#311 | ||||
The Librarian
Lose the Bosch plugs, and your problem will most likely go away.
If you look through this thread there's a few others that tried the Bosch plugs, and had pretty much the same result as you.
WD40 Reverend GripShift - FF Moderator Member's Rules and Signature Guidelines Member FAQ and Information Archive Complete 'How To' Archive Complete Acronym/Abbreviaton and Forum Terminology List |
#312 | ||||
pwned
Do most of you guys that use the Autolite 104's get the copper or platinum ones? Also how often should these be changed?
#313 | ||||
Coppers should be checked at every oil change, but can usually last 20-30k miles if the heat range is correct. Platinums probably last about twice as long.
#315 | ||||
The Librarian
We have the Zetec engine, not the Duratec.
#316 | ||||
ohhh burned! well not really but its seemed to fit lol.
67mm TB port matched manifold, AEM CAI, FS UDP, Tune, CFM STS, MSD Coil & Wires linux user |
#317 | ||||
Do you guys think this set-up would be fine for my svt massive MSX 90 wires (In orange) and the copper plugs. Has anyone used the massive 90 wires?
#318 | ||||
I can see this thread is a couple of years old, so I don't know if any one will see this.
I have a stock 2002 zx3, and I'm going to do my own tun-ups. I would like to put the best plugs and wires in it without dropping a lot of unnecessary money. In trying to get some info off the web I came across a "fact sheet" by magnecore. Do I really need to spend that kind of money to get good wires, or will a set of ngk's or the like do me? Also, should I get motorcraft copper plugs, or are those best suited for the racing and performance cars only? Any info would be a great help. Thank you. |
#319 | ||||
LETS TURN DIRT!!!!
There's nothing wrong with running a copper plug in a Focus be it "high performance" or an every day non-modded driver.
There are advantages and disadvantages to both... the coppers carry better spark but the plats last longer.... the plats cost more but you should replace the copper more often. Personally I run the coppers and have for a few years without any bad side effects.
[B]1951 McCormick FARMALL M 2007 MINI Cooper S Turbo... new project car 1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel 2004 Harley V-Rod.... sex on wheels 2011 Harley Electra Glide Ultra Limited [/b] |
#320 | ||||
Nevermind.
'02 Infa Red SVT #3564 T-Minus 2 months until the new house is done, YES! MY OWN DRIVEWAY AND GARAGE! |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| DTC P0351 - Ignition Coil "A". At the end of my rope. | superbeast04 | General Technical Chat | 17 | 08-20-2012 06:33 PM |
| SVT Spark Plug Wires and plugs? | rfinger | SVT Performance (2002-2004) | 16 | 11-28-2007 02:09 PM |
| svt grill, svt cat, svt plug wires and coil... | my 2003SVT | Archive | 13 | 11-28-2006 08:43 PM |
| For Sale: Stock SVT spark plugs, plug wires, and Distributor!! | my 2003SVT | Archive | 4 | 05-04-2006 02:55 PM |
| Spark Plug Wires and Grounds Question | Oni | SVT Performance (2002-2004) | 20 | 01-20-2006 08:00 PM |
