Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 06-29-2010, 04:15 PM   #381
superunkn0wn
superunkn0wn's Avatar
Fan#: 75120
What I Drive: 2011 Mazdaspeed3
FF Reputation: 1 superunkn0wn Good Standing Member
Originally Posted by pstrjeff View Post
I have oil sitting in the tube where my spark plug wires go. How do i fix that?
You need to replace your valve cover gasket. Oil from around your camshafts is seeping down into the spark plug area through a tear or separation in the gasket.
From what I've read, a bad VCT solenoid can also leak oil. That's the module to the left of your spark plug wires when you remove the black plastic "Powered by SVT" cover from the valve cover. I believe you would be able to see a trail of oil leading back to the VCT module if this is the case.
superunkn0wn is offline
Old 07-04-2010, 01:27 PM   #382
Drago22
Drago22's Avatar
Fan#: 67556
What I Drive: 2004 Cd Silver Svt ZX3 EAP
FF Reputation: 1 Drago22 Good Standing Member
Question, my SVT has forced induction(Pwsc), I have Taylor wires and Azfs22c copper plugs, my ? is what should my plug gap be at, currently .60 is thatr ok for a supercharger?
Drago22 is offline
Old 07-06-2010, 04:37 PM   #383
WD40
The Librarian
WD40's Avatar
Fan#: 5157
FF Reputation: 136 WD40 Excellent Standing MemberWD40 Excellent Standing Member
.060 is what you really mean.
Regardless, that is generally way too big of a gap for forced induction and will cause missfire issues.
.035-.040 is a more typical FI gap.
(You can find further info on what gap to use in the Forced Induction Chat forums)
http://www.focusfanatics.com/forum/f...splay.php?f=44
WD40 is offline
Old 07-06-2010, 11:19 PM   #384
Drago22
Drago22's Avatar
Fan#: 67556
Thanks WD-40 I've been unsure about that for a while, when I nchanged plugs I mistakely followed the guy that owned it before when it came to the gap, two plugs were at .060 and two were at .055. It does like to stumble when I rev the motor and the rpms drop down it will go down below idle speed about 150 rpms, stumbles almost stalling out then picks up to a normal idle, is that result of the plugs being gapped wrong or something else? Thanks for the info.
Drago22 is offline
Old 07-07-2010, 12:55 PM   #385
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^Not sure about the idle symptom.
But, I do know that .055-.060 is too large a gap for FI.
(Again, I'd check on those forums for the exact gap to go with)
This is the NA (Naturally Aspirated) section.
WD40 is offline
Old 07-08-2010, 12:34 AM   #386
Tyler T
Tyler T's Avatar
Fan#: 42066
What I Drive: two '02 SVT's
FF Reputation: 2 Tyler T Good Standing Member
the 411 on spark plugs: http://www.motorsport-developments.c...AF272_tech.pdf Iridium is preferable because the thinner center electrode diameter allows for a higher quality spark and because iridium degrades much slower than copper it allows you to run a larger gap (or just replace your coppers constantly). Also the AZFS22C is the proper heat range for a regular Zetec but I don't think it is the proper heat range for a SVT. http://sparkplugs.com/results_app.as...1&AAIA=1385580 also helps out a lot for the specs for different plugs and they have some of the best customer support I have ever worked with.
tyturnbull.com
understeering? visit FealSuspension.com
for quality repairs and modifications in the LA area: StevesAutoClinic.com
Tyler T is offline
Old 07-15-2010, 09:40 PM   #387
drumminator
drumminator's Avatar
Fan#: 74444
What I Drive: 2004 Focus SVT
FF Reputation: 1 drumminator Good Standing Member
so i bought some champion plugs they are the closest ones to stock i could find (all that advanced auto had)and i cant remember the size of the gap on the stock plugs but these champion ones i bought are .001 either larger or smaller is this going to make a difference?
drumminator is offline
Old 07-16-2010, 08:43 AM   #388
macdiesel
I drive this!
macdiesel's Avatar
Fan#: 31579
What I Drive: Haggard Infra-Red SVT 2K2 #2633
FF Reputation: 21 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (11)
Always measure pregapped plugs. They get tossed around a bit before customers get their hands on them.
"When does the zetec kick in"
Asked by a Honda enthusiast
macdiesel is offline
Old 07-16-2010, 08:45 AM   #389
JeepXJ
JeepXJ's Avatar
Fan#: 48404
What I Drive: 03 Pitch Black SVTF
FF Reputation: 2 JeepXJ Good Standing Member
Buy-Sell-Trade Rating: (6)
^^ x2
Can I use CFM, or Taylor wires on my MSD coil?
67mm TB port matched manifold, AEM CAI, FS UDP, Tune, CFM STS, MSD Coil & Wires
linux user
JeepXJ is offline
Old 07-20-2010, 06:19 AM   #390
Chas
Licensed Shrink
Chas's Avatar
Fan#: 49800
What I Drive: 2004 Sonic Blue SVT ZX5
FF Reputation: 1 Chas Good Standing Member
i just installed copper plugs and taylor wires this week and it is GREAT. i have not gapped the plugs and probably wont because im lazy and the closest auto store is about 20 mins from me. anyway, i paid 8 shipped for my motorcraft coppers, DO NOT buy them from cfm or fswerks or even a ford dealer, just look on amazon and ebay. they are simple plugs you cant go wrong on those sites. i just paid like 60 bucks for the best tune up. plus the taylor wires look sweet and match my car! :)
Hatch Nation #22
04 ZX5 SB SVTF. K&N Drop-In, CFM Race HFC, CFM Flex, 2.5 Trubendz Exhaust, Tom's Tune, Eibach Lowering Springs.
Originally Posted by ah1f39 View Post
What happens in the cave. Stays in the cave.
Chas is offline
Similar Threads
DTC P0351 - Ignition Coil "A". At the end of my rope. superbeast04 General Technical Chat 17 08-20-2012 06:33 PM
SVT Spark Plug Wires and plugs? rfinger SVT Performance (2002-2004) 16 11-28-2007 02:09 PM
svt grill, svt cat, svt plug wires and coil... my 2003SVT Archive 13 11-28-2006 08:43 PM
For Sale: Stock SVT spark plugs, plug wires, and Distributor!! my 2003SVT Archive 4 05-04-2006 02:55 PM
Spark Plug Wires and Grounds Question Oni SVT Performance (2002-2004) 20 01-20-2006 08:00 PM
