Ask your spark plug, wires and coil questions here - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-13-2008, 02:48 PM   #111
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^Yes...those are the same exact plugs that many of us are running.
WD40 is offline
Old 03-21-2008, 02:24 AM   #112
ruststang94
ruststang94's Avatar
Fan#: 18710
FF Reputation: 1 ruststang94 Good Standing Member
I'm looking on C-F-M's website for wires. They have msd 8.5mm for $50 and cfm performance wires 8mm for $39. So are the MSDs worth the extra $10 for the .5mm? Also what are the stock wire size? Thanks
ruststang94 is offline
Old 03-21-2008, 03:11 PM   #113
noblesteed
Fan#: 47116
What I Drive: 2002 Black SVT
FF Reputation: 1 noblesteed Good Standing Member
pelotonracer2 you mentioned something about facing the spark plugs the same way, what does that do? and was it the gap side facing the exhaust ports? And do you have a part number for that MSD coil?
noblesteed is offline
Old 03-22-2008, 05:10 PM   #114
SVT-SAGE
Fan#: 43249
What I Drive: 2003 Pitch Black SVTF
FF Reputation: 15 SVT-SAGE Great Standing Member
Buy-Sell-Trade Rating: (17)
Its called indexing, you face the tip of the spark plugs toward your intake manifold, supposed to help with combustion, its some old school hot rodder trick.
SVT-SAGE is offline
Old 03-25-2008, 11:31 AM   #115
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
Actually you are suppose to face the spark plug opening toward the exhaust valves... that way when they ignite the "explosion" is already traveling towards to exhaust valves as they are opening, thus giving you better scaveging and a higher exhaust flow rate.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 03-28-2008, 08:23 PM   #116
Hempster
Hempster's Avatar
Fan#: 29310
What I Drive: 2014 Tuxedo Black Focus ST3
Points 739, Level 14
Points: 739, Level: 14 Points: 739, Level: 14 Points: 739, Level: 14
Level Up 39% Completed
FF Reputation: 3 Hempster Good Standing Member
Hi There, After waiting far too long I recently did some spring cleaning and changed my fuel filter, plugs (Motorcraft Coppers gapped to .060) I haven't noticed any real difference. It feels a little sluggish and even had a bit of pinging launching up a steep incline last weekend (the first I've ever noticed). My plats had over 100.000km's on them before I changed them out, but I haven't changed the plug wires though. (I have 2 year old Steeda's and a new set of Taylors Thundervolts waiting in the wings) I just want to know if I should be adjusting the gap smaller before I change my wires or if the wires might be the reason for the sluggish mid RPM feeling I am experiencing? I thought I would notice more than just a smoother idle.
Tuxedo Black 2014 Focus ST3
CD Silver 02 SVTF, #1336 - R.I.P.
"Brace for the G's, and fast heel-toe work!"- Hunter S. Thompson
Hempster is offline
Old 03-28-2008, 09:07 PM   #117
03OrangeSVT
LETS TURN DIRT!!!!
Fan#: 19169
Have you reset the ECU yet?? sometimes after changing out the filter you need to reset the ECU so it will relearn your fuel maps.
You shouldnt have to close the gap, I would go ahead and do the wires the same time you reset/clear the ECU and see what it does then... sometimes the Focus needs to "unlearn" the trends that the ECU has picked up over the years.
[/b]
Old 03-28-2008, 09:10 PM   #118
Hempster
Hempster's Avatar
Fan#: 29310
I did unhook the battery for at least an hour or two. Is there any formal procedure for resetting, I just hooked it up and started to drive. I thought it seemed better at first, but it has been feeling pretty slugish, like I mentioned, for a couple of weeks now, mainly in the mid RPM's, WOT doesn't seem too bad.
Hempster is offline
Old 03-28-2008, 09:13 PM   #119
03OrangeSVT
LETS TURN DIRT!!!!
Fan#: 19169
5 minutes is plenty long enough.
Have you bought gas from a different place or went with a lower octane lately??
I'm just asking since most people get a smoother idle and better responce when they change the gap on thier plugs.... then again you may have a wire getting weak or maybe the coil is a little weak.
Its hard to tell without seeing the car in person... these are just a few things to consider.
[/b]
Old 03-28-2008, 09:48 PM   #120
Hempster
Hempster's Avatar
Fan#: 29310
By "formal procedure", I'm meaning, do I have to let it idle for a certain legnth of time before I start driving again? I read somewhere on this site, that I should! Also, no on the gas! I use mainly Shell 91oct or sometimes Chevron's 93, I haven't noticed any differance with either.
Hempster is offline
Similar Threads
DTC P0351 - Ignition Coil "A". At the end of my rope. superbeast04 General Technical Chat 17 08-20-2012 07:33 PM
SVT Spark Plug Wires and plugs? rfinger SVT Performance (2002-2004) 16 11-28-2007 03:09 PM
svt grill, svt cat, svt plug wires and coil... my 2003SVT Archive 13 11-28-2006 09:43 PM
For Sale: Stock SVT spark plugs, plug wires, and Distributor!! my 2003SVT Archive 4 05-04-2006 03:55 PM
Spark Plug Wires and Grounds Question Oni SVT Performance (2002-2004) 20 01-20-2006 09:00 PM
