Ask your spark plug, wires and coil questions here - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-25-2008, 10:11 PM   #61
svtfocusmansvt
Fan#: 6548
What I Drive: 04' Pitch Black SVTF ZX3
FF Reputation: 1 svtfocusmansvt Good Standing Member
If you have the stock wires and coil pack stay @ stock gap. For nitrous you must run copper (but only lasts nearly 5k or so on fuel injected / electronic ignition type vehicles) AZFS22C is whats needed (get from Ford) but if what everyone is saying it true on the price go with C-F-M, in theory for every 50 HP run 1 heat range COLDER. Those plugs are copper plugs and are actually for the ZX3 2.0 @ 1 heat range difference. If you have a Turbo then things change.
svtfocusmansvt is offline
Old 01-25-2008, 10:17 PM   #62
SVT_Turbo
SVT_Turbo's Avatar
Fan#: 45979
What I Drive: 2002 SVT Focus & 2009 Hayabusa!
FF Reputation: 2 SVT_Turbo Good Standing Member
what about the ITV22 denso Iridiums and close the gap to .044????
GROWING OLD IS MANDATORY ... GROWING UP IS OPTIONAL
RIP Travis.... Best Brother/Co-Pilot one could ever ask for. Love Ya Dude
SVT_Turbo is offline
Old 01-25-2008, 10:27 PM   #63
svtfocusmansvt
Fan#: 6548
Stock Focus = IVT20
SVT Focus = IVT24
I have no idea what the IVT22 is for or what heat range its at, if its the same size plug, I would assume its not the correct heat range for the fact the higher the number the lower the heat, but thats just assuming the 24 is the colder and the 20 is 1 hotter. For nitrous you need to run copper to get the most from it, iridium may be too hot also for the nitrous. Bottom line is AZFS22C and no problems will happen, I have 44k on mine and runs as good as new, I've had my fair share of plugs but compression and all is GREAT.
Old 01-25-2008, 10:46 PM   #64
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
There is no "step" when rating spark plugs; it's just a term thought up by what seems to be the majority of people who don't know what the actual heat ranges of the plugs are.
If you want, you can equate the Denso numbers as "steps." ITV20 is stock, 22 is 1 step colder, 24 is two steps colder, etc. Just keep in mind, there is no definition of a "step."
Furthermore, the Screamin Demon ignition coil puts out nearly identical voltage as the stock ignition coil, and I've proven that the LiveWires are horribly inefficient compared to a good wire like Taylors. To expand on this, no stock replacement ignition coil "needs" a specific plug gap. As long as you can get a consistent spark, you can gap the plugs as far apart as possible. On a stock SVTf, this is typically between .060" and .065". On a boosted motor, it is significantly lower: more like .040". You will also need a colder heat range plug. In order to increase the gap for better combustion while boosting, you need to upgrade the entire ignition system.
CaysE is offline
Old 01-25-2008, 10:54 PM   #65
svtfocusmansvt
Fan#: 6548
I disagree have you actually tested the secondary voltage with a DVOM? As far as steps goes you are correct every company is different, but the SVT is only 1 heat range difference than the standard. Also the hotter the coil the more thats allowed to gap which increases the combustion of the plug, so yes you could stay @ the stock gap but can increase with a higher number to a point of loss. On boosted I could see that cause the lower compression and retarted timing. A screamin demon is an upgraded ignition, every system can only get the 12v reference its the output that changes. That doesnt answer my question to can it be gapped and what preferred. Heat range is too hot = holes in pistons. And the heat range change per 50 is also a major deal.
Old 01-26-2008, 08:27 AM   #66
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
Iridium plugs shouldnt be regapped... they are fragile and tend to both flake and break.... Personally I think they are way over rated.
The only time you should regap plugs is when you start getting spark blowout... usually caused by alot of boost or a large shot of nitrous. The bigger the gap the more power you will make so you should run as large a gap as possible (without getting blowout)
The majority of boosted Foci run the AZFS22C plugs and they work great up to 720whp (that we know of) and we dont worry about heat ranges or upgrading the coil.... usually we just do plugs and wires and run the stock coil (which does a great job)
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 01-26-2008, 11:53 AM   #67
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
A Screamin Demon is not an upgraded ignition; it's a piece of garbage. An MSD DIS-2 is an upgraded ignition.
CaysE is offline
Old 01-26-2008, 12:16 PM   #68
focusboypr
Fan#: 51154
What I Drive: 2004, white, ZX3
FF Reputation: 1 focusboypr Good Standing Member
I own a 2004 zx3 and I just changed the spark plugs and I am thinking of chainging the spark plugs wires as well. what do you think about the ebay spark plugs? are they any good? are they to cheap to be true?.
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
focusboypr is offline
Old 01-26-2008, 12:22 PM   #69
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
Taylor Thundervolts are my recommendation. jegs.com or summitracing.com
CaysE is offline
Old 01-27-2008, 08:58 PM   #70
SVT_Turbo
SVT_Turbo's Avatar
Fan#: 45979
MSD Wires are really good and if the coil starts going bad i would prolly get the ACCEL 4-Tower coil, but thats only if i had to change the stock one, cause i tried the MSD and there was no difference on the car other than the fact it wouldnt stay plugged in and i would be cruisin down the road and the car would skip a beat and shut off from not having any fire
Similar Threads
DTC P0351 - Ignition Coil "A". At the end of my rope. superbeast04 General Technical Chat 17 08-20-2012 07:33 PM
SVT Spark Plug Wires and plugs? rfinger SVT Performance (2002-2004) 16 11-28-2007 03:09 PM
svt grill, svt cat, svt plug wires and coil... my 2003SVT Archive 13 11-28-2006 09:43 PM
For Sale: Stock SVT spark plugs, plug wires, and Distributor!! my 2003SVT Archive 4 05-04-2006 03:55 PM
Spark Plug Wires and Grounds Question Oni SVT Performance (2002-2004) 20 01-20-2006 09:00 PM
