SVT Front Camber Issue, Stock Suspension... - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 11-26-2007, 05:35 PM   #11
ProSilverVT02
ProSilverVT02's Avatar
Fan#: 33656
What I Drive: 2002 SVT
FF Reputation: 7 ProSilverVT02 Good Standing Member
Buy-Sell-Trade Rating: (8)
Originally Posted by Geezer View Post
Sounds like you bought the car used so some things come to mind. 1) Are you sure it has stock springs on it? Did the previous owner possible lower it. 2) The accident could be one cause but it had to be a pretty good one. That amount of negative camber can not be achieved within the range of allowable stock adjustments. You're lucky if you can get a quarter to half a degree (if that) at most alignments. It's unlikely taller springs will do much. It would take a considerable increase to negate (reduce) that kind of camber. I see if someone has a set of SVT front springs laying around and give them a try (borrow) before you spend serious money on other springs and have them not work.
1) Not 100% sure it has the stock springs, but the rear end is about 3/8 of an inch lower than a ZX3 with a factory suspension with about 5,000 more miles. I thought that was pretty close to the factory height of the SVT. With that said, is it possible that the previous owner lowered the front and not the back? Either way, if the suspension is not factory an Eibach setup would have the car sitting .75 inches lower in the front than factory, and about 1 inch lower in the rear than factory. So I guess I'm hoping the ProKit will level the car out (raise the front, lower the rear). I was actually thinking about purchasing a set of KYB AGX struts/shocks last spring, so this problem would actually give me a reason to get them with the ProKit.
2) I don't see any repairs to the frame upfront. The only thing I noticed about the front end is an R DOT driverside headlamp and R DOT front bumper (probably a fender bender, nothing major) I have had the fenders off the front end and once again, no repairs to the factory welds/frame horns. As far as suspension parts, my controls arms are straight, and the bushings are solid. I'm running out of ideas of what to do.
ProSilverVT02 is offline
Old 11-26-2007, 06:28 PM   #12
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
FF Reputation: 17 wickedgreyzx3 Great Standing Member
might be a bent control arm
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 11-26-2007, 06:34 PM   #13
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Memberscrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
^^agreed
sloppy ball joints will also cause this. new LCAs come with balljoints.
scrammer is offline
Old 11-26-2007, 06:57 PM   #14
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing MemberGeezer Excellent Standing Member
I doubt its a bent control arm. First, both would have to be bent and by the same amount sense camber is pretty even side to side. Secondly, most bent control are bent laterally rather than vertically. A lateral bend screws up toe pretty significantly. To affect camber and not toe (toe is almost zero on both sides) the arm would have to be bent vertically (like dropping the car from significant distance and landing on its wheels...naturally this would break a lot of other stuff as well) which would shorten it and thus cause numbers towards positive camber rather than negative.
And for what its worth caster can affect camber a little as well. Do you have your caster numbers.
Geezer is offline
Old 03-04-2008, 02:14 PM   #15
Springbuck
Fan#: 23301
What I Drive: 03 CD Silver SVT 5DR
FF Reputation: 1 Springbuck Good Standing Member
I have this same problem. The wear seems to be on the outside of the tire rather than on the tire thread itself. The corner looks like it gets grinded away. I also have a SVT. Mine is stock. No suspension work done. I have had 4 alignments done with no success. It almost seems if you look at the tire that what happens is that when you turn the tire "flops" over instead of staying vertical. I have some pics I will dig up. The tread is worn evenly across the tire, but on both front wheels the inside corner is worn away so much it actually makes a triangle with the contact patch.
If you jack the front end up and "wiggle" the wheel there is no "play" in the wheel. it is real solid.
03 SVT Focus, STS,
2011 Fusion SEL -Bone Stock and staying that way
Springbuck is offline
Similar Threads
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 11:55 AM
WTB: SVT Suspension, SVT Front Bumper Black&Tan Archive 3 06-21-2005 08:28 AM
SVT vs stock suspension? BlazingCopper_ZX3 Brakes, Suspension & Body Chassis 2 06-16-2005 01:40 PM
For Sale: SVT stock suspension *SOLD* essveetee Archive 5 06-02-2005 05:03 PM
For Sale: SVT and stock ZX3 front grilles H&Rzx3 Archive 12 10-30-2003 10:59 AM
