Code PO171 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 12-29-2007, 02:48 PM   #1
bigdaddy73
Fan#: 52498
What I Drive: 2000 Grey ZX#
FF Reputation: 1 bigdaddy73 Good Standing Member
Unhappy Code PO171
I really need help on this one i know what the code means but having a hard time solving it. I've changed the bank i oxygen censor and i am about to change my temp censor, did a fuel treatment, air filter replacement and now i'm stumped. Was told to change the fuel filter. Parts are starting to get expencive. The car runs fine when you first start it cold but when it heats up it sputters and sometimes cuts out, While your driving it is fine, happens when you stop or just idling. Engine light is on and as i've mentioned the code is PO171. Someone please lead me in the right direction. Your help is greatly appreciated.
bigdaddy73 is offline
Old 12-29-2007, 03:03 PM   #2
Eleanor Focus
Eleanor Focus's Avatar
Fan#: 34501
What I Drive: 2005 LG ZX5 LOTH # 27
FF Reputation: 6 Eleanor Focus Good Standing Member
Buy-Sell-Trade Rating: (14)
that would be a System too Lean (Bank 1) code
A code P0171 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters (K&N, etc.) can cause the MAF to become dirty if the filter is over-oiled
There could be a vacuum leak downstream of the MAF sensor.
Possible SolutionsPossible solutions include:
In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect all vacuum and PCV hoses, replace if necessary
Check for a dirty fuel filter and proper fuel pressure
If you don't stand behind our troops, please feel free to stand in front of them! Cosworth CAI & Cat Back Exhaust, 17" Konig Theory Wheels, SAP Package, SVT Parts, 35% Tint, Silverstar Headlights and Front Turns, KYB AGX Suspension, KW Springs
Eleanor Focus is offline
Old 12-29-2007, 10:29 PM   #3
04SVTZX5
Fan#: 47605
What I Drive: 2013 Black Focus ST
FF Reputation: 1 04SVTZX5 Good Standing Member
I had the PO171 code on my 2002 ZX5 when it hit 90K. It ended up being a PCV line that collapsed.The line that runs behind the engine and is attached around the middle of the engine under where the Throttle body sits. I changed that line and that was it. Check it out.
04SVTZX5
04SVTZX5 is offline
Old 12-30-2007, 08:34 AM   #4
bigdaddy73
Fan#: 52498
thanks for you input, will give it a try see what happens.
Similar Threads
Check Engine - PO171 Code Babs64 General Technical Chat 10 04-21-2013 06:06 PM
Need Ford Recall, TSB, or your vehicle history? Click Here! DJ Lukdogg General Technical Chat 368 10-13-2008 06:04 PM
03 focus svt check engine code P0304 cyl 4 misfire tanya_03svt General Technical Chat 3 06-27-2007 11:08 AM
code PO171 HELP WhiteGTDropTop General Technical Chat 8 05-15-2007 11:09 AM
SVT Header swap. Help me Troubleshoot a DTC P2195 Code starfuryt550 General Technical Chat 11 05-03-2007 10:09 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
