The Importance of Toe-in or Toe-out - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-11-2008, 11:00 AM   #21
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
You should not have toe out, the recommended spec is slightly toe-in. .15 degrees, or .04 inches.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 01-11-2008, 11:47 AM   #22
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
A toe and/ or camber problem would cause, more or less, even wear around the entire circumference of the tire and localized to the inside or outside tread edge. If the tire was out of balance or if the shocks were bad, the wear could get wider or more pronounced in localized areas. A bad shock causes a cupping pattern around the circumference of the tread.
That said, and I'm taking a guess here, I think your problem is with the tires themselves. You either flat spotted them by locking up the brakes (only takes once) or the internal belts are separating (not as uncommon as it sounds). Either can cause the kind of wear you described. If the tires are relatively new I'd go back to the dealer for a tire inspection. Separating belts (aka de-lamination) can be determined by a visual inspection of both the inside and outside of the tire and is a warranty issue in most cases. Anyway, it sounds like you need to have them replaced.
Geezer is offline
Old 01-13-2008, 03:04 AM   #23
knoxrocks222
Fan#: 38601
What I Drive: 2003 black svt
FF Reputation: 3 knoxrocks222 Good Standing Member
damn this will be set # 4 i cant afford this anymore, anyone know where i can trade my sportlines for the pro kit
knoxrocks222 is offline
Old 01-22-2008, 03:31 PM   #24
knoxrocks222
Fan#: 38601
ok i put it up on the lift and found that the flat spots are def. on the inside of the rear tires and they look really choppy, its only one spot on each tire but it looks like someone took a meat cleaver and just hacked it up, thanks for the help
knox
Old 02-05-2008, 10:09 PM   #25
nacnudv8
nacnudv8's Avatar
Fan#: 52725
What I Drive: former owner:Pitch Black '03 SVT 3D
FF Reputation: 7 nacnudv8 Good Standing Member
Castor, Camber And Toe-in/out
I was getting a little unsure what all these terms meant, particularly the CASTOR - so I did some digging on the internet and cut & pasted and added some notes to these diagrams: Hope this helps other like me! Seems like a small pic - if someone tells me how I will try and get a bigger pic posted. I think if you click the thumbnail you get a larger view.
nacnudv8 is offline
Old 02-05-2008, 10:45 PM   #26
Pistonbroke
Pistonbroke's Avatar
Fan#: 42552
What I Drive: Black 2000 ZX3 mtx
Points 1,962, Level 26
Points: 1,962, Level: 26 Points: 1,962, Level: 26 Points: 1,962, Level: 26
Level Up 62% Completed
FF Reputation: 1 Pistonbroke Good Standing Member
At least we don't have to worry about caster on our cars as there is no adjustment. Camber can be in the ballpark but like Geezer emphazised, toe is very critical.
-There is no water holier, than the sweat off a man's brow.-
Pistonbroke is offline
Old 02-06-2008, 10:56 AM   #27
nacnudv8
nacnudv8's Avatar
Fan#: 52725
Is camber adjustable in the front and/or rear?
nacnudv8 is offline
Old 02-06-2008, 12:16 PM   #28
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Not from the factory. You have to buy aftermarket parts to adjust camber.
Egz is offline
Old 03-28-2008, 12:37 AM   #29
nicholson317
nicholson317's Avatar
Fan#: 39144
What I Drive: '00 ZX3 Arctic Silver
FF Reputation: 1 nicholson317 Good Standing Member
Just found and installed some camber plates. I'm a newb at autocross, but after some research they seemed like a good idea. I love the results..i'm set at -1.7 degrees front and -.8 rear. The handling improved signifigantly in the corners, but it is a little touchier on the highway. 3k miles later and no noticable difference in tire wear. They are basically just a steel plate that mounts to the top of your strut mount. You have to remove the mounting bolts from the upper strut plate and use the included bolts to mount the adjustable plate to the strut mount and car. Fun mod for autoxing, and pretty cheap if you DIY. Not a project for unexperienced though...compressed coil springs are no joke. Was gonna do the rear, but decided to go to the H&R coil kit first.
autocross....my newest drug
Zetec Crew #157
STS 317
nicholson317 is offline
Old 07-01-2008, 11:45 PM   #30
cheeztech
Fan#: 54828
What I Drive: 2005 Graphite Black zx4 st
FF Reputation: 1 cheeztech Good Standing Member
I've noticed on my 05 that the drivers rear is getting a lean to it. I checked over the bearing's and they seem good there's no play to it so what should I be looking at this thread has me intriged. Iam doing upgrades as things get worn and after reading alot of everyones post ( which by the way thanks to all ) I wondering where to be looking @ for the next mod so does anyone have any suggestionsfor me. I think I posted this in the right section and please feel free to backhand me if its not. Thanks again to any help thats offered because I will try it.
cheeztech is offline
Similar Threads
anyone know alot about alignments?? blackturbohatch46 Wheels & Tires 25 11-22-2007 05:24 PM
F/S: FC Rear Control Arm Toe Adjusters NEW chris-13 Archive 7 05-03-2007 09:41 PM
Is rear toe adjustable with stock suspension? brianwitt Brakes, Suspension & Body Chassis 5 02-13-2006 12:23 PM
SVT Pedals and Heel and Toe Oni Focus SVT 36 12-17-2005 02:01 AM
Heel to Toe? GaRyMaN DURATEC Performance (2003-2007) 16 10-22-2003 12:10 AM
