The Importance of Toe-in or Toe-out - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-16-2007, 03:34 PM   #11
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
Originally Posted by Geezer View Post
For 2000 to 2005 front is -.07" to 0.00" the rear is 0.04 to 0.11
A recently posted alignment printout for a 2007 was -0.1 to 0.1 front and 0.08 to 0.28 rear as the specified range.
I'm not sure what the specs are for a 2006 falls or 2008.
Note, these are all in inches.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 12-16-2007, 03:42 PM   #12
walshka07
Fan#: 48052
What I Drive: 2004 Subaru WRX
FF Reputation: 1 walshka07 Good Standing Member
there is a company called longacre they make race car set-upproducts that can easily be used for any car. well here are their toe plates
http://www.hrpworld.com/index.cfm?fo...action=product
they also make camber and caster gauges, scales, and all sorts of set-up stuff. with about 200 bucks you can get everything you need to set-up your car and align it to your own specs or accuratly set-up your car for the track or street. pays for itself on your second alignment. its pretty cool and not very hard to do, we set up a freind of mines spec miata in around 45mins and niether of us had ever done it before, im pretty sure if we did it again we could do it in about 20 mins. if you are a DIY kinda guy i recomend it. just read your manual and figure out exactly how to adjust everthing! good luck
Matt
2005 Pitch Black ZX3 - Sold = loved the car but it was plauged with factory problems, soon a Spec Focus!!!!!
2004 WRX - Downpipe + tune = AWD Fun
1993 MR2 Turbo - 300rwhp = glorious fun
walshka07 is offline
Old 12-16-2007, 03:51 PM   #13
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Absolutely correct and thanks for clarifying that. Some alignment racks still use degrees but I do not have any numbers based on those specifications..
Geezer is offline
Old 12-16-2007, 03:52 PM   #14
Geezer
Fan#: 1427
Originally Posted by Pistonbroke View Post
Geezer, after I install the SVT spring and damper kit, how much will my toe change?
I have no idea...sorry.
Geezer is offline
Old 12-17-2007, 03:36 PM   #15
Sarif2029
Sarif2029's Avatar
Fan#: 33430
What I Drive: 2003 Pitch Black SVT #3844
Points 1,757, Level 24
Points: 1,757, Level: 24 Points: 1,757, Level: 24 Points: 1,757, Level: 24
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 7 Sarif2029 Good Standing Member
Buy-Sell-Trade Rating: (8)
i move for sticky!!!!!
2003 Pitch Black SVT 3844 of 3985
RIP: 2000 Red ZX3 Born: Feb, 2000 Died: May 23, 2009
Garage Sale --> http://www.focusfanatics.com/forum/showthread.php?p=3522123#post3522123
Sarif2029 is offline
Old 12-17-2007, 04:01 PM   #16
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
in degrees the range is 0.15 to 0.35 toe in.
So basically you want it at 0.15 degrees.
Still wondering if its bad to go lower than .15....???
and after installing a suspension kit, the toe change will depend on wether or not you took out the inner bolt of the lower control arm. If you didnt, then it should change a bit, but will definitely go out of spec. If you did take it out, who knows how far off it is... Mine was at -.8/-1.11 degrees in the rear, - meaning toe out.
SUV this!
illinipo is offline
Old 01-10-2008, 04:37 AM   #17
knoxrocks222
Fan#: 38601
What I Drive: 2003 black svt
FF Reputation: 3 knoxrocks222 Good Standing Member
ok so check it, iv had this problem for about a year. iv been through 3 sets of very expensive tires and and its just the rears, they all have the same wearing problem, they all get bad flat spots and the car will shake horribly between about 55 and 70 then it smooths out iv had 3 alignments and im willing to try for 1 more before i put my stock springs back on.........by the way i have the sportlines and 17's and 16's both of which have had 3 sets of tires.
im a flight nurse in a different city and have to drive 27 miles one way to the hospital and i need my ride to be smooth and still keep my bad ass low look, if i have to i will trade for the prokit
thanks to all
knox (RN)
knoxrocks222 is offline
Old 01-10-2008, 10:05 AM   #18
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
you may need new shocks. Especially if you are still on the stock ones.
SUV this!
illinipo is offline
Old 01-10-2008, 11:48 AM   #19
Geezer
Fan#: 1427
thanks to all
knox (RN)
Can you be more specific about what you're calling a flat spot? Are you referring to a completeley bald area such as the edge of the tire. Is it in only one area of the tire (localized), is it a series of cupped like bad areas around the tire? Can you post any of the printouts from your alignments as those numbers could be very helpful.
Geezer is offline
Old 01-11-2008, 04:40 AM   #20
knoxrocks222
Fan#: 38601
well lets see how to describe my tire with a flat spot...kinds looks like a d lol like its just in one spot on the rear tires and its all the way accross the tire so its like u run ur hand around the tire and its like full tread half tread bald slick half tread full tread in that order, i dont have a printout of the alignment specs but i know im still towed out in the rear and im at a -camber, the front wears fine just normal.
but if i had to say the flat spot runs the width of the tire and about 20% around then the tire looks fine
Similar Threads
anyone know alot about alignments?? blackturbohatch46 Wheels & Tires 25 11-22-2007 05:24 PM
F/S: FC Rear Control Arm Toe Adjusters NEW chris-13 Archive 7 05-03-2007 09:41 PM
Is rear toe adjustable with stock suspension? brianwitt Brakes, Suspension & Body Chassis 5 02-13-2006 12:23 PM
SVT Pedals and Heel and Toe Oni Focus SVT 36 12-17-2005 02:01 AM
Heel to Toe? GaRyMaN DURATEC Performance (2003-2007) 16 10-22-2003 12:10 AM
