Engine misses, but not at idle - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 11-18-2007, 02:44 AM   #1
defl8ed
Fan#: 50351
What I Drive: 2001 White ZX3
FF Reputation: 1 defl8ed Good Standing Member
Hello,
2001 ZX3 stock everything, manual transmission. Recently car started shuddering every once in a while under acceleration, only when engine was cold. Thought the problem was EGR sensor (have already had that damn thing replaced 3 times), as the symptoms were similar. Waited for CEL to come on and confirm my idea, but when it did, the code was p0302 - missing on cylinder #2. Performance gradually worsened, but basic symptoms the same - engine starts and idles fine, but shudders (sometimes violently) when attempting to accelerate. Pulled out spark plug for #2 cylinder to see if it was blackened/damp, but it was not - this makes sense, since it appears that the cylinder is firing when the engine is idling which would burn off any uncombusted fuel in the cylinder. Drove car around the block to see if there was any difference, and got CEL code p0352 - which apparently indicates a bad ignition coil. "Ah Ha" I thought - ran down to the store, purchased a new coil, installed, and engine ran fine - for approximately 20 hours, at which point the problem reappeared - worse than ever. Got code p0302 again the next day. The plugs and cables were both replaced less than 30K miles ago, and the plug for number 2 cylinder is fine visually. If I look at the engine while idling, I can detect no arcing, so I don't believe it's the cable. Replaced DPFE sensor and disabled the EGR valve to make sure that wasn't actually the problem - (didn't think that was it, since that wouldn't cause a single cylinder to misfire, but wanted to cover all bases) - no change at all. So my question at the end of all this is "What can cause a cylinder to misfire when under load, but not when at idle?"
Vital stats -
2001 ZX3 with 97K Miles
2.0 Zetec
Alternator is new (replaced 2 months ago) and tested good
Battery is < 1 year old, also tests good
DPFE sensor replaced
EGR disabled
Spark Plugs and Wires Good as far as I can tell and have been replaced recently
Ignition Coil replaced after getting p0352, but no change.
Any Ideas?
defl8ed is offline
Old 11-19-2007, 11:51 AM   #2
defl8ed
Fan#: 50351
Followup
As a follow-up to clarify, the engine will not miss as long as there is no load - not just at idle. As long as the car isn't moving, you could sit there and rev the engine and hold it at high rpms forever, and it will not miss once, but once the gear is engaged, it will start to miss and jerk.
defl8ed is offline
Old 11-19-2007, 01:49 PM   #3
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 454, Level 9
Points: 454, Level: 9 Points: 454, Level: 9 Points: 454, Level: 9
Level Up 8% Completed
FF Reputation: 17 nilskje Great Standing Member
Try the pigtail connector to the coil, when driving the engine moves more around...
nilskje is offline
Old 11-20-2007, 12:01 AM   #4
defl8ed
Fan#: 50351
Pigtail
Nope, all wiring is visually okay. No wires pulled taut across a corner, no frayed or cut wire jackets.
defl8ed is offline
Old 11-20-2007, 12:13 AM   #5
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 232,586, Level 100
Points: 232,586, Level: 100 Points: 232,586, Level: 100 Points: 232,586, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
I"ll bet its a spark plug wire going south already, swap two of them around and see if the miss follows the wire. ( If you have enough length ). I"ve seen some cheaper wires go south in under 30K.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 03-09-2008, 09:37 AM   #6
DSKCP74
Fan#: 54195
What I Drive: 2001 Green Focus
FF Reputation: 1 DSKCP74 Good Standing Member
have you ever found a solution to this problem? My car is doing the excact same thing, and I just replaced the wires and plugs and its still doing it
DSKCP74 is offline
Old 03-11-2008, 03:11 PM   #7
agiannam
Fan#: 42831
What I Drive: 2002 Focus SE, 1998 Maxum 2100SC
FF Reputation: 6 agiannam Good Standing Member
We had this; It was vehicle wiring connected to the ignition coil. Wires broke at the back of the connector due to relative motion from the engine.
agiannam is offline
Old 03-11-2008, 03:57 PM   #8
JRODSVT
Dragon Warrior
JRODSVT's Avatar
Fan#: 15362
What I Drive: 03 SVT ZX5
FF Reputation: 97 JRODSVT Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I had this same problem but it was cracked porcelin of the spark plug.
But i see that it could be the ignition coil not groundig properly.
J-RAWK!!!
FocusFests best of sound 2008
(Oo> (SVT) <oO)
o xxxxxxxxxxxx o
JRODSVT is offline
Old 03-11-2008, 04:30 PM   #9
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,286, Level 85
Points: 18,286, Level: 85 Points: 18,286, Level: 85 Points: 18,286, Level: 85
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 48 iminhell Great Standing Member
Yup, few things it could be.
Common things to check are,
spark plug wires - visually check for arcing, test resistance with a DVOM (vs other wires, Ohms increases with length)
spark plugs - verify correct gap (more gap = more resistance), make sure plug is good, no cracks/corrosion/submersed in water/oil
ignition coil pigtail - pretty common to see these crack and fail, there is a how-to in the stereo section of this site (don't ask me why it's there)
fuel injector - easyiest way to test this one is to move the injector, if the miss follows the injector, well ...
mass air flow sensor - if it is dirty or has an oily coating it can not burn off it may be giving the ECU a foul reading, under light load you may not notice it (lean and light timing) but when you put your foot in it (rich and heavy timing) you may notice it, use a specifically for MAF cleaner
PCV - the elbow specifically, if there where a tear in the tube you may be running lean and that would give a miss (most likely not your problem but it's one of those commonly overlooked things)
iminhell is offline
Old 03-16-2008, 05:38 PM   #10
perrobox8
perrobox8's Avatar
Fan#: 45037
What I Drive: '01 silver ZX3
FF Reputation: 1 perrobox8 Good Standing Member
i have the same problem, replaced pcv hose, and the pigtail, also checked the spark plugs any idea?
zetec crew #144
AEM CAI,FC header,Borla catback,STR fuel rail,MSD ignition and wires,Massive speed UDP,Ford Racing LSD,X-Cal 2,Comp 2 cams,2000 intake manifold,NX
perrobox8 is offline
Similar Threads
IAC Valve Davva General Technical Chat 104 10-24-2009 08:45 PM
Engine Bogging at Idle mdgonzo101 General Technical Chat 0 07-01-2007 12:27 AM
General specs on the SPI b16sir1991 General Technical Chat 0 04-18-2007 11:20 AM
Does a bad DPFE sensor cause the engine to stall at idle? odengiz General Technical Chat 3 03-06-2006 05:08 PM
Engine hot at idle rob0781 General Technical Chat 11 04-24-2005 12:05 AM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
