Clunking noise from rear of Stock SVT - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-24-2007, 08:33 PM   #1
SVTF4243
SVTF4243's Avatar
Fan#: 4068
What I Drive: SVT 2002
Points 4,095, Level 40
Points: 4,095, Level: 40 Points: 4,095, Level: 40 Points: 4,095, Level: 40
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 2%
FF Reputation: 11 SVTF4243 Great Standing Member
Question Clunking noise from rear of Stock SVT
I get this CLUNK when I brake, it's in the rear and I suspect ( but am no means sure) it's from the suspension.
What are the possible culprits and How do i diagonse them?
Thanks!
Silver SVT 2002 svtf4243.com
Silver ST3 MR::: 02 11 2013
GO :: Cobb RRM | Accelerator petal mod| JBR OCC | STS | Springs| Rear Swaybar | Tune
SHOW :: Lights tint | Calipers Painted| Graphite colored wheels| Back up Cam | Window Tint
SVTF4243 is offline
Old 11-24-2007, 09:15 PM   #2
stivo
Hiyadoin'
Fan#: 48389
What I Drive: 2004 Infrared SVT, EAP #1440
FF Reputation: 9 stivo Good Standing Member
Buy-Sell-Trade Rating: (6)
Just got to check under there and make sure everything is tight. It's a little hard to tell from your description... when exactly does it make the noise?
Check your exhaust for excessive play. I had a car with worn exhaust mounts and it would clunk over bumps... took me a few months to figure it out. It ended up being a cheap and easy fix.
stivo is offline
Old 11-24-2007, 09:21 PM   #3
SVTF4243
SVTF4243's Avatar
Fan#: 4068
Forum Activity 2%
Thanks STIVO, I'll check Exhaust mounts.
It Clunks right after I apply brakes. No noise over bumps
SVTF4243 is offline
Old 11-24-2007, 09:26 PM   #4
stivo
Hiyadoin'
Fan#: 48389
I'd start with the brakes then... checking the bolts and making sure everything is still tight. Look for signs of wear on the brakes, around the brakes. Sway bar end links... bolts in the suspension... Even check your wheel lugs!
Good luck!
stivo is offline
Old 11-24-2007, 09:43 PM   #5
SVTF4243
SVTF4243's Avatar
Fan#: 4068
Forum Activity 2%
Good luck!
Lugs were the first thing I checked...I've had a clunk before in the front and a lug was the cause
SVTF4243 is offline
Old 11-28-2007, 09:17 PM   #6
Tony D
Fan#: 7018
What I Drive: 01 ZX3 Yellow/03 SVT Red
FF Reputation: 6 Tony D Good Standing Member
Buy-Sell-Trade Rating: (17)
Check the rear caliper mounting bolts to see if they are tight. While you have the rear wheels off, look at the holes in the rotors where the wheel studs go through to see if they are ovalled out for some reason.
Also, check the rear brake pads to see if they are moving around too much in the caliper.
Got anything loose under the spare tire?
I hope this helps.
Tony D
www.newedgeperformance.com. Your one stop Focus parts headquarters!
Tony D is offline
Old 12-07-2007, 01:01 AM   #7
SVTF4243
SVTF4243's Avatar
Fan#: 4068
Forum Activity 2%
Thanks All for the tips.
I'll keep you posted when I get around to checking them.
SVTF4243 is offline
Old 12-13-2007, 09:22 PM   #8
SVTF4243
SVTF4243's Avatar
Fan#: 4068
Forum Activity 2%
Well Duh uhUHHHHH!
This morning the clunk became a clunk clunk clunk after any speed change so I rechecked the lugs. The back lugs were tight as they were the last time I checked but the front driver side had 2 loose lugs.
Now the only clunking sound is the sound of my palm hiting my head.
Well STIVO you called it!
SVTF4243 is offline
Old 12-13-2007, 10:03 PM   #9
dirtbrown
what it be like
dirtbrown's Avatar
Fan#: 40563
What I Drive: 03 EAP
Points 41,796, Level 100
Points: 41,796, Level: 100 Points: 41,796, Level: 100 Points: 41,796, Level: 100
Level Up 0% Completed
Forum Activity 8%
FF Reputation: 27 dirtbrown Great Standing Member
^^^ do u really think that was the prob....?
thats odd you said it was in the rear...id say caliper mounting bolts as well....had this problem after I changed my breaks and tightened it and it went away
dirtbrown is offline
Old 12-13-2007, 11:56 PM   #10
SVTF4243
SVTF4243's Avatar
Fan#: 4068
Forum Activity 2%
Well it sounded like it was in the rear but after tightening the lugs the sound is gone
I'll check that when I rotate my tires next month
SVTF4243 is offline
Similar Threads
SVT Parts For Sale: Ontario, California jrgtrain Archive 98 02-11-2008 08:32 PM
**Vote for FF.com ROTY** Chick Ford Focus - Ride of the Month 113 07-31-2007 12:04 PM
For Sale: 2003 ZX3 5 Speed SVT Brakes ST170 Headlights white03SVT Archive 19 06-27-2007 11:31 AM
For Sale: SVT & Progress RSB's, Katzkin Blue Leather Seats, H&R Cup Kit, JBA Header, RT Cat turboed00focuszx3 Archive 48 02-24-2007 11:20 AM
Ford Focus: Suspension & Brakes hotfocus Brakes, Suspension & Body Chassis 0 02-17-2005 04:40 AM
