MTX Fluid Change? Coolant Flush? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-12-2007, 09:42 AM   #1
Djmike2485
Registered User
Fan#: 3230
What I Drive: Silver 2000 Ford Focus Zetec 4 Dr.
FF Reputation: 6 Djmike2485 Good Standing Member
Ok, so yesterday I had the zetec in for it's oil change, new shop, I'm at school and in previous years were able to go home before it's due. It's approaching 90,000mi and of course the shop noticed it. They gave me a list of things that they and Ford recommend doing to keep it running well, so sweet of them. One of the things on that list was to change the transmission fluid. I have a mtx, and my knowledge of mtx's is not much. My question to you, do I need to change it? If so, can I do this myself? What kind of fluid do I need to put back in?
My other question relates to the coolant. I had this flushed around 45,000 so I'm guessing it's also about time to get it done again. Can I do this myself as well? What are some tips as to what to put back in?
I've seen a lot of controversy on both subjects so I'll admit, I'm a bit confused.
If I've left out any important info, let me know and I'll supply it to the best of my ability.
Thanks
Anyone willing to take a Physics final for me?!?!? Anyone?!?!?!? Gahhhhhh!
Djmike2485 is offline
Old 12-12-2007, 01:43 PM   #2
cafociguy
cafociguy's Avatar
Fan#: 21858
What I Drive: 01 ZX3, 03 ZX3 PWSCed
FF Reputation: 46 cafociguy Great Standing Member
Buy-Sell-Trade Rating: (4)
My take on both issues, is probably not needed but if you can afford the change then do it, what will it hurt to change it? I personally just bought some Royal Purple manual tranny oil stuff from Massive along with a bunch of other parts I am going to change as soon as I get some time. And probably do a radiator flush at the same time, why not I don't see that it can hurt anything if anything help protect it a little better...
cafociguy is offline
Old 12-12-2007, 01:48 PM   #3
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
The Ford interval for the yellow coolant is 120,000. I'm not sure where they're getting the idea that your transmission oil needs to be changed, I've never seen any documentation out of Ford that there is any suggested interval for the MTX-75.
Typically, its one of those things you'd want to do if the transmission is out anyways. Otherwise, the gearbox is a sealed system and all the transmission fluid does is lubricate, it does not transmit power like it does in an automatic. They're just trying to get a little more out of you...
SkaAddict is offline
Old 12-12-2007, 01:52 PM   #4
cafociguy
cafociguy's Avatar
Fan#: 21858
They are probably working on job security... more problems, more money, if Jay Z only knew... HA HA
Old 12-13-2007, 10:16 AM   #5
Djmike2485
Registered User
Fan#: 3230
I checked the Chilton Manual about the transmission fluid. They say not to do it unless there's a problem. So, problem solved. The coolant should be done; I consulted my father about it, he said that to do it right they should perform a "power flush" or something like that to get all the little chunks out.
I will do that when the time comes around.
Should the PCV valve (redundant?) be replaced? I've never replaced it.
Right now, my list of stuff includes:
Cleaning the battery terminals
Plug replacement, yeah, I know about the dielectric grease
Fuel filter
Air filter
Maybe pcv valve
Any suggestions on anything else that I should do?
Thanks for all your help. Everyone here has always been so helpful when I need insight.
Old 12-13-2007, 05:44 PM   #6
Djmike2485
Registered User
Fan#: 3230
Okay, so I got around to doing the plugs, air filter, and the battery stuff but using my Chilton, I was unable to locate where the PCV valve was on the zetec. Can anyone lead me in the right direction?
Old 12-13-2007, 06:07 PM   #7
Obocecha
Obocecha's Avatar
Fan#: 28484
What I Drive: 2002 Yellow ZX3
Points 1,703, Level 24
Points: 1,703, Level: 24 Points: 1,703, Level: 24 Points: 1,703, Level: 24
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
FF Reputation: 15 Obocecha Great Standing Member
Buy-Sell-Trade Rating: (9)
All you have to do is loosen the drain plug on the bottom and put in a couple of new quarts of tranny fluid. It's a fairly straight forward procedure. I changed my MTX's fluid in about 5 minutes.
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is online now
Old 12-13-2007, 08:32 PM   #8
1stTimeFocus00
Fan#: 44202
What I Drive: 2000 InfaRed Zx3
FF Reputation: 27 1stTimeFocus00 Great Standing Member
Yea the trany fluid is a real simple one. One trick i have is u stick ur pinky in there and if it gets fluid on it, ur good to go
Zetec Crew #152
United States Army
1stTimeFocus00 is offline
Old 12-16-2007, 08:55 AM   #9
TeamPrecisionIT
TeamPrecisionIT's Avatar
Fan#: 49174
What I Drive: 2002 Black ZX3 HB
FF Reputation: 1 TeamPrecisionIT Good Standing Member
Where do you actually put the fluid in the tranny? I tried looking from the top and couldn't find a fill hole/bolt. From the bottom there are two bolts I noticed, one towards the front and another on the bottom in a litle cave. Am I guessng right that the one in front is to fill?
TeamPrecisionIT is offline
Old 12-16-2007, 09:05 AM   #10
Obocecha
Obocecha's Avatar
Fan#: 28484
That's exactly right. The one on the bottom is for draining. The other one on the front side is for filling it up. I used a smaller funnel with a long plastic tube to fill it up.
'02 Yellow ZX3
'85 Supra 6M-GTE
Similar Threads
auto trans fluid change robr General Technical Chat 9 06-07-2005 06:38 AM
Manual Tranny Fluid Change... Vette2AFocus ZETEC Performance (2000-2004) 8 04-30-2005 04:14 AM
How to flush the transmition fluid? Maxis Ford Focus & General Car Chat 19 05-12-2004 10:36 AM
Checking MTX Fluid 00SE Ford Focus & General Car Chat 6 05-06-2004 05:36 PM
MTX 75 Transmission Fluid change microtonal Ford Focus & General Car Chat 7 01-14-2004 11:04 AM
