Go Back   Focus Fanatics > Model Specific Discussions > MK1 Focus
Old 12-02-2007, 11:02 PM   #1
MisterJohnson
M0derator Monkey
MisterJohnson's Avatar
Fan#: 51724
What I Drive: '04 ZX3 D23
FF Reputation: 30 MisterJohnson Great Standing Member
Buy-Sell-Trade Rating: (18)
How to replace broken plastic tabs
I couldn't find a thread for this, and I needed to do it myself, so here ya go
How to replace a broken-off plastic tab on the back of a standard ZX3 grill:
What you'll need:
- paper or cardboard *see bottom of instructions for optional template method
- pencil
- tube of Quiksteel Plastic Repair putty
- cheap butterknife
- wet rag (water keeps the putty from sticking to your fingers)
- 60 grit sandpaper
- rubbing alcohol
- small clean dry rag
- black paint (flat black aerosol primer worked for me)
- masking tape and paper
Good side
Busted side
Use pencil and paper/cardboard to trace out the good side
Set the paper on glass and back-light it so you can trace the outline and use it to replace what's missing
Thoroughly clean the whole area to be fixed. I used rubbing alcohol. Use a small drill bit and drill a bunch of holes at the edge of the break, then use the sandpaper to rough up the area (front, back, and sides)
Grab your Quiksteel plastic repair and follow its instructions for preparing the putty for use.
Apply the putty onto the plastic so it covers the holes you drilled, and push the putty into the holes. Then start forming the putty to replace missing plastic. It will take a couple minutes for it to start setting, but when it does it will set up pretty fast. When it starts to set use your template as a guide to form the putty into the correct shape. Don't worry if it's not thick enough, you can add more later. For now just fit it to the template. Use your knife to trim any excess from the edges instead of trying to push the extra back in. Let it set for about 10 minutes and then you can add more if you need to bulk it up.
Let it harden for 20-30 minutes and then sand it to the proper shape. If you have a dremel tool, that would be a lot faster and easier than sanding by hand. When you're happy with the shape use your template and drill your hole.
Wipe off any dust, tape it up to avoid overspray, and paint!
I did a pretty quick job, so the putty was a little thicker than I would have liked, but it's hidden from view and it works
*optional method for a template (I though of this after I was done and it will probably work better)
Instead of paper, use some thin cardboard for the stencil (like from a cereal box), cut it out, and tape it securely to the bottom side of the plastic. That way your template won't move and it'll be easier to get your putty in the right size and shape.
Hope this helps someone out there!
Moderator for Showroom, General Chat Lounge, and South West Region
15.07 @ 93.49 Team Duratec #149
MisterJohnson is offline
Old 12-02-2007, 11:08 PM   #2
FocusVet
I'm Back!
FocusVet's Avatar
Fan#: 41812
What I Drive: '03 Twilight Blue Sedan-D23E
FF Reputation: 19 FocusVet Great Standing Member
Buy-Sell-Trade Rating: (9)
Nice Job!!! I nominate this guy for the "complete how-to archives"
TEAM DURATEC # 074 / SEDAN REVOLUTION #001
FocusVet is offline
Old 12-03-2007, 01:36 AM   #3
focusonthis420
focusonthis420's Avatar
Fan#: 30951
What I Drive: SGM 2012 5dr
FF Reputation: 17 focusonthis420 Great Standing Member
Buy-Sell-Trade Rating: (26)
great right up, this will come in handy. both of my lower tabs are broken right now and i had to drill holes and zip-tie them to keep the grill in place
Sterling Gray Metallic 2012 5dr Titanium w/ MS3 RMM
focusonthis420 is offline
Old 12-03-2007, 02:30 PM   #4
MisterJohnson
M0derator Monkey
Fan#: 51724
That sucks. If you plan on doing the template, see if you can find someone who will let you trace their unbroken tabs since both of yours are gone.
Old 12-03-2007, 02:39 PM   #5
zx360
zx360's Avatar
Fan#: 32439
What I Drive: 2005 black zx3 ses
FF Reputation: 44 zx360 Great Standing Member
Buy-Sell-Trade Rating: (33)
awesome! how to material!
FocusFest 11' "Best in class" • Oct'11 HOTM • FITF'12 "Best Show & Shine"
OEM+ • Ford of EuropeCosworth FSWerks
zx360 is offline
Old 12-03-2007, 03:55 PM   #6
mister_bin
mister_bin's Avatar
Fan#: 50998
What I Drive: 2003 Yellow ZX5
FF Reputation: 25 mister_bin Great Standing Member
great write up definatley something to put in the how to archive
mister_bin is offline
Old 12-03-2007, 09:08 PM   #7
focusonthis420
Fan#: 30951
i still have one of the tabs, i saved it after i broke it off by accident. i figured i would try and work out a way to repair it but you beat me to it (and prob came up with a better way to do it than i could).
Old 12-17-2007, 10:10 AM   #8
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 68 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO ARCHIVE"..... good stuff!!
Chad (S2)
S2 is offline
Similar Threads
Broken Headlight Tab & HID Wiring Problem-How to Fix? SuperFlea MK1 Focus 7 08-17-2006 10:19 PM
broken link in engine bay. 2002SVT SVT Performance (2002-2004) 15 06-27-2005 05:55 PM
Broken...cheap crummy plastic [ZX3]Brucity General Technical Chat 17 06-07-2005 10:23 PM
Krylon Fusion paint for plastic sdwndr85 MK1 Interior Mods & Upgrades 10 05-19-2004 10:13 PM
replace the black plastic with cool stuff focusonthefocus MK1 Focus 5 11-14-2003 09:46 AM
