Bucking - Jerking Under Acceleration - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-01-2008, 09:49 PM   #1
NKENN
Fan#: 50392
What I Drive: 2000 blue SE
Points 192, Level 3
Points: 192, Level: 3 Points: 192, Level: 3 Points: 192, Level: 3
Level Up 84% Completed
FF Reputation: 1 NKENN Good Standing Member
2000 Focus SE, MT, Zetec engine, 108K miles. No DTCs or pending DTCs. The car bucks and jerks under acceleration at any speed. It feels similar to the way an inexperienced driver starts off when learning to drive a manual tx. Idles good and runs good on a level road. The fuel pump was changed years ago under warranty before Ford recognized the problem with the fuel pumps and issued the extended warranty on the pumps.
So far the following things have been done with no change in symptoms:
  • Installed new Motorcraft plugs
    Replaced plug wires
    Replaced fuel filter
    Inspected ignition coil (looks good-no visible cracks, etc.)
    Inspected vacuum hoses
    Monitored the fuel presure with Auto Tap scan tool under actual driving conditions - Fuel pressure fluctuated between 37 and 44 PSIG
Any suggestions on where to go from here???????????????????????
Thanks!!!
NKENN is offline
Old 01-01-2008, 10:04 PM   #2
ProSilverVT02
ProSilverVT02's Avatar
Fan#: 33656
What I Drive: 2002 SVT
FF Reputation: 7 ProSilverVT02 Good Standing Member
Buy-Sell-Trade Rating: (8)
I had the same problem. It could be a number of things. In my case, like yours, I had no check engine light. Checked under the hood and my throttle position sensor was cracked. Got a new one and ran good for about 2 days and then the problem returned. This time I had a crappy idle. Checked my Mass Air Flow sensor and decided to clean it. With the new TPS and clean MAF my problem was resolved.
Since you are specifically having acceleration problems it sounds like the fuel pump. I've seen around the forum that 2000's are known for having fuel pump problems. Even though you've already had it replaced, it may be the cause of your problem.
ProSilverVT02 is offline
Old 01-02-2008, 12:21 PM   #3
cafociguy
cafociguy's Avatar
Fan#: 21858
What I Drive: 01 ZX3, 03 ZX3 PWSCed
FF Reputation: 46 cafociguy Great Standing Member
Buy-Sell-Trade Rating: (4)
fuel pump or fuel filter is what it sounds like to me, but could be a MAF connection or just might need a cleaning.
cafociguy is offline
Old 01-03-2008, 11:19 AM   #4
Jblackrose
Fan#: 46242
What I Drive: 2003 ford focus se
FF Reputation: 1 Jblackrose Good Standing Member
sounds a bit like my car too
2003 SE model.
All I have done is replace the Fuel Filter
mine is still hurky jerky at times. but this does not happen all the time.
very weird. No check engine light is on.
keep me posted,
Joe Black Rose
Jblackrose is offline
Old 01-03-2008, 12:09 PM   #5
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
I would guess your clutch is slipping, or you have no friction surface left on the clutch or flywheel.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 01-14-2008, 03:32 AM   #6
svteric
svteric's Avatar
Fan#: 42526
FF Reputation: 9 svteric Good Standing Member
I am having the same problems too!
Dynoed 279hp and 224tq in 111 degree weather
(MODS):Magnaflow catback, vortech w/aftercooler, diablosport tuner, 67mm tb, 70mm MAF, k&n filter,55lb injectors, all three performance mounts, short throw shifter, 5.7" crank pulley
svteric is offline
Old 01-14-2008, 05:37 PM   #7
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
What I Drive: 04 silver SVT Focus
Points 6,732, Level 53
Points: 6,732, Level: 53 Points: 6,732, Level: 53 Points: 6,732, Level: 53
Level Up 91% Completed
FF Reputation: 4 ChrisRobin Good Standing Member
The only time I noticed it on mine (if I'm talking about the same thing here), is if I'm in 2nd or 3rd, I don't remember which one, and my rpm's are too low. As in I should be in a lower gear. Upon acceleration it bucks a little until back up to higher rpm's. But that's probably just me not paying attention to my shifting.
ChrisRobin is online now
Similar Threads
bucking at 2.200 rpm | ford racing plug wires TEAM ST General Technical Chat 8 08-28-2007 12:38 PM
Need some input for more acceleration!!! teamrc49 Ford Focus & General Car Chat 2 05-07-2007 03:18 PM
Problem with acceleration darkproximity SVT Performance (2002-2004) 24 10-07-2006 02:32 AM
Loss of acceleration uphill, hesistation, engine light.. -diVe- General Technical Chat 7 05-30-2006 09:51 PM
I have lost my acceleration......help stxen12 ZETEC Performance (2000-2004) 16 06-12-2004 12:21 PM
