks926
nsticks926's Avatar
Fan#: 56320
What I Drive: 2005 Infra Red ST
Points 319, Level 6
Points: 319, Level: 6 Points: 319, Level: 6 Points: 319, Level: 6
Level Up 38% Completed
FF Reputation: 1 nsticks926 Good Standing Member
Has anyone experienced a faint whistle during acceleration? It ALMOST (wishful thinking) sounds like a turbo spooling. It only does it above 3000 rpms at about 1/2 throttle, or i quickly hit the gas pedal. Just wondering if that's normal, or if I possibly have a leak somewhere. :-S
nsticks926 is offline
Old 05-26-2008, 04:18 AM   #27
jumpboy
jumpboy's Avatar
Fan#: 46739
What I Drive: 2006 Black ZX4 w/ SAP
FF Reputation: 1 jumpboy Good Standing Member
No your good. Intakes let you hear the sound of air going through the TB at certain rpms which is what your hearing.
jumpboy is offline
Old 05-26-2008, 02:18 PM   #28
Svtzx555
Fan#: 27739
What I Drive: '06 silver ST
FF Reputation: 11 Svtzx555 Great Standing Member
Buy-Sell-Trade Rating: (4)
I like. I just cant stomach spending $200 on it. I'll be doing this, just the DIY deal.
Gumpcrew#7
Originally Posted by the_07ninja View Post
Svtzx555-3 to Sn4ckm4st3r-1
Originally Posted by TnFocus View Post
Yea, I'll go .080 over on his face.
Svtzx555 is offline
Old 10-17-2013, 06:26 PM   #29
DisguisedRyan
Fan#: 117039
What I Drive: 2006 Screaming Yellow ZX3
FF Reputation: 1 DisguisedRyan Good Standing Member
When you guys installed your intake did you take the factory intake ALL the way out or just the top two pieces and left the bottom one? I left the bottom one in and my steeda is very quite and I would like it to be loud as possible!
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
― Jeremy Clarkson
DisguisedRyan is offline
Old 10-18-2013, 06:48 PM   #30
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,823, Level 76
Points: 13,823, Level: 76 Points: 13,823, Level: 76 Points: 13,823, Level: 76
Level Up 44% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Take it all out. I removed the bumper cover to remove the oem filter & induction hoses.
felixthecat is online now
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
steeda sri installed rightwingjosh_ST DURATEC Performance (2003-2007) 18 11-27-2006 04:16 PM
STEEDA SRI, any problems? rightwingjosh_ST DURATEC Performance (2003-2007) 13 11-01-2006 08:33 PM
Steeda Short Shifter Install Help! ouikikazz ZETEC Performance (2000-2004) 5 09-22-2004 11:48 PM
Steeda SS install? Solaris MK1 Interior Mods & Upgrades 4 07-22-2004 05:34 PM
