Let the swap begin! - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 11-21-2007, 01:50 PM   #1
tczx3
tczx3's Avatar
Fan#: 48551
What I Drive: 2002 ZX3 (SVT Eng/Tran), 2002 SVTF
FF Reputation: 32 tczx3 Great Standing Member
Buy-Sell-Trade Rating: (8)
Let the swap begin! ZETEC to SVT!
Let the swap begin! Well it's been a LONG time in the works but I think we finally have all the pieces to do the Zetec to SVT swap. Here's the starting pics!
Hopefully by the end of this weekend we'll have a running ZX3SVT!!
2002 ZX3SVT SVT engine/trans conversion w/ SVT guages, headlamps, front grille, bumpers, 17" Euro, Hankook Ventus V12, AEM CAI, Borla
2002 SVTF Infra Red! Stock w/ Dual oulet exhaust and rolling on Proxes 4
2002 SVTF Pitch Black-Dad's new ride!
tczx3 is offline
Old 11-21-2007, 03:36 PM   #2
klodkrawler05
Sooooooooooo EURO
klodkrawler05's Avatar
Fan#: 47771
What I Drive: BMW's
FF Reputation: 26 klodkrawler05 Great Standing Member
Buy-Sell-Trade Rating: (30)
i hope your going to give us a detailed list of every single part needed to do this!
-Brad
'03 VW Jetta TDI - The Daily Commuter
'02 Chevy Corvette Z06 - The Toy
'99 Triumph Daytona - Death Machine
klodkrawler05 is online now
Old 11-21-2007, 03:59 PM   #3
TKE_Quailman
FF God of South FL
TKE_Quailman's Avatar
Fan#: 44442
What I Drive: 07 Pitch Black ZX3
FF Reputation: 35 TKE_Quailman Great Standing Member
Photos of everything!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
02 Black ZX5 R.I.P.
07 Black ZX3 Work in progress
Last of the Hatches #1
XBOX LIVE:TKE428
GIVE REP POINTS IF IM HELPFUL
TKE_Quailman is offline
Old 11-22-2007, 06:14 PM   #4
tczx3
tczx3's Avatar
Fan#: 48551
The swap is on! Yesterdays progress went well and we were ahead of schedule at 11pm when we called it quits. We started at 4:30 and at the end of the day the motor and tranny was out. The main problems in the removal were: a. Could not get lower ball joint bolts out to pull ball joint out of knuckle to remove drive shafts so we pulled the struts instead. No biggy but killed 30 minutes trying to get ball joints loose. b. Hard time getting LH drive shaft out due to retainer clip. Finally got slide hammer with claw behind the cup and popped it out. c. 1 stuck ATF line that we had to remove at cooler and unscrew hose and nut. d. Rusted nuts on flex pipe (go figure). Oxy/Acty to the rescue! We used a Motorcycle/ATV jack to hold motor up with car on jackstands, removed mounts, dropped motor as low as jack would allow and then lifted chassis up a foot or so with forklift to clear motor and rolled the motor out! Piece of cake!
Today was Tday and big feast at the inlaws so not much work but we squeezed in 3 hours this morning. Worked on stripping engine bay. This was a AOD to Manual swap so took a long time to tear out shifter and cables. Pulled both engine wire harnesses. The BJB harness was a pain because one wire went under LH fender to washer motor and that was a pain because of frozen bolt at rocker panel to remove inner fender liner to access.
Tomorrow we hope to detail engine compartment and complete interior work. We're swapping dash wiring harness also. This will allow SVT guages to work correctly. This swap is also 02 chassis to 04 motor so some wiring/connector issues to deal with. Will post lots of pics in the am to show where we're at. All things look good to have this done by Sunday eve! Motor install will start on Sat.
And for the nay-sayers, this can be done, buts LOTS of work. Is it worth it? Anything is worth it if it's what YOU want, right? The motor was a good deal and we wanted to go MTX so this gets us 40hp and the MTX. By the time everything is done we hope to have this project completed for $2000, less whatever we can get for the original motor and extras. Any one need a good used zetec motor????
tczx3 is offline
Old 11-22-2007, 07:15 PM   #5
klodkrawler05
Sooooooooooo EURO
Fan#: 47771
What I Drive: BMW's
you ARE taking pics of everything right?!?!?! tons of us zetec auto guys would love a svt engine!
-Brad
Old 11-23-2007, 07:36 AM   #6
tiresmoker
What bump stop?
tiresmoker's Avatar
Fan#: 20426
What I Drive: '00 ZX3 Turbo, '06 ST Turbo
FF Reputation: 24 tiresmoker Great Standing Member
The only problem I see you running into is the fact that you don't have the SVT block, head, or transmission in any of your pics.
Good luck with the swap, and make sure to keep this updated.
ST Crew #19
2006 ST Turbo: JUNE 07 ROTM 2007 Ride of the Year
2000 ZX3: superturbochargedpartscar
2005 Shinka RX-8: too many mods....
Originally Posted by 03OrangeSVT
It was like concentrated death on chicken
tiresmoker is offline
Old 11-23-2007, 09:02 AM   #7
tczx3
tczx3's Avatar
Fan#: 48551
As promised, pics of current status:
One zetec motor out of chassis!
Looks empty!
tczx3 is offline
Old 11-23-2007, 12:10 PM   #8
tczx3
tczx3's Avatar
Fan#: 48551
Yes, the SVT engine exists!
Probably the nightmare- wires, wires, everywhere!
tczx3 is offline
Old 11-23-2007, 08:54 PM   #9
03screaminSVT
03screaminSVT's Avatar
Fan#: 51702
What I Drive: 03 screaming yellow svt focus
FF Reputation: 1 03screaminSVT Good Standing Member
That a good choice bro. SVT is the way to go
03screaminSVT is offline
Old 11-24-2007, 08:29 AM   #10
tczx3
tczx3's Avatar
Fan#: 48551
Well, the deconstruction phase of the build is complete.
Look Ma, No motor!
Took the time to thoroughly clean and detail engine compartment.
And no dash!
As it turns out the dash wiring has been the biggest pita! The harness could not be removed without pulling the dash- oh, well. What's another 2 hours?
It's been interesting as we've gone. Trying to check and double check components for interchange. It's the little things too. Found as we were installing the brake/clutch pedal assy from the SVT that the brake pedal didn't come up high enough to depress the cruise switch. After much comparison found both switches on the brake pedal slightly different. The plunger length on the AOD brake pedal/switch is 3/16" longer than the SVT. The switches look exactly the same except for the plunger length. Apparently the SVT has a different Brake booster/master cylinder and the pedal comes higher so the switches are shorter. Had we not found the difference now the cruise would never work because the system would think the brakes were always on.
Today we hope to have the dash wiring and interior completely put back together and start the engine install tomorrow. Trying to work out some issues with the head before we can put the motor in.
More later!
tczx3 is offline
Similar Threads
My SVT Brake Swap (w/Rear Discs) is Done! l88m22vette Brakes, Suspension & Body Chassis 17 07-27-2007 08:35 AM
engine swap momo General Technical Chat 1 04-19-2005 03:54 PM
What tools will i need for a tranny swap, clutch swap and posi swap turboed00focuszx3 General Technical Chat 2 02-25-2005 01:57 PM
