fan switch or blower relay - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-17-2004, 05:54 PM   #1
needin help
Fan#: 7899
What I Drive: 2001 zx3 s2
FF Reputation: 1 needin help Good Standing Member
I HAVE A 2001 ZX3 S2 FOCUS THE FAN SWITCH ONLY WORKS ON 4 NONE
OF THE OTHER SETTING WORK ALSO WHEN THE SWITCH IS ON LEVEL 1,2,OR 3 THE AC COMPRESSOR WILL RUN ON LEVEL 4 THE AC COMPRESSOR TURNS OFF
WHATS BROKEN HERE I CAN REPLACE PARTS BUT CANT AFFORD TO GUESS
Truely hopeless
needin help is offline
Old 05-17-2004, 11:30 PM   #2
Ripinosu
Ripinosu's Avatar
Fan#: 4803
What I Drive: Infrared 2004 ZTW called Elise
FF Reputation: 1 Ripinosu Good Standing Member
Don't use caps. I'm sorry I cannot help, but I'm interested in the solution also. Good Luck!!!
Ripinosu is offline
Old 08-08-2004, 03:47 PM   #3
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
Resistor pack in switch
nilskje is offline
Old 08-08-2004, 04:03 PM   #4
centers1d10t
Fan#: 4450
What I Drive: 03 SVTF ZX5 #1011/2173
FF Reputation: 1 centers1d10t Good Standing Member
Its sounds like it is the blower resister, if your car has one. I know Mazda trucks were notorious for this same type of issue in the late 80's and early 90's. I would call your local dealer parts dept. and ask them to look this part up for you (I am almost certain that this will be a dealer item only probably $25-$50), and if your car does have a blower resister ask your parts guy if he has seen this issue before.
centers1d10t is offline
Old 08-09-2004, 01:07 AM   #5
sieben
sieben's Avatar
Fan#: 8152
What I Drive: 2004 Liquid Grey ZTS Sedan
FF Reputation: 1 sieben Good Standing Member
replace resistor, better safe than sorry, last time I looked it was like $8. I have not seen this problem so much with the focus's, more with escorts and contours, but I'm sure ford hasn't changed the design too much. I know with the contours they actually had a problem with the wiring and had a recall on both. but no such luck with the focus. but when you change the resistor check the wire to it and make sure the connector isn't melted.
sieben is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
Heater fan blower problem Skibu General Technical Chat 2 07-07-2010 05:06 PM
Fan...blown relay...sensor...overheating hugging corners General Technical Chat 6 10-28-2008 10:36 PM
Blower switch and cooling fans monbenkey General Technical Chat 5 01-17-2008 03:41 PM
