Aiming SVT HID headlights? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 11-21-2007, 02:00 AM   #21
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Just to add...there should be a little "o" right in the middle of the headlight lens, marking the center of the light.
SkaAddict is offline
Old 11-21-2007, 09:46 AM   #22
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
not on the Mach's. im not sure if the non-HID housings have that or not.
scrammer is offline
Old 11-21-2007, 10:34 AM   #23
SkaAddict
Fan#: 1690
Hmmm...I could've sworn mine had them
Old 12-03-2008, 04:51 PM   #24
Kalos
Fan#: 1733
What I Drive: '04 SVT, Silver
FF Reputation: 1 Kalos Good Standing Member
SVT HID Headlight and Fog Aiming ?
Originally Posted by scrammer View Post
behind the headlights there is a panel that can be removed. it has 4 clips. one at each corner. remove this panel. there is a knob on the inside. this is your height adjustment. clockwise moves the beam up. be careful on how much you increase it. a little goes a LONG way.
Does anyone have exact dimensions for aiming SVT HID headlights (and fogs) ?
Assuming the car is level and aimed at a vertical wall 25' ahead, how high should the left and right lamp beam "center spots" be?
I think my HID lamps are aimed too high. I get complaint flashes from oncoming cars even on low beam, and the high beam does a good job of illuminating bird nests in trees.
It's worse when I'm pulling a heavy trailer...
Kalos is offline
Old 12-03-2008, 05:04 PM   #25
scrammer
scrammer's Avatar
Fan#: 26570
^^read the posts again, its explained above.
scrammer is offline
Old 12-04-2008, 01:40 AM   #26
Kalos
Fan#: 1733
Not really. The measurements refer to the aiming of fog lamps (eg 2" below low beams).
Incidentally, without a trailer the HID low beams seen to be aimed more or less correctly, but the high beams are still too high. Is it possible to aim high and low beams separately?
Kalos is offline
Old 12-04-2008, 02:19 AM   #27
scrammer
scrammer's Avatar
Fan#: 26570
highs and lows are aimed together, they cannot be aimed seperately
measure from the ground to the center of the projector. take 2" from this measurement and draw a line on a wall 25' away from the car. make sure your on a flat surface.
adjust the white knob on the back until the bottom line of the step of the beam is level with your measured line. if you have never adjusted the vertical aiming on the housings, then you wont need to adjust those.
scrammer is offline
Old 07-08-2013, 09:12 PM   #28
jmoryl
Fan#: 50300
What I Drive: 2003 SVT Focus (silver)
FF Reputation: 1 jmoryl Good Standing Member
Two questions about aiming SVT HIDs:
What is the correct way to release the clips on the cover over the adjuster? I don't want to apply too much force and break anything.
What is the function of the little white gear assembly visible at the top of the light? Mine is has a slotted nut under a sticky black patch. Turning it a bit doesn't seem to do anything to the aiming. I thought this might be the aiming adjustment.
jmoryl is offline
Similar Threads
For Sale: Hellas US spec Headlights with HID rook18ie Archive 15 10-20-2006 08:38 PM
For Sale: SVT HID Headlights (lots of pics) *SOLD* Hocus Focus 2001 Archive 9 09-08-2006 05:17 PM
Damn I hope things work out for SVT! TORQUERULES Ford Focus & General Car Chat 7 12-16-2004 12:49 PM
Mopar power that Ford needs to imitate hbm1 General Forced Induction 72 09-20-2004 05:57 PM
