How to install foam speaker baffles in front doors - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-14-2007, 12:51 AM   #1
MisterJohnson
M0derator Monkey
MisterJohnson's Avatar
Fan#: 51724
What I Drive: '04 ZX3 D23
Points 62,373, Level 100
Points: 62,373, Level: 100 Points: 62,373, Level: 100 Points: 62,373, Level: 100
Level Up 0% Completed
FF Reputation: 30 MisterJohnson Great Standing Member
Buy-Sell-Trade Rating: (18)
I installed new 6x8's in the front doors of my '04 ZX3, and I used the foam baffles from Crutchfield.com
There are two ways to do this, and I picked the hard way, I'll give you the easier way at the end.
There are other threads for removing door panels, so I'll leave that part out
For this version you'll need duck tape, longer screws, washers (if the screw heads aren't big enough), scissors, and your speaker's spacer (shown here)
IMPORTANT! Roll down the window before you start or you won't know how deep the baffles can go!
Here are the speaker, crossover, and baffle I used
Here you see how the baffles are too deep to fit the front door properly
Cut the top off the baffle so there's about 3/4" protruding
Use your scissors and make cuts in the top of the foam approximately 3/4" long about every 1" -1 1/2", then slide the spacer up the baffle and use strips of duck tape to fold the foam over the spacer
Finished it should look something like this
Now stick it in your door
And install the speaker with the longer screws and the washers.
I didn't want to punch a hole in the baffle, so I ran the wires out the front between the speaker and the baffle. The foam is thick enough that the wires don't create a gap.
For the easier way:
If you don't want/don't need to use the spacer, go ahead and do the cuts in the foam and then tape the flaps to the door panel. Then just install the speaker as normal.
If you're curious how I attached the crossover:
I made sure there would be enough space for it with the trim panel in place, then I checked behind the steel panel and made sure there was nothing in the way for drilling. Then I drilled holes and used zip-ties to secure the crossover. When drilling each hole you'll have to stop part way and remove the gorilla snot from the drill bit.
If you have manual roll up windows, here's a tip to make your life easier when re-installing the trim panel:
Put the clip back in the handle before you put the handle in place, then just snap the handle on. You don't have to squeeze the clip on through that tiny gap with the handle already on the door!
15.07 @ 93.49 Team Duratec #149
MisterJohnson is offline
Old 12-14-2007, 05:54 AM   #2
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
nice write up! but coudnt you do the same thing with some dynamat?
meh, its probably easier this way.
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 12-14-2007, 07:39 AM   #3
foci01
foci01's Avatar
Fan#: 41223
What I Drive: 01 Twiligh Blue SE 4DR Sedan
FF Reputation: 1 foci01 Good Standing Member
How much of a difference in sound quality does this make? I have the stockers in the doors still and they sound good for a daily driver, but if I can improve on the sound I will try it.
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy crap..What a ride!"
SEDAN REVOLUTION#23
foci01 is offline
Old 12-14-2007, 02:25 PM   #4
MisterJohnson
M0derator Monkey
Fan#: 51724
I don't think dynamat would make much difference on the front door as it's already coated in black goop and then covered with a layer of foam (on my car anyway).
I'm not sure how much of a difference the foam baffles make in the sound quality, I didn't do a comparison, I did the baffles and new speakers at the same time. It just seems like they would give you a little tighter bass and in the front door especially it seems like they would be good protection from moisture.
Old 12-14-2007, 03:04 PM   #5
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
How much were those baffles? I guess I could just go look it up. But that's very interesting. Might have to pick some of those up.
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 12-14-2007, 03:12 PM   #6
MisterJohnson
M0derator Monkey
Fan#: 51724
They were like $8.99 a pair on Crutchfield.com, but you may be able to find them cheaper somewhere else.
Old 12-14-2007, 08:31 PM   #7
Waffles ZX3 Kona Sport
WAFFLEY!
Waffles ZX3 Kona Sport's Avatar
Fan#: 10426
What I Drive: 2006 Fusion SE Midnight Blue
FF Reputation: 11 Waffles ZX3 Kona Sport Great Standing Member
Buy-Sell-Trade Rating: (6)
I had foam baffles like that in my CRX - good investment for 9 bucks IMO. Nice writeup btw! (sticky????)
Waffles ZX3 Kona Sport is offline
Old 12-14-2007, 09:08 PM   #8
mister_bin
mister_bin's Avatar
Fan#: 50998
What I Drive: 2003 Yellow ZX5
FF Reputation: 27 mister_bin Great Standing Member
do all the fofo's have that black goop on the front door ??
mister_bin is offline
Old 12-17-2007, 11:09 AM   #9
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO ARCHIVE"..... good stuff!!
Chad (S2)
S2 is offline
Old 12-17-2007, 02:20 PM   #10
zx360
zx360's Avatar
Fan#: 32439
What I Drive: 2005 black zx3 ses
Points 16,856, Level 83
Points: 16,856, Level: 83 Points: 16,856, Level: 83 Points: 16,856, Level: 83
FF Reputation: 44 zx360 Great Standing Member
Buy-Sell-Trade Rating: (33)
great how to! very nice
FocusFest 11' "Best in class" Oct'11 HOTM FITF'12 "Best Show & Shine" July 12 ROTM
instagram @360DSGNS
zx360 is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
Front strut tower bar install with aem cai SUCCES!!!!!!! breakdancein SVT Performance (2002-2004) 11 03-16-2004 11:38 PM
zx5/svt front vallence install? FOCUS03 MK1 Focus 4 01-24-2004 01:29 AM
?? about Euro front bumper install sooner-or-later-an-SVT MK1 Focus 1 09-18-2003 04:06 PM
