Old 12-28-2007, 08:09 PM   #1
plmac7880
Fan#: 51940
What I Drive: 2000 SE silver my Daughters car
FF Reputation: 1 plmac7880 Good Standing Member
Oh No, Stripped water pump bolt
156 IN LBS my...... alright, while installing a new water pump I stripped the front lower bolt hole. Has anyone used a Helicoil in the pump housing? Not much metal there to work with, any sugestions? Pretty tight place to work too.
plmac7880 is offline
Fan#: 1
Old 12-28-2007, 09:21 PM   #2
focusguy87
I AM DA FOCI FANATIC
focusguy87's Avatar
Fan#: 40962
What I Drive: 03 Red EvO & 03 TURBO SVT
FF Reputation: 9 focusguy87 Good Standing Member
Buy-Sell-Trade Rating: (6)
Tap Dye kit? will that work?
FOR SALE,
2003 Turbo SVT ZX5 318WHP (SOLD)
2003 Evolution 8 320AWHP
focusguy87 is offline
Old 12-28-2007, 10:42 PM   #3
plmac7880
Fan#: 51940
I,ll try that first, and go up to the next size bolt. That would cut less material than a helicoil. Have you ever tried the epoxy thread repair? It sounds like a bandaid, I'll have to read up on it. Thanks
Old 12-29-2007, 12:23 AM   #4
viney266
Moderator
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
FF Reputation: 112 viney266 Excellent Standing Memberviney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
I have used the epoxy thread repair on two-stroke cylinder heads. It works pretty well, MAKE SURE you use enough of the release agent on the bolt threads... It held a spark plug in on a vintage aluminum 2 stroke head.
Try just chasing the threads with the same size tap first, unless you truly wiped out the threads.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 12-29-2007, 08:48 AM   #5
plmac7880
Fan#: 51940
Sounds good, I'll try to chase the threads. Thanks for the info.
Old 12-30-2007, 08:43 AM   #6
plmac7880
Fan#: 51940
Ended up using the epoxy thread repair kit. It worked great.
Old 12-04-2011, 10:07 PM   #7
stonecold
Fan#: 92372
What I Drive: 2001 blue SE Zetec
FF Reputation: 1 stonecold Good Standing Member
Stipped water pump bolt on Zetec 2001 focus
I had the same issue. 156 in-lb has to be a typo in the Haynes manual; way too high. Theere is no way the M6 x1 bolt threaded into an aluminum pump housing (4-5 threads) should expect to withstand this much torque.
I used an M6 x 1 Hel-coil kit purchase off the internet. Since I was also replacing the timing chain, all I had left was two bolts to remove the water-pump housing. So, I made the thread-repair on my bench. Drill out the stripped threads with 1/4" drill bit, tap the threads, screw in the heli-coil (the kit tool compresses the coil to make it easier to insert), break off the coil tang, you are good to go. I believe I torqued to about 90 in-lb I believe max for an M6x1 is around 106 in-lbs. I also used Permatex thread locker.
This link covers use of the heli-coil tool, watch the video. http://www.repairengineering.com/helicoil.html
stonecold is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 10:54 PM
Will it fit? CheckMyVitals MK1 Focus 14 08-12-2005 02:55 PM
water pump focuszx3r General Technical Chat 3 11-22-2003 02:55 PM
FC water pump pulley? silverfoci ZETEC Performance (2000-2004) 9 09-17-2003 01:22 AM
