rattle sound coming from passenger front wheel - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-23-2007, 08:21 PM   #1
bdonaldson404
Fan#: 51764
What I Drive: 2001 cd silver lx
FF Reputation: 1 bdonaldson404 Good Standing Member
Hello,
I'm new here but have had my focus for a little over a year. I've had a few minor issues with it such as brakes and such but I expected that as I had bought the car used. It is a 2001 LX sedan and now has 61,000 miles on it. Anyways, for the last couple months I have been hearing a rattle coming from the front end on the passenger side. It happens when it is cold first thing in the morning. It will make the rattle when I turn right and then for a little bit as I drive straight. It will go away as the car warms up. Also when it makes this rattle it will vibrate when I make sharp right turns. Once it is warm, it won't vibrate. I finally took the car in for this noise and the mechanic told me that the right front hub bearing was bad and needed to be replaced. I had them replace it and $317 later it still makes the noise! I took the car back to the shop telling them that it makes the noise still, and they claim that it didn't on their test drive and they checked everything underneath the car and it was ok. I don't buy this and can't afford to be replacing everything piece by piece. Does anyone have any ideas what it could be and how expensive the repair might be. I am not mechanically savy, and will have to take it to another shop, but I don't want to be swindled again. Any ideas will be greatly appreciated. PS the frst shop also checked the CV joint supossedly because this is what I thought it might be.
bdonaldson404 is offline
Old 07-24-2008, 10:44 PM   #2
guillaume_0
Fan#: 57853
What I Drive: 2003 Blue ZX3
FF Reputation: 1 guillaume_0 Good Standing Member
Yep rattle near front passenger wheel
I have the exact same problem : rattle around 3000 rpm when cold and specially when turning right. I went to two different ford dealerships. They cannot find what it is. A bearing was replaced but that was not it. It's not the heat shield, and nothing else seems loose. Their advice : keep driving it until it gets worse. So much for a professional advice.
Did you ever find out what it was?
Guillaume.
guillaume_0 is offline
Old 07-27-2008, 10:53 AM   #3
7flowers4u
Fan#: 58016
What I Drive: 01 Focus wagon...green..ZTEC DOHC
FF Reputation: 1 7flowers4u Good Standing Member
It was a tie~rod that needed replacing on mine.
Same year, and around the same mileage when the issue started:)
Hope that helps!
7flowers4u is offline
Old 10-16-2008, 03:11 PM   #4
domesplit
domesplit's Avatar
Fan#: 19448
What I Drive: 2002 ZX5 and 2003 SVT ZX5
Points 990, Level 16
Points: 990, Level: 16 Points: 990, Level: 16 Points: 990, Level: 16
Level Up 90% Completed
FF Reputation: 1 domesplit Good Standing Member
did the tie rod idea work?
I have the exact problem as explained above. When my car is cold and when I turn right I hear a sound coming from the right wheel. After driving a while the sound goes away.
Did the other 2 guys try the tie rod idea?
domesplit is offline
Old 10-16-2008, 03:54 PM   #5
broham71
broham71's Avatar
Fan#: 6426
What I Drive: 03 PB 2.3 ZX3, 09 PW Mini JCW
FF Reputation: 8 broham71 Good Standing Member
I had a similar issue and replaced the front endlinks... problem solved.
I would hear a clicking sound when I would turn either way. I thought it was something serious. I guess I got lucky.
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming "WOW! What a Ride!" SoCal Crew#3/Team Dtec#186
broham71 is offline
Old 10-21-2008, 12:53 PM   #6
robin muir
Fan#: 24782
What I Drive: 2002 dk grey zx3
Points 303, Level 6
Points: 303, Level: 6 Points: 303, Level: 6 Points: 303, Level: 6
Level Up 6% Completed
FF Reputation: 1 robin muir Good Standing Member
Same problem, I hear a kinda humming sound when I start the car cold,drive the car and when turning right sounds awful . After about 15 mins on the freeway everything is normal. I had snapped off a lug nut on the right side, thought maybe there was vibration from that side. Bought a stud on Sunday to replace ,but when taking the wheel of broke another one. Gave up and drove the car to the dealer to have them replace all four studs . $ 300 dollars later the problem still exits.
robin muir is offline
Similar Threads
So here's my dilemma with the dealership service department ethics/damage... long.... Soviet Russia Ford Focus & General Car Chat 31 09-09-2006 03:12 AM
2002 Ford Focus: how to replace the front wheel bolts (lug bolts) jsimon General Technical Chat 4 04-04-2006 02:25 AM
WTB: Fog/Driving Light - Passenger Side / Front Splash Guard - Drivers Side Optikinescant Archive 0 04-01-2005 08:25 PM
grinding noise coming from front right wheel well pnut General Technical Chat 12 06-10-2004 06:45 PM
slight knock in front passenger wheel? wendelltate Ford Focus & General Car Chat 8 02-14-2004 12:21 AM
