Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 12-19-2007, 11:08 PM   #1
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member03OrangeSVT Excellent Standing Member
Exclamation Ask your spark plug, wires and coil questions here
I've decided to make an "ignition" thread.
and post up answer's to the more commonly asked questions.
Do I need to upgrade my coil?
Simply put.... No
Stock coils will provide enough spark to support over 700whp. The average 4 tower coil will put out between 36-40k volts most aftermarket coils put out only 42k MAX. You will not see any gains what so ever by swapping out a working stock coil for an aftermarket one.
Do I need to go with those really expensive plugs?
Again.... No
Unless you have a HEAVILY Modded (MORE THAN BOLT ONS) engine there is no need to use any other plug than STOCK. You CAN re-gap the stock plugs to .060 (in most cases) and you will get a smoother idle and the overall running of the car will be improved... but just slightly. When you open up the gap it take MORE voltage to jump the gap and make spark.. therefore wider the gap the hotter the spark.
Now if you are running Nitrous of Forced Induction then yes you can benefit from changing plugs. I highly recommend the MotorCraft AZFS22C f4 sparkplugs. They are copper cored (which is one of the BEST conductors of electricity.. better than Iridium) and will provide a wider,stronger spark. They also work VERY well with NA engines,and at $8 a set you cant go wrong.
Should I change plug wires?
Yes
Changing your plugs wires is problely the most effective ignition upgrade you can do on a Focus. Any descent low resistance wire is MILES beyond the stock wires... I can not say how much I despise stock wires for there inability to carry good voltage. Remember the bigger the wire the better... smaller wires will heat up internally and heat greatly reduces their ability to conduct electricity.
Well thats your basic ignition questions covered... feel free to ask any questions that you have.
John
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Fan#: 1
Old 12-19-2007, 11:27 PM   #2
egman2005
Slow n lifted
egman2005's Avatar
Fan#: 44983
What I Drive: 2003 SVT Focus
FF Reputation: 21 egman2005 Great Standing Member
Buy-Sell-Trade Rating: (7)
great thread! now it needs a sticky!!!!!!!!
egman2005 is offline
Old 12-19-2007, 11:31 PM   #3
03OrangeSVT
LETS TURN DIRT!!!!
Fan#: 19169
I can do that....... let me wave my magic wand.... sprinkle some fairy dust.... and abera cadabera [poof] now its a sticky!!!
[/b]
Old 12-19-2007, 11:40 PM   #4
egman2005
Slow n lifted
egman2005's Avatar
Fan#: 44983
LOLZ! you having fun tonight john????? can i have some fairy dust! i wanna make a turbo kit and built motor appear!
Old 12-20-2007, 12:07 AM   #5
03OrangeSVT
LETS TURN DIRT!!!!
Fan#: 19169
NO Egman... My Fairy Dust!!! <---- Cheap Cartman immatation
[/b]
Old 12-20-2007, 11:05 AM   #6
WD40
The Librarian
WD40's Avatar
Fan#: 5157
FF Reputation: 136 WD40 Excellent Standing MemberWD40 Excellent Standing Member
The new part number for the copper Motorcrafts is: SP-463
Some Dealers and Parts Stores will be able to cross reference to the old AZF--- number, but if not, use the new one.
I'd also add, that NA cars do extremely well with the Motorcraft copper plugs.
They're cheaper, and provide better spark than the stock platinums.
More often than not when it's time to change plugs, members are using the copper plugs.
As far as openning the gap to .060.
That's generally done when swapping in the Motorcraft copper plugs,
and not neccessarily with the factory platinum plugs.
Openning the gap also goes hand in hand with swapping in better plug wires.
WD40 is offline
Old 12-20-2007, 03:59 PM   #7
03OrangeSVT
LETS TURN DIRT!!!!
Fan#: 19169
Actually I have done the .060 gap on the plats with very good results in several other Foci.
[/b]
Old 12-20-2007, 04:16 PM   #8
Hamrhead
Hamrhead's Avatar
Fan#: 15106
What I Drive: '09 Cobalt SS '08 Viper
FF Reputation: 1 Hamrhead Good Standing Member
Just picked up the Motorcraft Copper Plugs today, along with a fuel filter.
Wasn't really planning on wires, but since I'll be tearing into it anyway,
What Wires are recommended?
and,,,
Got a link on a supplier by chance?
TIA
'08 Viper SRT-10 Coupe
'04 CTS-V
Hamrhead is offline
Old 12-20-2007, 04:24 PM   #9
WD40
The Librarian
WD40's Avatar
Fan#: 5157
I really like the Taylor wires:
http://www.focusfanatics.com/forum/s...ad.php?t=55133
^^^Lots of pics and links in the latter half of the thread.
That's good to know.
I'm just personally not a fan of the platinums, especially when considering the performance to price ratio.
WD40 is offline
Old 12-21-2007, 05:06 PM   #10
Hamrhead
Hamrhead's Avatar
Fan#: 15106
Ordered a set from Summit today. The 8.2mm RED wires. $46 and change plus the $10 'Handling' charge.
Lots of good info on the link you provided - Thanks!
Now I can't wait to get them installed with the new plugs!
Anything special I need to know about changing these plugs/wires? Special Tools?
I've been changing them for years on OHV V6's/V8's/V10's, but this will be my first on a Twin-Cam engine.
'04 CTS-V
Hamrhead is offline
Similar Threads
DTC P0351 - Ignition Coil "A". At the end of my rope. superbeast04 General Technical Chat 17 08-20-2012 06:33 PM
SVT Spark Plug Wires and plugs? rfinger SVT Performance (2002-2004) 16 11-28-2007 02:09 PM
svt grill, svt cat, svt plug wires and coil... my 2003SVT Archive 13 11-28-2006 08:43 PM
For Sale: Stock SVT spark plugs, plug wires, and Distributor!! my 2003SVT Archive 4 05-04-2006 02:55 PM
Spark Plug Wires and Grounds Question Oni SVT Performance (2002-2004) 20 01-20-2006 08:00 PM
