Turn signal problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-17-2004, 10:28 PM   #1
Dypheron
Fan#: 5571
What I Drive: Forest Green 2000 Focus LX
FF Reputation: 1 Dypheron Good Standing Member
Turn signal problem
So the other day I was driving around, and noticed that every time I had to turn the steering wheel to the right, a loud clicking sound would occur a few times when the wheel returned to center. Later that day, I put the turn signal on, made my turn, and as the wheel turned back, I heard a loud SNAP. Now whenever I use the turn signals they no longer automatically turn off like they used to. So, my question is how hard do you think it would be to get in there and replace the turn signal assembly? It's not really an issue, I just have to remember to turn them off manually now...
Dypheron is offline
Old 05-17-2004, 10:41 PM   #2
djnevoc
djnevoc's Avatar
Fan#: 1266
What I Drive: 2000 4DR SE
FF Reputation: 1 djnevoc Good Standing Member
Hey dude welcome to the world of the lost focus driver... I am that guy in the focus with the turn signal on for miles and miles!!! The part is really cheap to buy but to put on you must have a ford dealer stick it on unless you are really good with pulling off a loaded airbag without it going off. This problem would have never occured if ford would have used metal for this part!!! I havent had this fixed because my warrenty calls for me to pay $100 for any problem with the car to be fixed, no matter the size of the job. I guess its good if the engine goes!!!
My wife laughs and calls me a dork for being a Focus Fanatic.... I laugh because she Married the DorK!!!!
djnevoc is offline
Old 05-18-2004, 01:03 AM   #3
01FocusZX3
Fan#: 2449
What I Drive: 2001 Liquid Grey ZX3 S2 Edition
FF Reputation: 1 01FocusZX3 Good Standing Member
i dont think the part is too expensive from ford and it wont be that hard to replace it yourself.
01 Liquid Grey Focus ZX3 S2 Edition
04 Electric Blue Dodge SRT-4
01FocusZX3 is offline
Old 05-18-2004, 04:57 AM   #4
jfunk
jfunk's Avatar
Fan#: 3703
What I Drive: 2000 SE
FF Reputation: 3 jfunk Good Standing Member
You don't need to take off the airbag to get to the turn signal switch. Replacing the turn signal assembly is really easy. just remove the steering column upper shroud and then the
turn signal assembly will pull up after you release the locking tab on the turn signal. My turn signal doesn't stop automatically anymore easier. I went on ebay and bought another one.
But when I installed the turn signal it did the same thing. So, after closer inspection of both turn signal assemblies they seem to work. the tongue that sticks out to stop the turn signal wasn't broken off on mine so I'm guessing it has to be something wrong with the steering column.
So, you might want to check your old turn signal assembly first to see if the tongue in the back is broken off or isn't resetting the switch.
jfunk is offline
Old 05-18-2004, 05:22 AM   #5
djnevoc
djnevoc's Avatar
Fan#: 1266
there is a ring that goes around the steering colum its made of plastic and that is what broke
djnevoc is offline
Old 05-19-2004, 03:57 PM   #6
rootbeer88
rootbeer88's Avatar
Fan#: 5599
What I Drive: 2004 CD Silver ZX3 2.3L PZEV
FF Reputation: 1 rootbeer88 Good Standing Member
I guess this is a common problem that we should all look out for?
rootbeer88 is offline
Old 05-19-2004, 09:31 PM   #7
djnevoc
djnevoc's Avatar
Fan#: 1266
yes it is. The head mechanic at my local ford dealership said its a very common place problem. I filed a complaint to try to get an investigation into this problem. It does pose a safety problem that may cause an accident. people might think your going to turn because you forget to turn off the signal.
djnevoc is offline
Similar Threads
My turn signal does not click... slydarkwolf General Technical Chat 8 02-27-2009 01:54 AM
Rear brake and turn signal problem evm1024 General Technical Chat 9 12-02-2008 05:46 PM
signal lights problem hramos04 General Technical Chat 4 07-24-2007 02:46 AM
turn signal problems devilpup419 General Technical Chat 11 03-12-2006 10:31 AM
NEED HELP...Front Turn Signal? 1badassfoci MK1 Focus 2 02-13-2005 02:47 AM
